Question about Nokia N70 Cellular Phone
N70 blanking(all display white )
Helo...i have problem w/ N70 all blanking white.. its will offline and make a Hand sound.. but sometime just half of the sound (hand),, i need a solution how to repair and wht should i fix them and..i already fix both of the ic display its ic glass(small) , but b4 that i brush and change new connector lcd also..but i kept change new ic glass(display) now its more bad.. its wont turn on.. when i push on off its make a sound by buzzer ,,tut,,tut, (look like when we make a + & - to de buzzer by multitester)..... am very confused...need a big help..thanks...me email Manchestermu@yahoo.com with my pleasure need yr help.....big thankss...
toni
  • 1 more comment
  • toni one
    toni one Jan 22, 2008
    anyway Thank's Mr Turo, Abouting shorting i did cekhing before itsn't shorting at all.. its make me confused,... bout glass ic its same for all nokia phone right... its 5 x 5 Right. need your more info..im new player in a technician ,,,but i like to recover it hehe..goodday...thanks ya..
  • Anonymous Jul 25, 2008
    hi! im rommel, my problem is how can i find the trouble of 1100 not charging, i check already the fuse, diode, its good, where can i find it?
  • sujith153 Jul 30, 2008
    sir,,,..i also using n70 me.....and got the same problem...thats...one day it starts blinking....ie...that full white screen then normal display....then suddenly become white screen....in a continous manner......what's it.....?my frieng told me that its the problem of display ic....and i replaced it....but no change.....
    what is the problem of my phone......i expect i will get a good solution from here.....thank u....
  • 133 Answers
It looks that your N70 has a booting problem. Your phone wasn't booting. Usually the boot IC goes bad and needs t be replaced. You have complicated your problem by changing the glass IC's. This surely wasn't your problem. I'm not sure if you have replaced them correctly though. If you have a digital multimeter than check your phone across the battery terminals. Keep the meter on 'Continuity' which also shows a 'Diode' symbol and check ur phone .Between +ve to grnd, one side, the meter shd show around 370 ohms and reversing the polarity of the meter across the same terminals of the phone the meter shd show a reading similar to a capacitor discharge action towards infinity. Now if these readings do not show, then the phone has a 'shorting' somewhere. I suggest u take your phone to a technician he may be in a position to kick start it back to life.....................
Posted on Jan 20, 2008
  • Arturo D'Souza Feb 03, 2008
    I now understand wat u were talking abt, please keep in mind that not all Nokia handsets have the same Glass IC's also i hope u have fixed that IC's correctly......... i mean the notch on the IC shd be kept in mind........... if ur handset is booting then ur set is ok and it is only a display prob. N70 phones usually have this prob and in 90 percent of the cases the glass IC's are faulty. I wud suggest u take the help of the schematic diagram and check the tracks for continuity ...........
I have Nokia N70 complete working but display white screen. How can i do to solve this problem. Please help me with picture solution.
Phone imcoming - outgoing is ok. ringing is also ok. but display is only white. Please... please... help me.
Posted on Feb 09, 2009
2ry to reflow on display filterz it will work
Posted on Sep 20, 2008
N70 dead
Posted on Jul 02, 2008
My N70 shows white display but other activities it works properly. ones you disconnect the display and again reconnect the same, the display will work for 2 to 3 days and again same problem...
first format your phone by using this code
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
after this process the problem continuous , please check and change your mobile display with the help of an expert mechanic ,
most of the n70 users facing these problem
thank you
please rate me if my opinion helps you
Oct 18, 2010 | Nokia N70 Cellular Phone
Nokia N70 is display prb, white screen
The problem is inside the printer. Turn off the printer and open the replacement ink compartment- move the inks holder far to the left- use a torch to check where the inks holder home and you'll see that there is a sponge a tiny rectangular shape come loose -use the twiter and put back in place (holder).
http://www.fixyourownprinter.com/forums/inkjet/39177
Apr 28, 2010 | Nokia N70 Cellular Phone
Blank display, i can make and recieve calls but i'm not able to see my contacts,msg etc........
So if you have a blank display or just a white one, replacing the lcd screen should fix the problem.
See the link below for a guide on replacing the N70 lcd screen and links to buy a new one from ebay.
How to Replace the LCD Display Screen on Nokia N70
Oct 10, 2009 | Nokia N70 Cellular Phone
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
N70 DISPLAY IS BLANK/WHITE
Its a display IC fault.heres the screenshot..replace this two crystal IC for display.9323da0.jpg
Jul 21, 2009 | Nokia N70 Cellular Phone
Blank display
the LCD need replacing so take the phone to a mobile center and have them replaced it fopr you.
Jun 07, 2009 | Nokia N70 Cellular Phone
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
N70 comes on with whie screen and hangs
a lot tobe done in that problem of your... but i can give you one of the best... place yur unit in table so you can be cmfortable...the press all the keys in same time these keys are key *,key3,the call,and power on switch... much better if you had buddy beside you..to hold the unit... press them in same time or together, dont release it until you dont see a word formatting... wait until it finsih and the unit will be restarted by itself... enjoy
Nov 14, 2007 | Nokia N70 Cellular Phone
NOKIA LCD PROBLEM
first u need to tell are u getting calls even when the phone is blank.
Aug 09, 2007 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
1,142 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
