Question about Cell Phones
Phone problem My Nokia 7610 can not read applications in memory card, just themes. So if I want to open application or games I must open it from 'SeleQ' app that I put in my phone memory. I have tried other memory card but the phone still can not read at all. Can you help me sir?
Khong hieu vi sao co luc co nghe hay hong nghe duoc tieng cua ben kia va ben dau kia cung vay luon?????????..........
Posted on Oct 04, 2008
How can I do to make my nokia 7610 faster
1.remove all your messages from inbox and the saved messages.
2.remove games and applications from your phone memory. up phone memory asmuch as possible.
4.reset to factory settings.
update your phone software.
Feb 08, 2012 | Nokia 7610
Hi i m ali. i hve nokia 7610 i hve problem that when i send text msg it notify that other applications are open other applications pleas colose it first . plz send me solution
Hi there!
The message you're getting means there are application open or running on your phone and is using the memory. What you can do us turn off/on your cellphone
Hope this helps!
May 09, 2011 | Nokia 7610
How can i put a themes in my nokia n95 8gb?
Before installing any software go to
Menu> App.Manager> Options> Settings> Software Installation
In Software Installation make it ALL. This change is important, otherwise you will get an Error message Certificate Error. Contact the application supplier while installing most freeware
Also, if you see that some old themes are giving the Expired Certificate error, simply change the date of your phone to year either 2005 or 2006 or 2007 (check all as each theme has a different expiry) before installing the theme. After installation you can change back to today's date.
Now, here is the way to install themes and other applications in your Nokia . I use the USB Cable to do the installations.
1. First install the Nokia PC Suite software on your computer from the CD which you recieved with your Nokia
2. After Nokia PC Suite is installed in your PC, connect the Nokia to the PC with the USB cable which was provided in the box.
3. When the USB cable is connected, Nokia PC Suite will recognise that a phone is connected. You will then see an option on your phone?s screen asking if you want to connect via PC Suite or Data Transfer. Choose PC Suite.
4. Now, simply download the .sis or .java files (themes & applications) to your computer and Right Click on it with your mouse. You will see an option saying Install With Nokia Application Installer
5. Click Yes on the PC, and then Yes & Continue on the Phone when you see the prompts.
6. The phone will then ask you if you want to Install the Theme or Application in the Phone Memory or Memory Card.
I strongly recommend Installing themes in the Phone Memory! This helps in avoiding complications later on when Uninstalling.
When I first bought the Nokia N95, I made a mistake which a lot of new S60 3rd Edition users make, that is, I installed the Themes in the Memory Card instead of the Phone Memory. This was a huge mistake!
There is a bug in the Operating System of all S60 3rd Edition phones, due to which, if the theme is installed in the Memory Card, it cannot be deleted or removed, as it then does not show up in the Application Manager.
Ever since that mistake, I have made sure to always install themes and softwares in the Phone Memory, instead of the memory card. Yes, it eats up space on the phone, but it's worth it, as then it is easily removed as well.
And that's it, the theme or application is now installed!
Thanks for using Fixya.
Mar 14, 2011 | Nokia N95 Cellular Phone
I have forgoten my security code for my nokia e71. And i want to restore to fatory settings. the imei no. is 352925021952314
You can try to do a hard reset to restore it back to factory settings. All your contacts, messages, calls, applications, themes > everything will be gone. So BEWARE. Backup your important stuff first. Your memory card will be fine, so anything there will be saved. However, if you have applications installed on the memory card, I recommend deleted those as well.
I always tell people to install applications and themes on the phone memory always! Your phone will run faster, as will the applications. Leave the memory card for your media.
Anyways, to perform a hard reset on the Nokia E71 you do this...
Type *#7370# from the standby screen while your phone is on. It will ask for the lock code which is 12345 unless you have previously changed it. Make sure you do this right, because if you do it too many times the wrong way you can lock up your phone.
And that's it. Have fun re-installing all of your applications and themes. Hopefully this helps you out if your having problems, or if you just want to clean out your phone.
Hope this helps.
Jan 25, 2011 | Nokia E71 Smartphone
Nokia 5800 memory full even not
Dear...There seems virus attacked on ur phone.Just scan ur phone memory and card through a good PC ANTIVIRUS by using MASS STORAGE MODE.Find and delete any .exe file from ur phone and card.
Nov 28, 2009 | Nokia 5800 XpressMusic Smartphone
Nokia 7610 tht has been hacked
This is because of some sort of virus. connect the phone to the PC suit and sync all the data. Then reset the phone with the code *#7380# then enter the security pass key to proceed further. Now the phone will restart.This process will take off all the installed applications in the pone memory not the storage memory.After the restart connect the phone to the PC suit to restore all the data.
Aug 08, 2009 | Nokia 7610
I cannot install games on my Nokia 7610. Each time trying to install, gets a notification that - Nokia Application Installer - " The application installer is already running in the Phone. Please finish...
Where have you installed the spiderman? if on the memory card, backup your card data minus the games, format it and restore the card data. See if that solves the problem.
Jul 30, 2009 | Nokia 7610
Themes saved in memory card but i can't erase it
if the theme is not appearing in d file application then try to search it in phone memory and gallery...........................if not connect it 2 pc through a usb and delete the theme
Jun 04, 2009 | Nokia N73 Cellular Phone
Title. i cant open my sms
Not enough memory means your phone is too full of data IE. Pics, Themes, Contacts, Applications, Games, Old leftover files from sending via Bluetooth etc...
Do a clean up job. Get rid of all the trash.
The phone needs a certain amount of memory to function.
Mar 13, 2008 | Nokia 7610
Theme upload on memory card problem
to see those themes file and install them first you have to insatll any file manager like fileman or fexplorer, download and insatll any from these file manager software on your mobile, then you can able to see different folders and files of your mobile. among them you can find themes which you have saved. click on them they get installed.
Aug 25, 2007 | Nokia 7610
Cell Phones Logo
211 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
