Question about Car Audio & Video
2004 chevy trail blazer
I'm looking for a front brake pad assembly diagram.
  • 132 Answers
Also, try calling your local dealer, ask to talk to service and have them fax a diagram to you. Most will do it for now charge
Don
Posted on Jan 19, 2008
    President:
  • 3,130 Answers
That's going to be a hard one on line. I looked up several with the promise of diagrams, but they all want you to buy a book. I use the Haynes Automotive Repair Manuals on all of my vehicles. They may have one in your locale public library as a reference. The one you need is book number 24072, it covers the model year 2002 to 2004 of the Chevy Trailblazer's. If the library does not have one, some auto parts store maybe willing to photo copy a picture. or you can go to the website and order one from there. http://www.haynes.com/products/?searchType=vehicleApplicationSearch2&searchEnd=yes&sfID1=&sfID2=&sfID3=&year=2004&make=Chevrolet&model=Trailblazer&x=19&y=10 Good Luck
Posted on Jan 18, 2008
6ya staff
SOURCE:
2002 Chevy trail blazer front brakes don't seem to
Um more likely than not you have air in your brake system. I'd suggest bleed your front brakes and make sure your master cyinder cap is tightened also. You may also have a leak somewhere check the reservoir and make sure its not extremely low which would suggest there is a leak somewhere, and check your lines.
Oct 04, 2014 | 2002 Chevrolet TrailBlazer
Front right wheel doesnot want to turn on 2004 chevy trail blazer
check that the caliper is free to slide on the mounting pins It is necessary so that the caliper body can self centralise and let the brake pads come of the disc rotor. When the body seizes on the pins then one side of the caliper will have the pad in constant contact with the rotor and makes for bad braking and low economy
Feb 09, 2014 | Cars & Trucks
2004 Chevy Trail Blazer,blower fan not working and the brake and ABS lights are on in the dash, checked all fuses,nothing blown. Can not seem to narrow down which relay goes to this section. Any thoug
Hello Linda! Replacing the HDM relay for the low beams will not trigger any of these problems. If the blower isn't working, you probably need to get a new blower motor resistor (for manual controls) or blower motor module (looks the same) for automatic climate control. To access, need to remove the plastic kick panel near your feet on passenger side. After removed, look up you'll see the resistor, it's about 4" long with 2 small screws in it. You'll also need to drop the glovebox door to remove the connector from the resistor to the motor. Suggestion- buy a pig tail for the resistor also, these tend to melt. Very common problem. The ABS dash could be a bad wheel hub assembly or a hub starting to go bad.
Jan 24, 2018 | 2004 Chevrolet TrailBlazer
Where is the fuel filter located on my 2004 Chevy Trail Blazer? WE
On 05+ Trail Blazer, the fuel filter is integral with the fuel pump inside of the fuel tank. It is a non-serviceable part. On 02-04s, the filter is on the drivers side frame rail at about the B-pillar. If your trail Blazer is a late 04 which means that it was build close to the 05 Trail Blazer, you may have a non serviceable fuel filter. Good luck and check under your Trail Blazer or look at your manufactured date sticker on the door which would help you indicate if your 04 is a early Trail Blazer and you'll have the fuel filter on the inside frame rail under the driver's door.
Mar 05, 2010 | 2004 Chevrolet TrailBlazer
I want to know if the 2004 chevy trail blazer has head light that are on while the vehcile is on. Ignition is on
Yes. Theses are called DRL or daytime running lights.If you depress the emergency brake on it will disable them until the brake is released.
Aug 14, 2009 | 2004 Chevrolet TrailBlazer
Brakes smoke and cause a drag when driving
Parts came loose in the drum on the side it's pulling to.the Nail may have poped off if you diden't replace them casueing the brakes to lock up. You have to take it apart angood luck doing it.
Jul 01, 2009 | 2003 Chevrolet TrailBlazer
Where is the pcv valve on the 2005 chevy trail blazer
It is located on top of the valve cover. Buy the new one and you will see what it looks like, then you will pull the hose off of it and put the new one on, 5-minutes at top to do this job.
Feb 08, 2009 | 2000 Chevrolet Blazer
2005 CHEVY +TRAIL BLAZER ABS AND BRAKE LIGHTS ON
if chains caused problem and you have driven with them off light would have gone out once it saw everything working properly. look at sensors might have pulled a wire loose with chains. the abs system runs a self test everytime you start vehicle if it sees a history code from last time it will leave light on and look to see if that problem still exists and 99% of the time it will cut light off . but need to have scanned and checked out
Dec 29, 2008 | 2005 Chevrolet TrailBlazer
Car Audio & Video Logo
201 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
