Back to:
Tags:
Printers
Generic problem for all Printers
A change of configaration
posted by jannette0307 on Jan 17, 2008
i recently had to reset my modem n firewall--- now i can't print from d network
Comment by jannette0307, posted on Jan 21, 2008
i changed the ip address on the machine and added a new port. i pretty much copied information from the previouse port w/the exception of the new ip address. but still nothing.
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 19, 2008
Thanks for Trying (70)
jaylex
Rank:Guru Guru
Rating: 85%, 337 votes
Have you changed the IP address back to what the router used to be before the reset? If not then enter a new IP address in the machine and add new port in the driver for that same address then try.
95% sure that is all that is hope it helps
Thanks J
Rating Locked! (?) jannette0307 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on a change of configaration:
I don't want to Accept this solution
Can you Help with these Printers problems?
Printers
When I go to scan something onto my computer from a book,...
Xerox Phaser 8500/DN Printer
does anyone know what this error code means HELP.?
Samsung SF-560 All-In-One Laser Printer
How do you send the same fax to quite a few different...
Epson Stylus C60 InkJet Printer
how do i change the coloured printing to black when i am...
Printers
I dont' understand the symbols on the X 4560 printer
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
