Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa.
try plugging it into some other USB port and even try uploading the drivers of the USB!! or best is try using some other USB to test it!!
reply and rate!!
There are two way to upload your picture's or video's to your pc:
You can upload video to the use of your camcorder connector.
Connect your USB cable to your camcorder and plug it to your computer.
You need to turn on your camcorder so that it will be recognized by the
computer.
You can upload also your video's with the use of memory card
reader. Remove your memory card from your camcorder and insert it to the
card reader. Plug the card reader to the computer. The computer will
recognized the card. Now you can upload your photo's or video's.
Sounds like you didn't use the "safely remove hardware" function when you disconnected the USB cable. This can corrupt the card and even the camera. You could try using a separate card reader to download the pics from the card. If that works, and the pics are safely downloaded, then you should format the card in the camera to erase and optimize it. If it doesn't work, take the card to a Walmart that has a Kodak Picture Kiosk and it should be able to read your card. You can print the pics or even make a cd of them. Then, format the card in the camera.
Hi Ray;
Try uninstalling the Fuji software completely, through the Windows control panel. Don't use the supplied software at all. Make sure the camera is unplugged from the computer. Open "my computer" and note which drives are present. Now plug in the camera (still turned off) to the USB port. Turn the camera power switch on. Wait and see if a new drive icon shows up. It may take a minute or so. If you get a new icon (probably Fuji DSC or similar), you should be able to open the new drive and access the images through the various folders. If not, can you see images on the camera screen (when not connected to computer)? If yes, maybe a bad cable. If no, could be corrupted images on card.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
