Question about Indesit WA 125 Front Load Washer
Indesit WDL 126 dryer does not work
The wash cycle works fine but when i try to tumbne dry the clothes, they are more wet than when the wash cycle completed.
  • 2 more comments
  • pesguru Jan 27, 2008
    same machine...both dryer settings make clothes wetter than when they went in..sometmes literally soaking..but washer is ok.
    took out the filter,lots of water comes out which i dont think is right,as the towel gets soaked to absorb the water and the floor has a big puddle..not even 2 years old.
  • habba Feb 10, 2008
    Same problem also with my WIDL126 - after drying cycle all laundy is hot and moist. Also I noticed some of the drying programs take a lot longer than normal...
  • mark_tuhoe May 24, 2008
    Yeah I have the same problem with the WIDL 106, anyone found a solution yet? Its really annoying.
  • cathwim Aug 31, 2008
    Yes, we have the same problem, have had this machine only a few weeks. Even on synthetic cycle, clothes are so hot you can burn your fingers. Hot and wetter than when they went in. Did anyone contact Indesit about this?
    Not fit for purpose.
5 Suggested Answers
SOURCE: dryer won't dry
www.malberusa.com
61 Commercial Ave
Garden City, NY 11530
(516) 294-6660
first empty the waste container on the right buttom of your machine you have to empty that container every couple of washes.if not solved replace the heating element. the tel # above.
good luck
Hadi
Posted on Oct 01, 2008
meBNme
  • 334 Answers
SOURCE: My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
Posted on Sep 26, 2009
jyackle5
  • 8197 Answers
SOURCE: indesit widl 126 stopped mid
Sounds like your transmition is bad on the washing machine. Replace the transmition. You will need to call a repair man out to fix
Posted on Dec 09, 2010
heatman101
  • 43501 Answers
SOURCE: Indesit WDL 126 dryer -
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Feb 11, 2011
Have a WDL540 can you explain the symbols on the right hand side of the machine has mins and other symbols. Don't have an instruction book. A wash takes 2 hours at 40 degrees its too long.
Do you mean a Hotpoint Aquarius WDL 540 washer? The wash cycle timing is available in the manual on page 8 of the manual (see link below). A normal-sized cottons wash at 40 degrees C takes about 150 minutes (2 1/5 hours) if you have good water pressure and do not use too much detergent. The coloreds cycle is shorter (just under 90 minutes). The indicator lights on the very right hand side (in a downward slash pattern) give the cycle status information. The top light is wash, and the next one down is rinse. The rest are Spin, Dry and End of Cycle. See page 7 of the manual. The function buttons, below the wash temperature and drying time/humidity selection knobs, are from left to right: Super Wash, Extra Rinse, Mini Load, Slow Spin. These are given on page 9. The dryer dial gives you the choice of selecting a dry time from 40-180 minutes or by humidity. The humidity options are Iron (leaves clothes slightly damp), Hanger (ready to put away) and Cupboard (to dry heavy items like towels to a very dry stage). Note the dryer can't manage as large a load as the washer function does. You may need to split the load after doing the wash.
The manual for the WDL 540 is available on the product page: https://www.hotpoint.co.uk/appliances-1/washer-dryers-3/hotpoint-aquarius-wdl-540-p-.c-washer-dryer-white/F064656/ . The picture of the washer shows the function buttons when you zoom in on the control panel. The direct link to the manual is http://docs.hotpoint.eu/_doc/19512781900_GB.pdf .
I hope this helps.
Feb 02, 2018 | Washing Machines
Hi We have a miele condensor dryer. It is working fine except that you have to put clothes through twice to dry. It seems to cut short the drying process and then you need to put the machine back on...
The first thing you need to check is your vent system. If your dryer vent is clogged with lint, the dryer has a hard time expelling the moisture.
Then, if the vent is clean, try using a timed drying cycle instead of a sensor cycle. If your clothes get dry using the timed cycle, then you might have a sensor problem.
Also, make sure your wash machine is properly spinning out the clothes. I saw that once before where the customer thought the problem was with the dryer, but it ended up being their wash machine's ATC switch adding water at the end of the spin cycle.
Nov 01, 2014 | Dryers
Indesit WDL 126 dryer - at end of cycle not draining or spining
heatman101
Feb 11, 2011 | Indesit WA 125 Front Load Washer
I have an indesit widxl146 washer drier and the machine takes an age to dry clothes, 9 hours as oppose to 2 hours when new
9 Hours!!! I hope it isn't because the clothes are too wet because if it is I wouldn't like your electricity bill!!
There are a number of things you need to check.
I assume that you are not overloading the machine, and that you are using the correct spin cycle
Don't start the drying cycle directly after the wash, take out the clothes and see how dry they are after the wash, you need to ascertain if it is spinning the load sufficiently fast to dry them. How dry are they directly after the spin? If they are not wetter than they should be then the dryer is not getting hot enough during the drying cycle, this could be due to a faulty thermostat or element.
Make sure all the filters are clean including the pre chamber down below so that it can pump out the water (I guess it must be clear if it is washing ok? but check anyway.
The principal parts involved, assuming that
Also check that you haven't got a delay set for the dryer (unlikely I know but I thought I would mention it anyway)
I hope that helps.
Jan 26, 2011 | Indesit Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Washer/Dryer not drying
is your dryer a conderser type
does it have a tank that you have to empty at the end of cycles
if it does the filter that condensers the water from drying cycle
if that is blocked it will not work
Jan 25, 2008 | Equator EZ 3710 Front Load Washer / Dryer
Indesit WA 125 Front Load Washer Logo
303 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
