Question about SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive
Need a part
I broke the usb cable that connects my 160Gb hard drive to my computer. How do i get a new one.
    Brigadier General:
  • 6,966 Answers
Most USB cables are standard. This one specializes in USB cables, you may be able to check if they have one that will fit your need. Here and here are comparable products.
Hope this be of help/idea. Pls post back how things worked out or should you be in need of additional information.
Good luck and kind regards.
Posted on Jan 17, 2008
Where can i get a new USB 2.0 cable for the 160GB SimpleDrive
you can get it at any computer shop or if you hard a generic digital camera its the same cable..
Dec 09, 2013 | SimpleTech SimpleDrive 160 GB External USB...
The SimpleTech 160GB ext. drive has a usb 2.0 cable with a y plug. I can only plug in one but I use the additional power supply. I get a message at times telling me to use the usb 2.0 port for faster...
You are using the correct connection, the external power supply is powering the drive, so the USB cable is just handling data. I believe the message may be telling you that you will get faster performance using a USB 2.0 connection, it is probably sensing that your computer's USB port is USB 1.1.
Feb 24, 2011 | SimpleTech Signature Mini 160GB External...
Green light wont stay on on memorex traveldrive
The light signals a connection between the hard disk inside the Traveldrive to its case. If it fails that means that the hard disk is dead. The unit has died, junk it and buy a new one, hard disks can't be repaired.
Aug 25, 2010 | Memorex Ultra Traveldrive - 160GB USB Hard...
I don't know how to attach the usb cable to the external hard drive?
Connecting an external drive is much easier than installing an internal drive because you don't need to open the computer case. The drive attaches to a connector either at the front or the back of the computer case; power is supplied by a separate cable
Available connections. Your PC is likely to have one or more USB 2.0 connections so plug into this your attached harddrive usb wire
Jan 04, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
I hve a Verbatim USB Portable Hard Drive with 160gb/go. Suddenly I notice the blue light on the unit is blinking, and my K drive (Verbatim) is no longer showing on my computer. What does this mean?...
usualy it means that it has an error,try checking that the cables to the drive are connected properly if there all fine try shutting the usb drive off and turing it back on after 3 min.
you should turn your PC off also and restart it.
if that does not work you need to post more information about your PC and periferal devices.
Jul 18, 2009 | Verbatim 160GB USB FireLite: The "drive...
Need drivers
Below is the link for the FireLite 160GB portable HD. Drivers are only needed for win98. 2000/xp/vista are plug and play. The manuals are included at this link.
http://www.verbatim.com/support/support.cfm?part_number=firelite+160gb+usb&x=56&y=11
Additionally, there could be a problem with power supply. A switch is on the back...USB or EXT. EXT is for an external supply. (http://www.verbatim.com/products/detail.cfm?product_id=38819801-1143-3415-5FE3682C49A8E37F&cat_id=3883B708-1143-3415-5FB9F3C74069A098) USB is naturally for a USB cable. Clicking might indicate low power when using USB. Switch to the external adapter or get a USB cable with two connectors for the computer (the extral cable draws more power),
good luck.
Jul 10, 2009 | Verbatim 160GB USB FireLite: The "drive...
Broke external hard drive
It depends on how badly bent it is. If you're stable with your hands, and can use a small nail to pry the deformed peice straight, do so carefully. If however you absolutely need to save the data on the drive and can't afford to have the bent peice fully break off, take it to your local computer repair store and they should be able to replace the connection.
May 05, 2009 | Maxtor OneTouch 4 Mini 160GB External USB...
Can't install SimpleTech 160 gigabytes
The usb port in your compute dosent support usb 2 please change the port if your system is latest dont connect both the usb cables of the hdd cauz the latest system is with usb 2 and dosent need power if old system please connect the power usb first and then the data usb cable it should work
please also try to connect to another port of your pc if available
thanks and regards
DUSHAYaNT
Jan 03, 2009 | SimpleTech Signature Mini 160GB External...
SimpleTech 250GB USB2.0 7200 RPM External 250 GB IDE Hard Drive Logo
41 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Ricky Ostrom
Ricky Ostrom
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
