FixYa.com
Tags:
Panasonic Workio DP-3520 Copier
Scanning
posted by SJGonzalez on Jan 17, 2008
First of all, good morning/afternoon, is there any charge for this service?
Comment by SJGonzalez, posted on Jan 17, 2008
on a DP-3520 how can I change the settings of the machine when scanning a bunch of documents and create single pdf file for each one of them using the feeder instead of manually create them.
Thank you
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Jan 18, 2008
Thanks for Trying (70)
CopierITWiz
Rank:Master Master
Rating: 86%, 14 votes
There should be a setting for this in your machines web interface under scanning>Scan settings>and then file format i believe.
Rating Locked! (?) SJGonzalez has rated this solution as Thanks for Trying
Can you Help with these Copiers problems?
Copiers
changing defuser drive gear on...
a spring was laying inside the... Answer This...
Copiers
Scanner Fault
When I power up, the machine... Answer This...
Copiers
Document Feed
Please help, my Panasonic... Answer This...
Copiers
minolta
minolta ep 1030 copier paper... Answer This...
E03-40 error code
I keep getting this error code... Answer This...
Repair Service
Find Copier Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
