Question about Dell OptiPlex GX270 PC Desktop
Is this a Software/Config/Hardware Problem ?
When I boot up PC and go through usual Switch-on/log-in procedure and begin using the PC randomly goes through some sort of reset/re-boot procedure which results in the monitor switching to stand-by/hibernate mode with the PC on. I have to press and hold the power buton down in order to get PC to switch off and thus re-booting in order to switch the monitor back on.
This happens with both CRT and LCD monitor types.
Any ideas/solutions welcome.........................???
  • jebediah243 Mar 08, 2008
    I believe I have the same issue.... at no specific time the machine appears to access its drives and then the monitor goes blank with a No Video Signal message in the centre of the screen. I also have to reboot the machine by holding the power button down.
    I have checked my hibernation setting and checked the BIOS Power Management settings - still no fix.
    Sergeant:
  • 239 Answers
Apparently someone must have went into your properties, By right clicking anywhere on the desktop, Choose properties and then screen saver and then power options, Once there look into the setting for hibernation,standby,sleep make sure that they are set so not shut monitor off after so many minutes. What I am thinking is when you quit using your mouse for any amount of time it turns the monitor off. I hope that gets you going, If not you can Write back here and ask me again we can look for another solution. Thanks
Posted on Jan 17, 2008
Cisco 3750 web config
Yes, know more about the Cisco 3750, just visit: http://www.3anetwork.com/cisco-catalyst-3750-switches-price_c41
Dec 26, 2013 | Computers & Internet
Wont boot/ says auto config over and over
Then use Recovery Console:
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
After restarting windows use a system utility software like RegInOut.
Dec 28, 2011 | E-Machines eMachines Desktop PC
After installing some recent windows updates, I then did a restart to the computer. The computer no longer will boot into windows. It ' boots to windows xp logo and then changes to a blue screen after...
This may help.
http://www.user-guides.co.uk/cddownload/Samsung/N120-12GBK/Samsung-N120-12GBK-Fix-Repair-NTLDR-Missing-Corrupt-or-Compressed-Boot-Disk-CD-98-XP-2000-502214.html
I have never used one as I have my own boot disc.
Feb 15, 2011 | Samsung N120-12GBK Netbook
Will not boot up past the message I describe below
You might reload your Operating System to correct this. Insert your Recovery disk into your drive, choose DVD as Boot Option, recover your OS.
Nov 22, 2009 | Sony VAIO VGN-FJ270/B Notebook
When I turn on my computer it begins the boot then goes black
Try booting into safe mode. That will disable all drivers and use generic windows drivers to send commands to the devices. If that still doesnt work, id say that there is a problem with your OS installation. Backup your files using an external harddrive enclosure and reinstall the OS.
If you need further help, reach me via phone at https://www.6ya.com/expert/jarrad_11786570be7a2abd
Jun 04, 2009 | Dell Latitude D600 Laptop Computer -...
Packard bell versa e400
Hi
files in system32\config\ are missing or corrupt.
there is a back up stored by default at c:\windows\repair
you can copy the contents of windows\repair folder into system32\config\ and it should solve the problem, you can do it with the windows installation cd by using the recovery console.
Go into the repair folder enter the following commands in repair console
cd windows (press enter)
cd repair (press enter)
copy *.* c:\windows\system32\config\ (press enter)
files should be copied
type exit, quit or restart or reboot to restart the computer.
May 22, 2009 | Dell Inspiron B120 Notebook
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
Catalyst ws-c2926 password recovery problem
  1. Attach a terminal or PC with terminal emulation to the console port of the switch. Use the following terminal settings:
    9600 baud rate
    No parity
    8 data bits
    No stop bit
  2. Unplug the power cable.
  3. Hold down the mode button while reconnecting the power cord to the switch. You can release the mode button a second or two after the LED above port 1x is no longer illuminated.
    The following instructions appear:
    The system has been interrupted prior to initializing the flash file system.
    The following commands will initialize the flash file system, and finish loading
    the operating system software:
    flash_init
    load_helper
    boot
  4. Type flash_init.
  5. Type load_helper.
  6. Type dir flash:. The switch file system is displayed:
    Directory of flash:
    2 -rwx 843947 Mar 01 1993 00:02:18 C2900XL-h-mz-112.8-SA
    4 drwx 3776 Mar 01 1993 01:23:24 html
    66 -rwx 130 Jan 01 1970 00:01:19 env_vars
    68 -rwx 1296 Mar 01 1993 06:55:51 config.text
    1728000 bytes total (456704 bytes free)
  7. Type rename flash:config.text flash:config.old to rename the configuration file. This file contains the password definition.
  8. Type boot to boot the system.
  9. Enter N at the prompt to start the Setup program, Continue with the configuration dialog? [yes/no] : N
  10. At the switch prompt type en to turn on enable mode.
  11. Type rename flash:config.old flash:config.text to rename the configuration file with its original name.
  12. Copy the configuration file into memory: Switch# copy flash:config.text system:running-config
    Source filename [config.text]? (press Return)
    Destination filename [running-config]? (press Return)
  13. Change the password: switch#configure terminal
    switch(config)#enable password Cisco
    switch#control/Z
  14. Write the running configuration to the configuration file:
    switch(config)#write memory
Jun 07, 2008 | Cisco Catalyst 2926 (WS-C2926) Networking...
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Registry file failure
If the last suggestion i posted didn't work, you need to put in your Windows CD on boot up and when it asks if you want to repair or install press 'R' for repair, this should repair any damaged registry files and Windows files.
Nov 12, 2006 | Dell Inspiron 600M Notebook
Dell OptiPlex GX270 PC Desktop Logo
73 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
