Question about Hitachi 50UX58B 50" Rear Projection Television
65 hitachi projectin tv
I replaced both IC and tv turn on but the lights don't come on. Can anybody give me any suggestions on what else I can do?
  • Bertha Martin Jan 18, 2008
    The convergence was off and magic focus couldn't fix it. The only thing I can think of that might be a problem is a resistor I changed. I couldn't find an original so I got one from Radio Shack that was 3.3 ohm.
  • Bertha Martin Jan 19, 2008
    Thank you for all the help I've gotten. Now I have another problem. I was able to turn the tv on but while fixing the convergence it suddenly turned off and it started making a clicking noise. Now anytime I try to turn it on all it does is make a clicking noise. What else can I do. Help!!!!!
    President:
  • 4,402 Answers
Make sure your soldering is good and you don't have ant soldering shorts.
make sure everything is pluged back in.
what was the orginal problem you were having?
Posted on Jan 17, 2008
  • Cary Farah
    Cary Farah Jan 18, 2008
    once again i would check your soldering if the resister was close (which it seems to be ) wont cause it not to turn on.
    my guess is you have a solder that is touching another path
Have a Sony KP-65WV600, already replaced d board once, and replaced convergence ic's once also. Now as soon as I turn unit on, turns to red screen and shuts off, video that is, audio works ok, noticed...
Check High voltage Block.After replacing ic's (STK convergence ic's) you need to adjust Black&White scale.Turn ALL screen adjustments to min.Turn TV on and adjust screen slowly for each gun (I would start with Red first ) when you came to point that you see red background with white lines across, at that point G2 is too high (that will cause TV to shut down,don't worry just lowered adjustment and turn tv back on) so adjust to proper voltage and do the same for each gun.After that, adjust focus for each gun (again all controls are on High Voltage Block and HVB is mounted on front of your tv after you take speaker gril out) black box with 6 controls' screen RGB, focus RGB .
You should do that in dark room in order to get perfect Black&White scale,when all guns are adjusted properly you will see grey picture.Make sure 'Color" adjustment on your display is down to 0. Another step is convergence adjustment ,Flash Focus etc.If TV stil shuts off after all, your Red picture tube is short inside,take crt pcb from tube,make sure TV is unpluged from power before that, and turn Tv on .If stays On tube need replacment...good luck)
Aug 22, 2011 | Sony KP-65WV600 65" Rear Projection...
I have white spots and black spots on right side of Mitsubishi WD-C657. I've done research online, and have heard its the dlp chip. Is that true, and if so, is it something that I can replace myself,...
This tv is it the DLP projection light engine block main board itself is the problems,not easily to go into the tv itself and replacing the IC chip itself.Must take out many mechanical parts to get u the Light engine block it self.U can replaced IC but somethime the IC chip it replaced,will not solved the problems,because the tv problems now the it is spreading and going on beyond the IC chip itself.If want to keep this tv very exspensive repair,i would reconmend hire a bound qualify tv tech replaced the whole Light projection block itself,but first call Mitsubishi for some kind of deal,they might help with the repair amount cost.
May 13, 2011 | Mitsubishi WD-C657 65" HDTV
Our tv has several white spots blocking out the picture on the tv, what could be the issue?
This problems very exspensive to fix.The Light projection Engine have a problems,with a IC design flaw.This problems happen to many Big screen tvs 65 and up have a design IC flaw by many companies like Sony,Mitsubishi,Toshiba and Samsang.Call up Mitsubishi make some kind of deal with them to help u to fix the Light projection Engine by replacing the IC or replace the whole entire Light projection Egine.
Dec 08, 2010 | Mitsubishi WD-65731 65" HDTV
Tv flashes red then shuts itself off after only on for 3 min
I have not repaired this particular model. But sometimes there is an IC they refer to as a standby IC. It may also be known as a controller IC. I call it the powerline regulator. And in one case the older Sony Projection TV had an audio output IC with a standby built into this IC. So,this advice is refering to a standby IC. And this IC may be in another form already mentioned. Please visit a Sony Tech. The work inside a projection TV is very complicated, you will need to see the specialist. Give them this note and go from here. Let me know how they handle the repair.Thanks for asking and good luck!
Aug 02, 2010 | Sony KP-65WS500 65" Rear Projection...
Hitachi 50ux26b projection TV, the color lines separated...
It sounds like a convergence problem; either bad solder connections at one of the convergence Ic chips or a bad Ic. if this was helpful give me a vote----if one of the chips is now bad it will have to be replaced(usual thing is to replace all the convergence ic chips---most use two and a few 3.
Aug 12, 2009 | Televison & Video
Green leds turn on momentarily when first plugged in then shutoff
ok , on hitachi pro tv is very common with bad power supply u may want to replace the voltage regulator which is next to the fuse u already replace , also loose connection on all the power supply seccion , also u may want to check the resistor close by the convergence ic 2.2 ohn if this are smoke replace stk392-110
May 07, 2009 | Hitachi 50SBX78B 50" Rear Projection...
My hitachi 50ux58b red light comes on but tv wont come on.
check diod d915
check d196
check for open fuse on the B+ side
replace c707 1000uf @ 2KV
replace IC 901 and H.O.T location Q777
hope this helps,
regards
daniel
Jan 12, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Sony 46WT500 Arched Red Lines appearing. The tv is about 4 years old. I have read on this web site that it is easy to fix, and I am willing to try it, but I do not know how to get the front cover off. Can...
NYGirl, the convergence circuit is failing, The IC`s will have to be replaced and all precision resistors will have to be checked, I don`t know who told you this was easy to do but I can assure you it is NOT an easy fix, If you have the service manual, access to a supply house that sells good quality IC`s ( I can give you that number if you think you can do this) a working knowledge of soldering and un-soldering and a good quality voltmeter you can remove the board and do this job, approximate repair time by a qualified tv tech is 2 hours, if not I strongly suggest you call a tv tech, questions? e-mail me back, BMW Rider
Jan 01, 2008 | Hitachi 50UX57B 50" Rear Projection...
Chirping noise and flashing front power light.
Theres a short somewhere in the set. Most likly the HOT is shorted or the vertical IC has caused this in the past. In one case I had shorted convergence IC cause this symptom.. This set is solid state and there are no user serviceable parts inside so please call a trained tech to assist you with this problem Good Luck
Aug 17, 2006 | Hitachi FDX Series 43FDX10B 43" Rear...
Televison & Video Logo
75 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
