Question about Whirlpool Duet GHW9150P Front Load Washer
Washing machine tub is wobbling in spin cycle.
    President:
  • 1,314 Answers
Its supposed to its on shocks and springs so it stayes balanced that way
Posted on Jan 22, 2008
197jacobs
  • 226 Answers
SOURCE: washing machine tub wobbles violently during rinse
borken sprinng
Posted on Oct 18, 2010
SOURCE: Washing machine will not go thru it's spin cycle.
I just replaced the 4 rubber straps on the tub. Washed a load and it worked fine. Washed a second load and it did not spin on the rinse cycle. Checked the wiring on the switches. All OK. What do I check next. Did I mess up something around the tub ?
Posted on Nov 13, 2008
SOURCE: washing machine drum is very wobbly
* General tips
* Balance the load
* Level the machine
* Inspect the water pump for a blockage
* Inspect the coupling
* Inspect the transmission
* Adjust the drive belt tension
* Check the motor bearings
* Check the drum brakes
The above are possibly the general remedies for this problem.But possible if the problem still persists after this, possibly the drum bearings might have been damaged during the previous heavy vibrations.Please do post comments.Will be glad to help you out.Good luck.
Posted on Jan 16, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
  • 102 Answers
SOURCE: Washingmachine tub spins during the wash cycle
If it's a top loader it sounds like the spin pall on the transmission is stuck, which would mean new transmision
Posted on Aug 06, 2009
What causes my frigidaire top load washer to vibrate and make rattling noise during spin cycle
There are springs and bumpers/shocks in the machine that hold the tub. When they break or come loose, the tub wobbles.
Jan 03, 2016 | Frigidaire FAHE4044MW Affinity High...
My top load Bravos washing machine wobbles during spin cycle.
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Sep 30, 2017 | Maytag Bravos MTW6600T Top Load Washer
Top load ge washer wobbles on spin cycle when tub is empty
Have you purchased this washing machine recently or have you just moved house?
I'm wondering if you have left the transit bar in situ?
If it is an old machine you may have a worn rubber mounting bush or similar.
I'm not a domestic appliance engineer but have some mechanical backround knowledge.
Sep 12, 2012 | GE Washing Machines
Kenmore Elite Oasis HT makes loud noises during spin cycle.
The tub may be unbalanced and wobbling. This may be due to washing heavy items such as rugs, towels, etc. If it is noisy with regular laundry loads, the mechanism that supports the tub may be loose or broken.
Sep 10, 2012 | Kenmore Oasis Agitator 4.5 cu. ft....
My washing machine makes a very loud banging noise at the start and end of the spin cycle and there is a scraping sound throughout the cycle as though there is metal in the drum. What could be causing...
If you have an older machine it is the un-even load distribution in the wash tub. The wash is not evenly distributed in the wash tub. The wash tub don't spin evenly and wobble instead.
Mar 30, 2012 | Washing Machines
Top loading washing machine tub wobbles a lot during spin cycle.
The top lifts off, then you can see the area around the drum and tank. There are springs and dampers that hold the frame and the drum steady. Check to see if they are broken or loose.
Feb 26, 2018 | Maytag Washing Machines
Washer tub wobbles, washer is level, on spin cycle the tub wobbles so bad it sounds like the tub is hitting the washer.
Sounds like a drum bearing problem , unless you are an engineer , suggest call service agent for estimate.
Nov 08, 2009 | LG WM2101HW 4.0 cu.ft. Washer
Spin
Does this happen with every load? I've had this happen occasionally but it was caused by one or two heavier when wet pieces of clothing that caused the tub to get off center and it would wobble out of control. By just rearranging the wet clothes to balance the tub it stopped wobbling. But only after making sure that the heaviest objects were on opposite sides if the tub.
Nov 11, 2007 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
126 people viewed this question
Dan Webster
Dan Webster
Sal De
