Samsung flatscreen+ sky+
We recently bought a samsung flatscreen tv and linked it up with sky. It works fine however when we record of sky+ and watch programs back we occasionally get moments through the recording were the picture jumps as well as the sound. it will continue for about 30-45 seconds then be fine.It only happens every so often. ? any idea's to the problem????
    President:
  • 1,284 Answers
Is the TV connected using the HDMI port? If so then connect using the component instead and see what happens. If it works ok then possibly a software upgrade on the TV or your sky box.
Posted on Jan 19, 2008
I have to turn the sound up full blast when watching recorded programmes. It is fine when watching live tv so not sure if it is the tv or the Sky box, can you advise please.
Mate does your sky box have a volume control as well as your television, I have a sky box(fox-tel)with volume control as well as the television volume control.... I have the television volume up full and control the volume through my sky box(fox-tel).... Hope this helps... CHEERS...
Mar 12, 2016 | Televison & Video
Hi, I have a sky tv link set up in my bedroom to a Samsung tv that works fine, however I have bought a Sanyo tv and the sky doesn't work on this tv??!! Any help would be apreciated
go to menu and find connection settings see if it is cable or air please select cable...
if already done but no change maybe your TV is not hd..select air only..
Mar 06, 2012 | Sanyo Televison & Video
Hissing and Humming when trying to use the speakers for the tv
The sony manual tells you how to connect to a TV however most of us now watch TV connected to a SKY box. The Scart lead needs to be connected to the Sky box for the sound to work correctly. Ignore the Manual and connect the Scart lead from the DVD Unit directly into you're sky box. It works fine.
Apr 04, 2010 | Sony Audio Players & Recorders
I have recently bought a sky plus hd box and want to connect an external dvd recorder to it(Sony). Followed instructions but it will not pick up a signal from the hd box by the way I live on the costa del...
if you connect the dvd to the tv using scart socket 2 (av2) it should send a signal to the dvd, depending on the make/model of tv, you also may have to set the av2 output in the menu.
Alternativly, connect the sky to the dvd input and the dvd output to the tv, this should also work.May have to watch the tv with the dvd on set to av.
Nov 20, 2009 | Televison & Video
I have a uhf pro 6.0 and a samsung flat screen tv. how do i program the remote to the tv. the controller is for a dish network system.
hi i bought a flatscreen samsung and subscribed to sky tv and got the blue ray... how do i get all these to work on one remote insted of three
Nov 03, 2009 | RCA RCU600M Remote Control
I have just bought a samsung lcd tv with 1 scart socket. But I have a satellite box and an hdd recorder but I dont know how to connect it all up. Could anyone help. Thank you
The Sky box should connect to the TV using it's TV Scart output.
The HDD recorder then connects to the SKY via the other Scart.
When you turn the HDD recorder on, the SKY box will automatically switch.
You need to put your normal antenna into the HDD recorder and tune it in.
When the Sky is off, you can use the HDD recorder for playback, you can also switch between the 2 when it is on with the Sky remote.
Sep 05, 2009 | Samsung Televison & Video
Sky+ DVD Recorder Tuning
You need to connect up the Sky+ to your recorder via scart. This will eliminate poor picture quality. The Sky box will be on ext1 on your recorder or something like that
Oct 12, 2008 | Televison & Video
CAN ONLY GET THE SURROUND SOUND TO WORK WITH DVD'S NOT WITH NORMAL TV OR SKY?? WHY??
You should have a AUDIO menu in which you can simulate true surround sound. This should be in your owners manual. Your DVD is recorded in dolby surround sound that's why on your set it will be reproduced as recorded. I hope Samsung is using a ATSC tuner in that model?
Apr 04, 2008 | Samsung HT-Q100 System
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
Souud delay on tv /amp
Instead of connecting each device (sky&dvd rec.) to the TV separately, I would simply hook up the sky to dvd recorder (connect the sky output and dvd recorder input), and then connect the dvd recorder output (must be called "play out") to one of the available recorder inputs (which could be a dvr, an empty tape input, etc)of your amp. However, you'll still have to establish a feedback between your dvd recorder and your amp. Therefore, if the dvd rec. supports it, you'll have to hook up the rec.out, which is on your amp.,to rec.in on your dvd recorder. After all these audio connections, you will only need to make a video connection among the sky, dvd rec., and tv. Get a video cable to hook up the sky video output to your dvd recorder's video input, then do the same thing between the dvd recorder's tv output and tv.
Apr 12, 2007 | Cambridge Audio Azur 540A Amplifier
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
