Question about GE GSS20IEP Side by Side Refrigerator
I accidentally short circuited the board on back & the guy wants 300.00$ to replace it
Am i getting ripped off?
  • 447 Answers
I do know that the board is $150 retail part. $150 labor is kinda steep, Id only charge 1hr @ $75/hr. Hope I helped.
Posted on Jan 18, 2008
Help, we accidentally hooked 24 volts. Now the power light doesn't come on but the trouble light does. Have I killed my amp or is it worth getting repaired?
Most 12 Volt Units have a Fuse built into them to protect the Circuit board from power surges or shorts if you can open it up and get to the circuit board inside look for a 12 Volt fuse mounted on the Board it should be located close to where the transformer is between there and the power source otherwise yes get a repairman to look at it. let me know how you went, Ron
Dec 14, 2017 | AMP Car Audio & Video
TV sound goes of after a short time
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Apr 15, 2016 | Hitachi P42H401 42 in. Plasma HDTV
Fuse 18 for dash lights keep blowing. Have replaced light switch and instrument cluster
If your fuse blows repeatedly, the circuit is drawing
too much current. Possible causes:
1) short in circuit... frayed wire, accidental circuit board contact with metal frame, solder bridge on circuit board, or wire placement/connection error
2) Too high voltage in circuit can cause excess current
drain
TROUBLE SHOOTING: measure circuit voltage w/ meter. If normal, put amp-meter (with fuse) in circuit
at problem fuse connector and quickly check current.
If very high, trace (look) along current path for location
of a short to ground/frame/etc.
Hope this helps...if this is all Greek, consider looking
for Better Bus. Bureau approved repair shop.
May 06, 2013 | Rotora 2003 DODGE RAM 1500 PICKUP...
Bowflex treadclimber has power but won't run
see the video and proceed with the test normal
After that you must see the diagram attached. and troubleshooting
However you can test the board by following this. a) test the input voltage motor, if there are Voltage the motor need repair b) test the output voltage board for input voltage board, if there are NOT voltage the board is faulty see the block diagram, and see my personal TIPS for motor help.
God bless you1_22_2013_6_06_13_pm.png1_22_2013_6_06_32_pm.jpg1_22_2013_6_06_44_pm.gif
Jan 21, 2013 | Bowflex Treadclimber
Tv turns on then clicks off by itself
Hello Steelworker, Hi, When the power switch is turn to ON then suddenly shut downs by itself, is a sign that the power supply board is in overload, the cause could be any shorted part on the main circuit board, a short regulator section on the power supply. a loose board, or foreign objects inside that shorts a circuit. There are no quick fix on this type of problem so my advice is let this TV be serviced by the repair shop. Common cause may be a shorted power board. Replacing the power board may OR may not solve the problem, this should be analyze first by tech guy. You can also inquire from your TV dealer for service.
Jan 14, 2011 | Mitsubishi Televison & Video
I have an Insignia NS-LCD32-09. When plugged in I get a red power light, when powered on I get a blue power light. The cable connection has been 'ripped' out of this set on accident. When turned on (blue...
Apr 29, 2017 | Insignia IS-LCDTV32 32 in. Television
The jack end of the ac adapter (plug into the
The jack has probably been ripped loose from the circuit board by repeated use over time. The jack must be de-soldered, then epoxy glued to the circuit board. Once the glue sets, the original connections need to be replaced with short sections of wire to bridge the broken portions of printed circuit. A relatively simple repair if done carefully. Hope this helps!
Apr 30, 2010 | Korg X50 61 Key Synthesizer Keyboard
Sony 52 Bravia XBR4-14months old,picture very white, ghosting
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Jun 24, 2017 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Toshiba TZ50V51 fix blinking red light
it took me a lot of time to understand the circuits on the toshiba they are not ease to fix but you may be able to get a tech for 300,00
Jul 20, 2008 | Toshiba TZ50V51 50" Rear Projection...
Subwoofer Module N-200 ( Nuance ) Short on circuit board
I'm working on a guys board looks like it is the Q10 and Q1 transistors I'll let you know how it goes.
Jan 05, 2008 | Audio Players & Recorders
GE GSS20IEP Side by Side Refrigerator Logo
76 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Joe Lamb
Joe Lamb
