Question about Samsung 206BW Monitor
Language problem Hi...I wanted to fix the size of the display by using the monitor menu source etc buttons, now the whole instructions has turned into some other language. Wanted to get back to english.
    Master:
  • 619 Answers
Hi , open the control panel cleck regional and language option .
Posted on Jan 17, 2008
Best way to remove a parental lock from a lg plasma tv
LG Service Menu Instructions
Method 1
Press and Hold <OK> button on remote as well as TV panel at the same time for a few seconds.
Method 2
Press and hold the {MENU} button on the remote and the {MENU} button on the TV at the same time for at least 5-7 seconds.
Method 3
Press and hold the {MENU} button ON THE REMOTE until a 4-digit password screen is displayed.
LG Service Menu PIN/Password Codes
  • 8 7 4 1
  • 8 7 4 3
  • 7 7 7 7
  • 0 0 0 0
  • 8 8 7 8
  • 0 4 1 3
LG LCD Monitor Service Menu Instructions
  1. First turn off the lcd monitor, then press and hold the "MENU" button, then turn on the monitor. Release MENU button after the monitor is turn on.
  2. Press "MENU" button to open the OSD menu, at the bottom of menu, you can see a new selection to go into the factory service mode. Inside the factory service mode, you can see useful information like, product model, manufacturer date, F-ENGINE chipset version, lcd panel number and etc.
Mar 16, 2016 | LG Televison & Video
Need the operation manuel for my 22inch Gateway monitor can't change operating language
I have a smaller sized Gateway monitor than yours, but I'm sure the monitor buttons (on the front) perform the same functions on all sizes.
You should have eight control buttons on the front of the bezel (as listed from left to right): source, menu, down arrow, up arrow, left arrow, right arrow, auto/set, and on/off buttons.
Press the menu button, the first dialog screen that appears (at least on mine) is the brightness/contrast function. The screen will show the function to be changed, and a very small picture of what screen you have in view.
Once the first function is listed on the screen, press the down arrow to access the other screens (color, tracking and set-up), each having their own little picture indicating what screen you are looking at.
Brightness/contrast - picture of half light, half dark circle
color - RGB picture
tracking - two squares on top on one another slightly off center
set-up- hand pointing left
You want the set-up screen which shows a picture (I think) of a little hand pointing to the left. Once you are in the set-up screen, press the auto/set button and the first line will be highlighted (usually it is the language choice).
Once highlighted, press the right arrow button until your language name appears (i.e., English, Duetsch, Francais, Espanol Italiano, -there is no choice on mine for Japanese, etc.).
Press the menu button again and that should do it.
Feb 10, 2013 | Gateway HD2201 22" LCD Monitor
Osd volume control won't go away
bad switch i monitor.
fix switch
or new monitor.
its just a switch, it closes and OSD pops. on demand by said switch, OSD is a timing processor in the display that has the OSD code in it , "program"
Mar 25, 2017 | HP Computers & Internet
I my projector is new one used for 4 hrs, when i try to turn it on it just has a blinking green light. Please help Solve It! .
The blinking green light means the unit is either Powering On (Warming Up) or Powering Off (Cooling Down).
Powering On the Projector
1. Remove the lens cap.
2. Securely connect the power cord and signal cable. When connected, the ON/STANDBY LED will turn Amber.
3. Turn on the lamp by pressing " " button either on the top of the projector or on the remote. The ON/STANDBY LED will now turn Green. The startup screen will display in approximately 10 seconds. The first time you use the projector, you can select your preferred language from quick menu after the startup screen displays.
4. Turn on and connect the source that you want to display on the screen (computer, notebook, video player, etc). The projector will detect the source automatically. If not, push menu button and go to "SETUP". Make sure that the "Source Lock" has been set to "Off". If you connect multiple sources at the same time, press the "SOURCE" button on the control panel or direct source keys on the remote control to switch between inputs.
If you are still unable to get the unit to turn on, try unplugging it for 10 minutes and plugging it back in. If it still ceases to work, contact Optoma here: http://www.optomausa.com/rma_policy.asp
Their Technical Support line is 1-888-887-5001
Feb 25, 2011 | Optoma HD20 DLP Projector
Got moniter working but screen is too wide for monitor i have to usw cross arrows to read the whole page
Each monitor has settings buttons on the front or side of the monitor to set the screen size, brightness, etc. Look for a button or wheel and find the menu, then go find the screen sizing, but verticle and horizontal and move it so it fits the monitor screen.
Pushing buttons on the monitor will not cause any damage, so try then all until you find the menu button and then you will need to find the button or wheel that moves you from selection to selection. Generally, pushing the menu button will select the highlighted menu item so you can adjust the settings.
I hope this was helpful.
Brian
Dec 24, 2010 | Computers & Internet
My sons computer screen says OSD Lockout and mouse won't work
Take it to your dealer, he can do it without any problem.
Try this link:
http://www.fixya.com/support/r5393255-windows_password_recovery
Lost user password in XP with networking setup on HP
The best way to do this is using the Offline NT Password & Registry editor.
You can download it at the following link: http://pogostick.net/~pnh/ntpasswd/
This utility will enable you to reset the password of any user that has a valid (local) account on your Windows NT/2k/XP/Vista etc system.
The link above includes some directions on how to use this utility.
Oct 30, 2010 | HP Pavilion a1610n PC Desktop
Adjust monitor
hi, most monitors have between 4 buttons or 8 to udjust picture. the 4 button MENU, PLUS, MINUS, OFF. when the menu button is pushed the screen will show a list of COLOUR, BRIGHTNESS, CONTRAST, etc,etc the plus is pressed to change the COLOUR, BRIGHTNESS, etc,etc. if you need to change the SCREEN setting BECAUSE THE ICONS ARE TOO BIG click on START go up list to CONTROL PANEL go to DISPLAY click on this and go to SETTINGS click on this and on the left. change to 1024 by 768 SCREEN SIZE (COLOUR 256). press APPLY wait press OK. gerry
Sep 10, 2010 | Envision EN 9110 19" Flat Panel LCD...
Need a larger font size on aol
Hi there.
To enlarge the font on any webpage hold down the Ctrl key and use the + and - keys change the size of the font.
Good luck and thanks for choosing FixYa!!
Jun 08, 2009 | Dell Computers & Internet
Foreign language instructions
Hi Mike, I just answered your first post about this. Rate both a fixya and help me out. I appreciate it!
Hi, my name is Rob and I can help you. Do this:
While in live view, hit the menu/ok button.
Scroll to the right to the the icon with the wrench (set up menu).
Scroll down to Language and press the menu/ok button.
Use the directional button to highlight English then press the menu/ok button. Back out of the menu and there you go.
That will fix your problem. Thanks for coming to FixYa and don't forget to rate my answer a fixya again!
Rob
Feb 17, 2009 | HP Photosmart M425 Digital Camera
Horizontal view on screen will not re-center
You want to locate Position or Horiz Position from the Menu screen. Press menu first then Up or Down to select the item you want then Left or Right, I can't be more specific as all monitors are different - but there isn't a single button to center. You could also try the different input settings (Analog, Digital, etc) if the Autoselect isn't working properly.
Dec 12, 2008 | Computers & Internet
Samsung 206BW Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
