Question about Dell Latitude CP (0001849d-38380-968-p06e) LS-120 (SuperDisk) Drive
Need help it turs on fiine and says its opening windows 2000 but it doesnt it goes to a black screen .....
    Champion:
  • 217 Answers
Your boot record is corrupted. You'll want to boot to the Windows 2000 Recovery Console.
http://support.microsoft.com/kb/229716/
Try running the chkdsk /r command first. It may take about 30+mins to finish. If that doesn't get it, then you'll want to try fixing the boot record:
command-> FIXBOOT loadTOCNode(3, 'moreinformation'); fixboot drive name: Use this command (where drive name is the drive letter where the boot sector will be written) to write the new Windows boot sector code on the boot partition. This command fixes problems where the Windows boot sector is corrupted. The Emergency Repair process also fixes the boot sector. This command overrides the default of writing to the system boot partition.
command-> FIXMBR loadTOCNode(3, 'moreinformation'); fixmbr device name Use this command (where device name is an optional device name that specifies the device that needs a new MBR) to repair the master boot record (MBR) of the system partition. This command is used in scenarios where a virus has damaged the MBR and Windows cannot start.
WARNING: This command has the potential to damage your partition tables if a virus is present or a hardware problem exists. This command may lead to inaccessible partitions. Microsoft suggests running antivirus software before using this command.
The name can be obtained from the output of the map command. If this is left blank, the boot device's MBR is fixed, for example:
fixmbr \device\harddisk2 If Fixmbr detects an invalid or non-standard partition table signature, it prompts you for permission before rewriting the MBR.
Posted on Jan 28, 2008
Back passenger power window stopped working
I can help with a little testing. On the hinge side of rear passenger door, should be a wiring harness. Probably has a protective rubber boot covering, pull the covering back far enough to get at wire colors in the diagram. One wire is voltage the other is ground depending if the window is going up or down. Use a test lite to check. Key on, I would think.Your front passenger window works ok? If the wires check out good for voltage and ground, could be something wrong with window motor?
Oct 22, 2017 | Cars & Trucks
I have a ASUS x501A notebook and when i upgraded to windows 8.1 after restart it goes up to the logon screen where it says welcome Bobby and that circle keeps turning and then after that a bright black...
When you reboot the machine, keep pressing F8. this should give you a menu to boot into safe mode. when in safe mode you should have an option on the charms bar on the right to refresh your pc which will restore it to previous settings without losing your data.
Oct 26, 2013 | Asus Systems Asus X501A Notebook
Whats the problem when the computer boots the loading process bar of windows xp is displayed but as soon as the computer goes into windows xp the screen turs black and stays black
In this situation you need to do one solution to know the exact issue with you system, there are chance that your screen resolution has gone bad or your OS has gone corrupted. You must press f8 when your computer start's and then you must chose start with safe more or start with VGA mode. If you can see you desktop this time you need to adjust your computer's screen resolution as it's seem the problem with your screen resolution.
Apr 15, 2011 | HP LaserJet 1320 Printer
Black screen
If you have an onboard video card, that won't be enough to run the game. Try updating your graphics card. Here are the requirements to successfully run the game: suggested system requirements: Pentium III 1 GHz, 256 MB RAM, graphic card 32MB (GeForce 2 or better), 1.2 GB HDD, Windows 2000/XP
May 07, 2009 | EA Sports Cricket 07 for Windows
Msconfig won't work
If youre running windows 2000, it doesnt come with msconfig. For a missing msconfig in XP, download it from the internet, copy it to the C:/WINNT/SYSTEM32 folder. The version that works for windows 2000 will work for XP. DONT USE the 95, 98, ME version on 2000 or XP.
Mar 29, 2009 | HP Pavilion a450n PC Desktop
I cant get windows to connect on in seens stuck?
master boot record is damaged you need to format the drive
Mar 12, 2009 | HP Pavilion a1440n PC Desktop
I am having a problem with my compaq laptop,. when i turn it one its makes a clicking sound goes to start windows 2000 and then goes to a blue screen?
You will probably have to reinstall windows 2000. The problem is a corrupted file. Before you reinstall try rebooting pressing f8 at starting screen and then scroll to boot with last known good configuration. If this doesnt work then reinstall w2k with service pack 4 or upgrade to win xp service pack 3
Jan 01, 2009 | Computers & Internet
Windows vista error
what the status of your vista is it activated or not
Oct 04, 2008 | Packard Bell Easy One Silver 2120 Notebook
Computers & Internet Logo
138 people viewed this question
Alun Cox
