The pink input jack is the microphone jack on most computers. The jack has 3 contacts on it One is for the microphone, one is ground and the third one is for the voltage applied to the microphone circuits. Easiest way is to get a headphone with a microphone on it . That way you won't get a squeal out of your speakers or an echo when using Skype.
Since the Headphone jack is soldered onto the motherboard in most cases you could remove it by unsodering it from the MB. However, replacing it might cause another issue. You can always install a sound card that would allow you to have additional headphone jacks.
Take it to the Service center. need to replace the headphone output connector's. these will happen from Moistor,Dirt block or Dry solder in the Laptop Motherboard. best of luck. ( Try, put headphone jack in and out for 20 to 30 times, or check the sound comes out via headphone, when pressing the connected jack.) best of luck
The reality is, Best Buy will only swap parts. there are other vendors on the internet that will replace discrete components. Google for "laptop power jack replacement" to find options. it takes decent skills to do this kind of repair, so research well.
This sounds like a problem with your connection for your headphones. Your headphone jack on your notebook is stereo, which means that you need stereo headphones to make it work. If you look at the tip of your plug on your headphone cord, it will have 1 black ring, or 2 black rings. 1 black ring is mono, 2 black rings is stereo.
If you are using stereo headphones, and you're still having this problem, your headphone plug is not going all the way into the jack on your notebook. Press the plug all the way into the jack and the problem should be fixed.
If you physically cannot push the plug all the way into the jack, there may be a problem with the jack on your notebook that will need to be looked at.
Hope this helps. Please take a moment to rate this solution. Thanks.
It sounds like you're asking whether headphones are necessary to the Skype experience.
You don't absolutely *need* headphones (or a microphone or a headset that has both), but if you don't use headphones, then your Mac external microphone might pick up the sound of your conversation and you might get unpleasant levels of feedback.
If this doesn't answer your question, please write back with the following information:
1. Your Skype version (click Skype --> About Skype) 2. Your model of Mac 3. Whether you are having problems with your audio - On Skype only? - On other applications? - In general? 4. Whether you have tried clicking on "Skype Test Call" - Whether you could hear the voice giving you instructions
most likely headphone jack is broken. option one is to take it to the apple store and have them repair it. option 2 is to go on e-bay and buy a replacement jack and try to do it yourself. best option is to sell it on ebay as broken/needs repair. Someone who knows how to fix them will buy it from you and you can use the money you get to buy a good used working iPod. There are always tons of nanos for sale on ebay.
