Question about Floppy Drives
Jumper settings a friend i have, borrowed my matsushita 5.25 floppy drive and removed the jumper pins from the back to repair his computer and does not remember where he had to put them back can you help me IS ANYONE THERE?
    Problem Solver:
  • 11 Answers
Re: jumper settings
Insert the jumper pin into 1 2 or 3 depending on your drive alocation i presume it is the only FDD in your case so set it to 1 dont set it to 0 or D this is a diagnostic mode.
if your on scsi you can set it to any depending on the drive slot i.e (a: b: or X:) - Lordlangford
Posted on Aug 19, 2009
Re: jumper settings - Floppy Drives
Posted on Feb 21, 2008
  • 226 Answers
Re: jumper settings
Insert the jumper in the first pins from the left insert it verically. For master setting.
Posted on Jan 17, 2008
0 characters
3 Points
Jumper settings Chinon F354E floppy drive
Hi Robert Bissett,
The amiga drive Chinon F-354 have jumpers, long itme ago I did this.
I think you have to set a jumper for the drive there is both normally marked with DS0 one of the drives need to be changed to DS1.
Dec 23, 2011 | Floppy Drives
I am installing an EPSON SD_600 5.25 inch flopy drive into a gateway computer. Which if any jumpers do I need to change into order to have this drive share a data ribbon cable with the existing 3.5 inch...
Unless floppy drive cables have changed in the past few years, they're designed for 2 floppy drives, with the jumpers on both set the same way. There's a small twist in the cable that changes the drive addresses instead.
Or you could just replace the existing drive with the new one.
Mar 13, 2011 | NEC Epson Combo 5.25 and 3.5 Floppy Drive...
How do I add two floppy drives, A and B? There are no jumpers to set.
If you're using an IDE cable and a fairly modern motherboard, just plug one IDE into the first drive, the second IDE into the second drive, and then plug in the IDE cable to the motherboard, and it should automatically configure the drives regardless of jumpers.
Mar 05, 2011 | NEC FD1231M 144MB 35" Internal Floppy Disk...
Hello, Do you have a way to replace the JA-751 8 inch FDD by other one as CF card,...... Thank you. Weng Canxin
you can replace your matsuhita floppy disk drive by a DTX200 floppy disk drive emulator ,that work perfectly,no more trouble ..sincerely
Sep 15, 2010 | Matsushita Floppy Drives
FD-05HG-8861 pinout needed
Here's a link to a document that contains the pin-out of the interface as well as other relevant data:
Mar 08, 2009 | Teac Dell Floppy Drive 1.44 Slim FD-05HG...
I need a JU-253-403P floppy drive or equivalent
[International Portal Floppy Drive ,] is "TEAC low-density jumper floppy drive, SONY low-density jumper floppy drive, YE-DATA low-density jumper floppy drive, EPSON low-density jumper floppy drive, MITSUMI low-density jumper floppy drive, Panasonic low-density jumper floppy drive, Mitsubishi low-density jumper floppy drive, CITIZEN low-density jumper floppy drive, NEC low-density Jumper floppy drive "global distributor. ]
Mar 05, 2009 | Panasonic (JU257A607P) (JU257A607P)...
ok ive not seen one of these in a long time most floppy drives do not need drivers i gus with this one there are jumper set up at the back
try setting it to slave mode
settings should be described underneth
Dec 29, 2008 | Panasonic JU 257 (JU257A827P) Internal...
This drive supports Ready signal or Disk Change signal on pin 34 (RY34 or DC34), has a large number of jumpers for various settings, thus (unlike the standard 235HF drive which works in PCs only) this drive can used to replace a 720k drive on older computers such as Amstrad CPC/PCW or Commodore AMIGA.
Nov 03, 2008 | Teac (FD235HFC291/391) (FD235HFC291391)...
1.2 MB? is this a 5 1/4" drive you are talking about?
You need an older floppy IDE ribbon. No drivers needed for that.
Aug 23, 2007 | Teac Floppy Drive 235HF Internal Floppy...
Floppy Drives Logo
562 people viewed this question
Top Floppy Drives Experts
Brian Sullivan
Brian Sullivan
Donna Sander
Are you a Floppy Drive Expert? Answer questions, earn points and help others
