Question about Frigidaire GLTF2940ES Front Load Washer
Won't drain... Hi I keep getting an error code E20 on my washer I have checked drain hose and it is fine, I have also checked household drain and it is fine. Called Frigidaire and they said it was internal clog. Does anyone know how to fix this without calling a service company? Thanks
  • ErinD Jan 17, 2008
    Thanks I will give it a try when my husband comes home...I will let you know..
  • ErinD Jan 21, 2008
    IT WORKED....after telling my husband 4x's to go through the front he finally lisented and we had it fixed in about 1/2 hour. Thanks so much...
    Sergeant:
    Champion:
  • 262 Answers
On the pump there is a lint filter it is either in the drain hose coming from the tub or there is a slot on the pump that screws off.you have to take the front lower panel off to get to the pump after you take the junk out unplug washer for 60 seconds to reset computer. let me know what you find
Posted on Jan 17, 2008
  • Bill Dozier Jan 22, 2008
    im glad it helped you your welcome
How can I fix E20 error on washer
COULD BE EITHER? U HAVE TO CHECK THE HOUSE DRAIN AND THE HOSES AND WATER PUMP FOR OBSTRUCTIONS
Feb 16, 2014 | Frigidaire ATF6000ES Front Load Washer
Electrolux washer ewf1084 error code e20
Hello - Error code "E20" typically indicates that the water is not draining properly or not pumping out fast enough. Is the washer making a humming noise? If so, either the drain hose may be kinked or the household drain is clogged. Otherwise the unit can be experiencing more serious issues, like a faulty pump or Main Control Board. If I was in your position, I will personally consult a certified technician for a proper diagnosis and to move forward accurately.
Feb 19, 2013 | Washing Machines
Error code e20
Hello leah_mcmunn - the error code E-20 indicates that the water doesn't drain. This could be caused by either the drain hose is kinked or your household drain is clogged. If the drain pump is making a humming noise, check the restriction in the drain line. If not, then you might need to contact a professional to possibly replace the pump.
Sep 20, 2012 | Frigidaire GLTF2940ES Front Load Washer
I have a Kenmore Elite washer, model 44092. The machine won't spin and the error code is E20. What is wrong with it?
The machine, based on the error code, is made by Frigidaire for Kenmore. Error code E20 pertains to a slow or no drain problem which can be due to a clogged/kinked drain hose, blocked drain filter/coin trap, or a broken drain pump. The link below provides the detailed troubleshooting procedure of this error code.
Error Code E20 on Frigidaire and Frigidaire-made (including Kenmore) Front Load Washing Machines
Aug 20, 2011 | Washing Machines
Kenmore elite washer cycle signal keeps going off an on turing cy
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 04, 2009 | Kenmore Washing Machines
Kenmore front load washer just beeps doesn't start error code says "lol"
Jan 04, 2009 | Washing Machines
Error code E20. This is not listed on the error code chart. What do I do to fix the problem.
E20 means the drain hose is plugged or kinked or the household drains are plugged. YOur washer will not drain and spin until this is fixed.
turn off the washer/unplug it/remove the drain hose and check for a clog. If it is there, clean it out. If not - check your sinks and toilets for slow running drains. The garbage disposal is a good place to start as well. plug the sink, fill it with hot water, then pull the plug and start the disposal. That will help clean the disposal and also show you if you have a drainage problem there. Plunge the toilets, etc.
Good luck to you!
Aug 17, 2008 | Frigidaire GLTF2940ES Front Load Washer
E20 Error
On the sheet, 2 beeps and error E20 says Water Doesn't Drain. Drain hose is kinked or household drain is clogged. Straighten hoses or unclog household drain.
Jun 06, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error codes
I suggest you snake out the drain into which the machine waste hose goes, the standpipe that is. The drain could be blocked somewhere causing pressure problems which is conveyed to the machine. Be sure to replace the machine exit hose at about 3 feet from ground level, and dont shove it too much into the standpipe. Do not block up the point where the machine hose goes into the standpipe, it shouldn't be air tight.
Dec 28, 2007 | Frigidaire FTF530FS Front Load Washer
Zanussi Electrolux ZWF 1430 W (E20 error)
Check water "forreign object trap". It's under the lid at the bottom of the machine. First drain water by pulling out the hose and pull out the plug. Then unscrew the trap. Have had this E20 error twice. First it was two coins there, next it was a big paperclip. Have worked fine ever since.11_20_2011_8_57_27_am.jpg
Sep 26, 2006 | Zanussi ZWF1430W Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
206 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
