Question about Avaya Magic Voice Mail Automated Attendant Greeting 407380153 Phone
Cant get auto attendant to turn off.
Can't get auto attendant to turn off.
What are you trying to do. It isnt that easy to turn the Auto Attendant partially off....
Posted on Jun 02, 2008
4 Suggested Answers
consultel1
  • 860 Answers
SOURCE: How to turn on/off AA Auto Attendant
feature 982 password:67372867, press next til you see answer lines:y, change to n, press release
Posted on Sep 02, 2009
  • 7 Answers
SOURCE: auto attendant
I was poking around on the web and found your question. I designed the SI-460 a few years back. Casio, sadly, shut down their phone division.
I can e-mail you the owners manual (PDF) if you need it.Anyway, in case you haven't figured it out:
To turn off the auto attendant:
Press the PROGRAM key.
the display will indicate:
PLEASE SELECT
PNON ANSW OTHER
Press the key under ANSW
The display will indicate:
AUTO ATTND: ON
BACK CHANGE NEXT
Press the key under CHANGE
AUTO ATTND:OFF
BACK CHANGE NEXT
Press the program key to end the process.
Good Luck.
Joseph Quevedo
joequevedo@charter.net
Posted on Mar 08, 2008
consultel1
  • 860 Answers
SOURCE: how can I switch the auto attendant service off so
Somewhere on your set theres probably a night key that was accidently pressed. It might or might not be marked as such,but there should be an indicator (triangle) on the screen that shows that its on. TO turn off press the night key again. The indicator should go off.
Posted on Jan 05, 2010
Turn off the auto attendant for the Nortel Phone System
Press the program key. The display will indicate:
PLEASE SELECT
PNON ANSW OTHER
Press the key under ANSW. The display will indicate:
AUTO ATTND: ON
BACK CHANGE NEXT
Press the key under CHANGE. The display will indicate:
AUTO ATTND:OFF
BACK CHANGE NEXT
That's it. Now press the program key to finish. If you need more detailed instructions, please follow the user manual: Nortel pdf manual
Oct 28, 2013 | Nortel Computers & Internet
How do you erase and change after hours greeting?dhalman
Call voicemail by pressing the Intercom button then dialing 777, when it answers login by dialing 99# followed by the password(default is 1234#) then press 9 for system features menu. Press 3 to choose Automated Attendant, the system prompts for the Auto Attendant number(1-4), start with Auto Attendant 1,if you do not know which one is being used by pressing 1. Press 2 to choose Night Menu, press 6 to change the Night Menu prompt. Lift the handset, press 1 to record your new Night Menu prompt using the handset, press 1 at the end of your recording. To listen to the new recording press 23, to immediately re-record press 21, to save the recording press *#. Press # to save all programming changes and activate new recording. Press *7 to return to system features menu or hang up to end programming session.
Changing the Auto Attendant prompt should be done when you are able to do a test call on each line to verify that you have changed the correct prompt(in your case after hours or by putting the system in After Hours mode manually to ensure the After Hours prompt is active) for each line being answered by the Auto Attendant. By default all lines are assigned to Auto Attendant 1, if your system has been modified to use a different Auto Attendant for some or all lines, you will need to repeat the above procedure for the Auto Attendant being used. If at any time you get lost or confused while in the voicemail programming, hang up and start over. Once you get comfortable with navigating the voicemail programming, it gets easier. If you have trouble send a comment, I will try to help.
Feb 10, 2011 | Lucent PARTNER18 Corded Phone
How can I switch the auto attendant service off so I can answer the phone before it goes to auto attendant?? I have a nortel T7316E. I was cleaning the phone and somehow turn on the auto attendant, but can...
Jan 04, 2010 | NorStar T7316E Corded Phone
CP100 Auto Attendant transfers direct to voicemail
The norstar extension may be setup up for Call Fwd to voicemail, or call fwd/busy. Also, Custom Call Routing may be setup to send the caller directly to the mailbox.
Nov 10, 2009 | NorStar CallPilot 100 Voice Mail, 10 mail...
Sep 01, 2009 | NorStar T7316E Corded Phone
Take auto attendant off lines
You need to go in to system admin of the phone system and remove the lines from preset forward that goes to voice mail group 440 or if it is set for delay remove preset forward destination.
Apr 20, 2009 | Vodavi Lands Phones
Auto attendant
In order to do that, you need to know which Auto Attendant you have. I'd recommend calling a Panasonic technician (you call them engineers).
Here's a manual just in case you what to take a whack at it.
http://www.lccuk.com/files/docs/manuals/ICX_Feature_Operation.pdf
Carl
Mar 23, 2009 | Panasonic Lands Phones
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
AUTO ATTENDANT NOT ANSWERING
There is about three to four programs that need to be set up in your phone system in order to do this , the program number my be a little different depending on the partner system you have .
Jan 19, 2009 | Lucent PARTNER18 Corded Phone
Auto attendant
PLEASE SELECT
PNON ANSW OTHER
AUTO ATTND: ON
BACK CHANGE NEXT
AUTO ATTND:OFF
BACK CHANGE NEXT
Good Luck.
Joseph Quevedo
Jan 17, 2008 | Casio SI-460 Corded Phone
Lands Phones Logo
1,080 people viewed this question
Top Avaya Lands Phones Experts
Oloyede Monsuru
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Avaya Lands Phone Expert? Answer questions, earn points and help others
