Good day,
The fan motor runs when the thermostat asks it to.
If the machine is not at the proper temperature, the fan will run 24/7.
You have a cooling problem with the machine.
here are some areas to check.
1. The fan motor in the freezer compartment. It is behind the rear panel. You should be able to hear it running when you open the freezer door.
2. The defrost system has failed. Once again, open the freezer door, if you see frost built up on the rear panel, Either, the defrost timer, defrost thermostat, or main heater has failed.
3. The compressor is bad, or the start components mounted on the side of the compressor have failed.
4. Refrigerent has leaked out, or the system has an internal restriction.
The last 2 items are best left to a trained repair technician.
