Question about Car Audio & Video
Amp cut i have an alpine head unit and changer being pumped by a infinity ra 6006, this in turn is driving two qb69s and a 1200w sony sub, the problem is it cuts out when i turn it up almost as if the cd is skipping. it returns to normal when i turn it down.its done this on two different head units. please help bledger ov crammy
  • 2 more comments
  • bledger Jan 20, 2008
    hi mjap, no it doesnt have a db limiter, also how do i find out the impedance of the speakers? will it be printed on the speakers? what should it be? all wiring to amp is 4mm ofc. thanks for your help..
  • bledger Jan 22, 2008
    both amp wires are of good quality and connection,i connected the ground wire to the body, might it be better to connect to the - terminal on battery?
  • bledger Jan 26, 2008
    hello again,ive found the source of the problem, its not very technical though. the cd changer is right underneath the speakers(in my van) and the vibration was causing the cd to skip.ive now moved it. thanks for all your help, ive learned a lot.
    bledger
  • Mark Payas
    Mark Payas May 11, 2010
    does it have an dB limitter.? or you are using a different speaker impedance..
  • 107 Answers
Use an ohm meter to check the impedance. impedance is resistance (ohm). and check wether you are having a voltage drop from your supply.
Posted on Jan 20, 2008
  • Mark Payas
    Mark Payas Jan 22, 2008
    have you checked if there is an voltage drop in your supply.? 1200W is too much. put a two 4700uF capacitor and if there isa voltage drop.
  • Mark Payas
    ps.
    check the voltage in high volume.
    I'll wait for your reply. write all the details. ok.
    Novelist:
    Champion:
  • 218 Answers
Make sure that you have the right speaker load on your amp and also be sure that you are not starving your amp for current by having too small a wire for either the B+ or ground connections. Of course check all your connections to be sure they are in good shape.
Posted on Jan 18, 2008
I bought a new 1200 watt xplod amp and pluged it to a 1200 watt double coil sub with my alpine headunit the head unit is too old so i got a new xplod head unit but now i got a really freak low sound...
personally I would probaly contact the place where you bought the equipment, providing you have connected everything up correctly, it sounds like the amp is faulty
May 05, 2011 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
I have an alpine cda9831 unit with 10" subs. I have an alpine v power m500 independently running them. The subs will randomly cut off and on and the wires to the head unit have been checked for loose...
so you have already ensured that there are no crossed/loose wire strands.
you are running 2 subs off a single alpine mono amp.
if subs are 4 ohms apiece, you should be fine. if you have 2 ohm subs, or you have dual voice coil subs and you are running all the voice coils parallel, then there is your problem. you can have a maximum of a 2 ohm (2x4 ohm speakers= 2 ohms.) load with that amp.
ensure that the subs are 4 ohms apiece, and that you are not using dual voice coils. if the subs have 2 inputs (dual voice coils) then only use 1 input apiece.
if this is already taken care of, then your amp is defective.
Nov 06, 2010 | Car Audio & Video
What kind of wire do I need to install Infinity reference series 605cs with a JL Audio 10" sub and a Alpine Flex 2 amp? Can I use my factory head unit?
You can use the factory speaker wiring for the Infinity speakers you should purchase a amp kit which will give you everything to install the amp. See site below
http://www.sonicelectronix.com/item_18428_Raptor+ISPKBL4-BG+by+Metra.html
Well that all depends on the current audio system you have now is it just a basic or a premium factory system with a factory amp. Honestly you would get a better and cleaner sound if you change the factory head unit to a after market one which has preamp feeds and the higher the preout volt the better. Just make sure it is compatible with the amp volts input (Example 4v to 250mv) If you use the factory headunit you would have to by a high to preout adapter it connects to the exsiting radios speaker leads, but like I said before change the head unit you won't be sorry. Do not forget if you change the radio you need a radio install kit and the wiring harrness which converts the two radio plugs so you don't cut them so down the road you can remove the after market radio and just replug the factory right back in.
Apr 16, 2010 | Infinity Reference REF 605CS Car Component...
I have a set of Alpine Type R 12 inch subs... I have a 1500 watt amp powering them but when I turn the music up, the bass cuts out. Where should I start looking for the problem?
ground is loose(most likely amp), battery running low, subs might be damaged? feel free to keep me in touch if problem occurs more after checking grounds and power source and subs. Also might need to re-tune your head unit and amp?
Jul 03, 2009 | Alpine Type-R SWR-1042D Car Subwoofer
Subs cut out at low volume no matter the settings
I'm not a complete audio expert but it sounds like somethings over heating or you have a blown out put bridge.
Jun 20, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Sound loss
bad system cofiguration too much load on rea amp
May 11, 2009 | Infinity 475A Car Audio Amplifier
Sub cutting out
Check the 12v wire running from the battery to the amplifier. Also the sony explode is a garbage subwoofer compared to the Alpine.. sony (they say 1200w max but its more like 100w to power the thing) Amp could be going. Is the amplifier hot when running. If there is a burnt smell comming from the amp, its the amplifier
Mar 27, 2009 | Alpine Type-R SWR-1222D Car Subwoofer
Problems with my txi 6006 amp
check all connections then check the subs voice coils to make sure there not burnt smelling, or burnt looking.then check the cars charging system you might have to add an extra battery,and or cap.
Jan 09, 2009 | Hifonics Titan TXi 6006 Car Audio...
Alpine mrd m500 amp is not pushing my 12 in infinity sub
If you have a dual voice coil sub, make sure that you have the positive and negative terminals connected properly. If you have ONE of the coils wired backwards, it will cause the speaker to produce little or no sound.
Have you set the gains properly?
Are you sure the amplifier is receiving a strong signal from the head unit?
Have you tried it with a different speaker?
Jul 19, 2008 | Alpine MRD-M1000 Car Audio Amplifier
Car Audio & Video Logo
91 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
