Question about Sega Dreamcast Console
Date screen I haven't used our dreamcast in about 2 years, When it powers on we couldn't get passed the screen to put in the date. We bought 2 new controllers and it still will not get passed that screen. We have two dreamcast and they both do the same thing. Help if you can? Thanks.
  • 2 more comments
  • schecter Jan 17, 2008
    If I leave the dreamcast plugged in for an hour will this allow me to get passed the date and time screen?
  • chiquilloran Dec 17, 2008
    I have a DC and i haven't played it since almost three years. When i turn it on i get the date and time screen and i cant get past it. I bought a new controller to see if it was the problem, but i still had the same problem. Please help me get past the date screen!!!!
  • Anonymous Dec 22, 2008
    wont go past data screen
  • kylehelder Jan 30, 2009
    When i turned on my dreamcast that worked fine tow years ago it just brings me to the screen with the date and i can not do anything from there. both controllers same problem. can you help??
  • 4,402 Answers
If you unplug you Dreamcast for extended periods of time the battery in your Dreamcast that saves that info will die (its suppose to last a month but over time they will wear out and not last at all). After 1 hour of gameplay (assuming the battery is still working, as Li's wear out) the battery will be fully charged and last a month.
Posted on Jan 17, 2008
Bought an acer lap top may last year is it still free too fix dvd faulty
The warranty is 1 year. So if you haven't gone pass the date, they will service a faulty DVD-ROM without a problem. Please contact Acer Tech Support.
Jan 03, 2012 | Acer Corolla Computers & Internet
How do i set the clock? l have clicked on clock and tried entering numbers but nothing happens
Enter into BIOS
  • Enter the CMOS setup.
  • system setup screen see the date and time
  • Using your arow key on the keyboard navigate to the date and change the date. Once highlighted on the month, day, or year, press your arrow key / your page up / page down keys to change the date.
Using Msdos command
  • Press Control + r key togather
  • type cmd
  • on the black screen type date
  • press enter. It will be showing the current date and also asking you to put the new date in the format mm-dd-yy,
  • type new one as per format
  • press enter
For time
type cmd
on the black screen type time
press enter. It will be asking for new time,enter new time and close the black box.
Sep 24, 2010 | Computers & Internet
I just bought a dreamcast off ebay. The console powers on and then goes to the set time/date screen. I plug in both controllers and neither will change the settings...Are both controllers broke or is it a...
controller circuit board problem,,internal battery needs to be replaced, it blue and looks like a watch batt,,it is marked in the controller board as BT1.
Also on the controller board is a resistor or transistor marked F1 that needs to be replaced. You will need to do some soldering but it's not that difficult. They are colour coated so make sure you get the right one. They are very cheap and the battery can be picked up at walmart for under 10$
Feb 27, 2010 | Sega Dreamcast Console
I have a sega dreamcast but i can't change the date. what can i do. do i need f1 fuse.
At first mine would do the same thing, so I thought. What you should try doing is go to "settings" and change the date, then go down on the list and change the memory card date settings. If that doesn't work then I'm really sorry I wasted your time.
Dec 11, 2008 | Sega Dreamcast Console
Setting Day/date on Helbros wrist watch
As an extra tip, to advance the date a little faster, you can turn the stem and rotate the hours past midnight and keep going until you pass 2 AM, then you can wind backwards, going past about 8:30 and you will hear a 'click', then you can go past 12 am again and the date will change. This makes it a little quicker to advance the date several days.
May 13, 2008 | Watches
Dreamcast freezes.
take apart your dreamcast and look at the controller input circuit board, there should be a big resistor on near one of the boards corners, make a note of the coloured bands and buy a new resistor with the same pattern and replace the one already on the board with the new one.
Mar 09, 2008 | Sega Dreamcast Console
DC doesn't go past set date screen.
try charging the console for about 30 minutes
the console has a rechargeable battery inside that needs to be charged
if the main menu keeps on moving on the background most probably the fusible resistor on the controller board is busted it has to be replaced
Change all ink message
Your Lexmark cartridges may be like my HP ones--they have a chip that the machine reads so they cannot be reused without doing some tricks to fool the printer.
My HP remembers the last 2 or 3 cartridges and also will not use ones that have passed the expiration date that is stamped on the cartridge. I'll tell you what worked for my HP.
Check the date on your ink cartridge.  I bet it has expired. If you put in a "new"cartridge but it is even an HP one with an older date, it may not work.
I had my printer stop in the middle of a print job.  It was printing fine and suddenly would not print.  So I refilled the cartridge with an ink kit I had on hand and reinserted it--no go!  Then I opened a remanufactured cartridge I had bought some time ago and inserted it.  No go, despite the fact I could see ink coming from the jets.  I finally gave up and bought a new HP ink cartridge, and it worked just fine.  But it bugged me why the new one would work and the other two that seemed just fine would not.
Later I learned that HP has a chip that reads the expiration date on the cartridges and that is what keeps those old ones from printing.  I found one trick of setting my date on my computer back to a year earlier than the exp date on the cartridge.  I saw the date on the remanufactured one I had tried earlier was 2005, so I set my computer date to today date but year 2004.  After forcing me to do print alignments several times and take the remanufactured cartridge out and put it back, I got it to print just fine.  And that 2005 cartridge that would not work earlier is what I am printing with right now.
Be advised, though, if you try the date setback, that HP printer will buck and try every way to not let you use that old cartridge.  You must say no to reflashing if HP tries to pull that on you.  And you will take out and put back that same cartridge multiple times and keep printing alignment sheets 3 or 4 times before you are successful.  But, if you persist, you can get it to work.
Oct 25, 2007 | Lexmark X63 InkJet Printer
Sega Dreamcast Console Logo
312 people viewed this question
Top Sega Video Game Consoles & Games Experts
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
