Back to:
Tags:
Rainbow 75th Anniversary Canister Vacuum
Rainbow d4c
posted by Bflem on Jan 17, 2008
How do you take apart the rainbow d4c to change the switch
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 18, 2008
Not Rated (0)
bradwick1
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
All four sides of the inner shell in the top can be pushed in to remove inner shell. I tried to take my switch out and gave up after several attempts at pinching the plastic tabs inward that hold it to the case. even with all four tabs pushed in the switch didnt want to push all the way out.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on rainbow d4c:
I don't want to Accept this solution
Solution #2
posted on Jan 17, 2008
Not Rated (0)
reddevil6
Rank:Guru Guru
Rating: 88%, 1292 votes
Take off water tank, remove the screws to separate the top from the bottom, take out the screws inside the top and take out the plastic shell and the switch will be there.
Thank You!
Can you Help with these Vacuums problems?
Vacuums
Bissell Proheat will not pick up much water. The tool...
Vacuums
How do I use the Hoover SteamVac Deluxe 5 Brush Steam...
Vacuums
cvbcvbcvb
I'm having problems removing the separator, it turns...
have replaced cord have two wires brown and blue,dont know...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
