Question about Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum
Adaptive brush control
Does any one know how to fix an adaptive brush control that won`t let you turn the control to activate the auto brush.
  • 53 Answers
Hi bamboozle,
I have found some instruction on how you can repair your dyson this is the link www.international.dyson.com/aftersales/manuals/DC03opmanual.pdf
you can try it`s got instruction on how to fix your adaptive brush.
I hope if this is useful to you.
Posted on Jan 17, 2008
Good evening! I use IRobot Roomba, currently brush do not active any more. Please help
YOU HAVE HAIS STUCK INSIDE BRUSHES GO TO YOUTUBE THEY HAVE A VIDEO HOW TO FIX YOURSELF
Nov 17, 2016 | iRobot Vacuums
How do I get to the impeller on my Hoover steam vac dual v to get to the rotating brushes to fix their rotating
First, there is no impeller that turns the brush. It is controlled by a turbine assembly. There is the brush with the middle stem (know as the brush block) and the turbine turns the brushes.
Turbines cost $39.00
Brush Block Assembly cost $34.00
Called our store on Monday to order. 937 291 3560
www.daycinvac.com
Sep 27, 2014 | Vacuums
Can't activate front brush
Hi Sandy, it's Jack at Dyson.
DC25 has a belt engineered to last the lifetime of the machine. It's protected by a sensor which shuts off the brush bar if something jams it. If your brush bar won't rotate it's likely it just need to be reset. Please follow the steps shown in the video I've attached.
Tip: Once you've checked the cleaner head for obstructions and removed any threads or hair from the brush bar, recline the machine into the vacuuming position. Turn it on with the red on/off switch, then press the silver brush control switch twice.
Please note: The brush bar will never rotate when the machine's standing upright, so make sure you recline it down into the normal vacuuming position before testing it.
I'm confident this will resolve the issue, but if you would like further advice after you've tried this, please get in touch with us directly. You can reach our genuine Dyson experts by calling 0800 298 0298 (UK), 1-866-693-9766 (US), or 1-877-397-6622 (CA).
Best wishes,
Jack
Dyson Online Customer Support
www.dyson.com
Aug 19, 2013 | Dyson DC25 Vacuum
The brushes do not disengage when in upright position
Set the brush control, as needed. The brush control turns the brushbar on the underside of the vacuum on and off. The button is located beside the power button, on the top-front of the vacuum cleaner. Turn on the brush control for cleaning carpet. Turn off the brush control for bare floors or delicatelb_icon1.png rugs..
Feb 25, 2013 | Dyson DC15 All Floors - The Ball Bagless...
Dyson dc25 off button won't turn off, brush button won't engage brushes
Hi ... did u get this fixed cos mine is the same hve to switch off on the wall?
Sep 22, 2012 | Dyson DC25 All Floors Bagless Upright...
Brush wont turn belt not broken no sure how to get to shaft to see if it is turning
Sorry to hear you're having difficulties with your DC07. If the brushbar in your cleaner doesn't seem to be rotating, please check you have the brush control set to 'Carpets', as it won't rotate when set to 'Hard floors', or if the cleaner is standing in the upright position.
If the brush control is set correctly and the brushbar still won't turn, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Jul 09, 2011 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brush bar is not turning when I turn on my dison vacum
Hi There,
The Dyson DC15 All floors is actually a 2 motor upright, meaning the suction motor is separate from the motor that rotates the brushes. The first thing you should check is the reset switch on the brushes. Behind the brushes there is a little red pole, push this down to reset the brushes, and see if this fixes the problem.
If not, then you may have a bad on/off switch for the roller brushes. Try pushing the switch next to the main on/off switch that controls the brushes up and down, up and down, can you hear the brushes attempt to come on at all? If you could hear them come on even somewhat, this means that your brush on/off switch is bad and needs to be replaced.
If nothing happens when you push this switch, it still may be bad and not getting any power at all to it.
Does the machine make any sound at all when you try to turn the brush switch on and off?
Please try pushing the reset switch, then testing the on/off switch first. If neither one of these solutions works, please just use the comment field on the repair and let me know, and I can then walk you through some more advanced diagnosing of your machine.
Thanks,
Chris Jones
GoVacuum.com
Apr 28, 2010 | Dyson DC15 All Floors - The Ball Bagless...
THE BOSS SUPERLITE THE BRUSHES WON'T TURN
Check two things with this model: if the top slider button has been activated it will turn the brush roll on. If not then you'll have to remove the sole plate and check the sides of the beater bar - sometimes this will get jammed and refuse to turn because clogging of dust or tangled hair/carpet thread takes up the thread wheels at the sides. Sadly this model has a permanent toothed drive belt that can't really be replaced by the owner. However check the slider control on the top of the main body / handle first before doing anything - as you know it has a two option slider - switching on without the brush roll function and switching on with the brush roll activated.
Feb 28, 2009 | Eureka Boss SuperLite Bagless Upright...
Bissell Healthy Home Vacuum Cleaner
sounds like you need a new belt for your agitator(brush)
Jan 26, 2009 | Vacuums
Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum Logo
168 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
