Question about Dell DJ MP3 Player
Dell dj i can't get my computer to recognize my ditty dj it works but it isn't being recognized
  • 758 Answers
Go into your Start Menu and right click on My Computer and choose "Properties" from the menu. Click on the Hardware tab on the new window that opened. Select Device Manager. Check to see if your device is recognized under Windows Portable Devices. If your device is not recognized here,what i would recommend you to do is to uinstall the device.
To uninstall the devid just right click on the device name and hit uninstall...the device usually listed under disk drives, portable devices and univeral serial bus controllers.. Once you uninstall the device..you will need to make sure what mode you have the device...turn the device on and click under setting and look for usb mode...then you want to make sure its under MTP mode or Auto....then what you will want to do is to plug the device on that back of the computer not the front...then windows should recognize it...if that doesnt do it you will need to contact the manufacturer of the device.
3. Open Windows Media Player and go to the Sync section. It should be recognized on the right-hand side. If it is not, or if your device has a drive letter after its name (for example F :), your device is not being properly recognized by the computer and you will have to contact the manufacturer of the device.
4. If it is seen in Windows Media Player then disconnect the Device and close all programs.
Next we are going to make sure that Windows Media Player is not storing unnecessary information about your device:
1. Open Windows Media Player.
2. Maximize the program and choose the Tools > Options menu.
3. Click on the Privacy Tab in the open window and choose "Clear Caches" and "Clear History".
4. Re-connect your device and choose "Manual" and "Permanent" on the window that opens.
5. Close Windows Media Player.
I hope that help...
Thank you
Computerrep
**Please rate accordingly...**
Posted on Jan 29, 2008
How do i take off music out of my dell dj ditty mp3
Plug up your dell DJ Ditty MP3 Player
Go to my computer and click on your storage device
You should be able to manually delete what music you want off
Jan 16, 2011 | Dell DJ Ditty MP3 Player
It will not pair up with my computer., the computer does not recognize it, so i can't download music to it. what is the solution
you may need a driver, if you are not running vista or xp, you will need a driver, if it came with a cd, i hope you still have ti, or try to research it online
Jul 08, 2009 | Dell DJ Ditty MP3 Player
Files on Dj Ditty won't show up on computer..
Sounds like you need to reformat the player, but here is my Dell Ditty troubleshooter:
Dell DJ Ditty
http://support.dell.com/support/edocs/systems/P97347/om/OM.pdf - manual
http://www.dellcommunity.com/supportforums/board/message?board.id=dce_djmusic&thread.id=47830 – How to Troubleshoot the Dell DJ Ditty – from Dell
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PDA_MP3_DJ_DITTY&os=WW1&osl=en&catid=&impid= - Firmware for Ditty
Did you run the installation CD first? If you don't, Windows will load its own, possibly wrong, drivers.
Make sure you didn't accidentally press the player's lock button:
The keys on the Dell DJ Ditty have been locked.
Unlock the keys by pressing in on and holding the
Volume/Scroll/Select dial until the lock icon disappears.
Reset method - Insert the end of a thin object, such as a straightened paper clip, into the reset button (near the headphone jack).
Also make sure your operating system is Windows XP - it won't work on anything before or after.
The Musicmatch service that this player was tied to was discontinued in October 2007, so you’re going to have problems even if we get it working again.
The DJ Ditty does recognize DRM-encryption for WMA files – make sure the license is up to date, or convert the file to mp3 format if you are experiencing licensing issues.
If you are experiencing frequent freezing, or a file system/corruption error, or getting the “Warning! Reformat with Firmware Updater!” message, there are two ways to format the DJ Ditty:
Format using Windows Media Player:
Run Microsoft Windows Media Player.
Connect the DJ Ditty to the computer.
Click the Sync button on the top of the menu.
Click the "Format storage media" button on the right-hand side of the screen.
Disconnect the DJ Ditty and power it back on.
Reload or upgrade the Firmware:
Download and install the latest firmware from http://support.dell.com
Run the firmware upgrade program with the "Format Data Area" checked.
-Tha Mp3 Doctor
Dec 14, 2008 | Dell DJ Ditty MP3 Player
Dell DJ Ditty froze
I waited for the Dell DJ Ditty to run out of power then a charged it again and it worked!
Nov 13, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty has frozen
Dell DJ Ditty
-Tha Mp3 Doctor
Oct 06, 2008 | Dell DJ Ditty MP3 Player
My dell dj ditty wont turn on
Dell DJ Ditty
-Tha Mp3 Doctor
Jun 27, 2008 | Dell DJ Ditty MP3 Player
No recognition
This happens to my ditty quite often. When it does happen I plug it into the USB port and press the reset button on the Ditty until the computer recognizes it.
Nov 24, 2007 | Dell DJ Ditty MP3 Player
DJ ditty wont work
Connector bent = replace the player
May 02, 2007 | Dell DJ Ditty MP3 Player
My dj ditty don't work
Same here! There must be a big problem with these things. I called DELL....that is a major ordeal in itself dealing with them.....but finally got ahold of a guy at corporate. He said they didnt make them anymore....wouldnt say why and offered a $100.00 discount on anything else they sold. I got a camera and they took off the money. Good luck! They are hell to deal with!
Dec 22, 2006 | Dell DJ Ditty MP3 Player
Will not turn on
put in usb port then push the rest in. should turn on now.
Dec 01, 2006 | Dell DJ Ditty MP3 Player
Dell DJ MP3 Player Logo
292 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
