Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
Samsung rear projection tv have vertical black linens up and on tv
Vertical black lines on tv
  • Gene Thynge
    Gene Thynge Feb 09, 2008
    Thin black vertical lines, rows of 7 individual lines 9 vertical rows. I have a HL-P5663W
    President:
  • 4,402 Answers
You have a bad dmd module and it cost around $750-$800
Happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that.
Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulg all cables ( i think
3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
Posted on Jan 30, 2008
My samsung hl-r5087w has black verticle lines how do i fix that
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this will help to fix the fault, do take care in handling the solution
May 26, 2011 | Samsung HLR5087W 50" Rear Projection HDTV
Have thin vertical black lines accross the screen
You have a defective optical engine. The symptom usually shows lines separated by about an inch vertically across the screen. It may be worth your time to call Samsung consumer relations and see if they will incur some of the cost.
Bill W.
integrityhomeworx.com
Mar 09, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
I have a black line on the tv samsung
Hope this help......
Jun 22, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
My tv wont turn on the light on the power button blinks and the lamp turns on in the back but the screen dont light up
check if crt screen voltage correct (g2) try to adjust screen settings at flyback transformer and monitor if g2 response, some model if vertical ckt down monitor have black signal only can determine if screen adjustment knob in flyback transformer turn increase. vertical line appear.
Mar 26, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Faint vertical lines on my samsung lcd 1080
hi
this is the problem caused by 3 main issues
1.colour wheel
2.cathode ray tube
3.jungle ic on D-board
check it..//thank u
please rate it
Jul 04, 2009 | Samsung HL-P5063W 50" Rear Projection HDTV
Samsung DLP vertical black lines
I did some reading on this. They said its caused by a faulty DMD board. I understand it's costly... around $700 to replace. Still looking for a cheaper avenue...
Apr 28, 2008 | Samsung HL-P5063W 50" Rear Projection HDTV
Problem with the White vertical lines on Samsung 50 in DLP
Get DMD board part # and shop for best price.......
I will do the same......let me know.....T.
Nov 05, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Vertical black lines rear projection
Please provide exact model from back of tv........
Possible vertical IC circuit problem===bad caps? IC?
...........T.
Nov 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Vertical black line
does this verticl line go all the way form top to bottom or is it about 5-7 in long in the center of the screen and does it some times change in color with the picture.
Aug 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
180 people viewed this question
Jerry Greenberg
Jerry Greenberg
