Question about Hitachi UX21511 Projector Lamp for 50V500
Pink spot in middle of Screen
When my screen goes blank between shows or the show is real dark you will see the pink circle in the middle of the screen...otherwise it is a great picture still and I have owned this tv forever....and nothing else has happened to it.
  • 2 more comments
  • Marquish Jan 18, 2008
    Right...if you look up 50V500A, its a Hitachi projection LCD....if its the lamp...I would say, hmm I kind of think its time...I have had the TV since Jan 2004. What do you need to know?
    so replacing the lamp will not help...or what...you were not specific in you answer...You did say it was repairable....do I need to get a repair person involved....what would the average cost of this repair....If its more than about $1000 then it would be cheaper just to buy a new one....wouldnt you think? Please be more specific on your "this is a repairable condition" statement.
    Thanks
    It doesnt, because I have contacted them and all I get is hmmm, that dont sound good....better call a repairman.
  • Marquish Jan 23, 2008
    I am getting a Large pink spot in the middle of my screen only when the picture is dark or shaded. Is that the lamp or another major issue? Please read my other posts. Thank you for your assistance.
  • 579 Answers
That model isn't known particularly for this, but on many other similar moels this would indicate a warped light engine causing distortions in the picture. It may be just starting to happen in your set and since it is caused by overheating of the plastic housing of the light engine ($$$) you should clean the filters of the ventilation fans and make sure it is getting cooled well. Also, projection lamps get hotter as they age so it may be part of the problem as well.
Posted on Jan 23, 2008
  • 64 Answers
Http://www.freelists.org/archives/techassist/11-2005/msg00917.html
The Problem has to do with the light engine and apparently its a known issue and I would contact Hitachi on this one. If you complain enough and play your cards right they might give you a new tv or repair it for free even if its out of warrenty.
http://206.53.239.180/archives/techassist/11-2005/msg00897.html
If you have a uniform pink hue on screen: turn television input to input channel that is not being used (should have a blank screen) shut tv off. Have television off for 2 minutes hold input button and turn on television. Let go of button after5 seconds. Television will have service menu on it. Hit menu on remote, this should bring you to 2nd page. Scroll down to Mem init box w/ remote. Hold joystick button to right til check mark is seen on square for mem init. Let go of joystick and this will re initialize memory. This fixed my pink hue issue and I did not need light engine. Remember to change your input to that of an unused one. Otherwise you will not be able to reinit memory.
    Scholar:
  • 128 Answers
Http://www.hitachi.com/GlobalSupport/ContactUs?form_type=global_support This is the hitachi support site. Hope this helps :)
Posted on Jan 18, 2008
I received the pink wand and although it does cover the dark circles under my eyes, it looks pink on my skin. Does this mean the yellow would have been more suitable? I have no idea how to tell if i am...
hi suzy! you can only tell what skin type you have.. if your problem is the dark circles under your eyes i suggest you to use MARY KAY TimeWise® Targeted-Action® Eye Revitalizer Diminish dark circles. Depuff under eyes. Discover real results. After just two weeks, 7 out of 10 women said their dark circles and undereye puffiness were less noticeable†. I hope it will help you. :-)
http://www.marykay.com/skincare/lipeyecare/10029737/10029737/default.aspx
Apr 29, 2011 | Secret Principal Reclaim Illuminating...
Pink screen abd pink lines everywhere
hi there.
for this, kindly check the BIOS mode of your machien first to know if the pink lines will still show there and if it still show then you may wanto contact your acer support to arrange a screen repair or replacment since issues like this are usually cause by dead pixels or display driver problem or display driver updates issues
you may use the given phone number below to contact the acer support if yoru screen shows the pink colors on BIOS so they can arrange a repair or screen replacment 800-816-2237
Feb 21, 2011 | Acer Aspire One Netbook 8.9" Notebook
The color on my tv is mostly pink. Is this
Try a reset to factory defaults. Show some image with lots of white. If it is still pink, it could be the backlights starting to fail. Or a circuit board. To be sure, you would have to disconnect the LCD panel from the board and turn on the set so that you have a blank white screen....with no signal. A pink screen, backlights are bad.
Apr 23, 2010 | Insignia IS-LCDTV32 32 in. Television
Tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Oct 14, 2009 | Televison & Video
Pink spots on screen sony wega 42" reaprojection tv
This TV has a known problem with the optical Block. Please call Sony Customer Relation and ***** them until they send someone to replace the optical block
Jan 03, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony kf50we610 hd pink stripes
That's a good one!
If you're using component video cables, make sure they are good and tight. If it's composite video or S-video inputs, you will likely need service.
Sep 12, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Pink cloud covering most of the screen
If the pink spot appears as mostly a circle in the middle if the screen then a light engine is needed. If it is an even coverage than possibly just a memory initilization needed by a technician.
Jan 13, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
364 people viewed this question
Top Hitachi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Hitachi Office Equipment and Supply Expert? Answer questions, earn points and help others
