Question about Microsoft Xbox 360 Console
Red light on startup
On startup wether using the console button or controller button 3/5 seconds later, where the green light should be it goes completely red
Usually When You Get Four Red Rings Of Death All Cables Are Not Conected Or Maybe Broken Test It On A Diffrent Tv And Diffrent Power Plug Socket Any Way Thats All I Can Think ....
Posted on Apr 03, 2008
  • 4 Answers
How many red lights do you see around the ring of light? there are actually four quadrants around the power button representing the four controller positions and when it flashes red there are different issues allocated for different number of quadrants that are lighting up red.
[b]one red light (E67,68,69)[/b] - there might be a problem with the hard drive. turn off the console, remove the hard drive and turn on the console without the hard drive. if the 360 works without the HDD attached there is a problem with the hard drive
[b]one red light (E71, 74, 79)[/b] - console is experiencing a hardware failure. disconnect all cables or wires from the console and also remove the hard drive. re-attach the cables or wires and torn on the console without any HDD or memory unit and if the same issue occurs your console is having a hardware failure and you need to send the console for repair.
[b]two red lights (no error message)[/b] - the console is overheating. try to cool down the console for a few hours. if the console is still experiencing the issue check the fan at the back if it blows out air. if the fan is not working or if the console is still experiencing the issue after cooling down the console you need to send it to the service center of microsoft for repair
[b]three red lights (no error message)[/b] - two reasons for the red lights: hardware failure or power supply unit failure. when the three red lights is showing check the light on the power supply unit. if the light is green you console is experiencing a hardware failure. if the light is orange, red or no light at all, there might be a problem with the power supply unit. disconnect and reconnect the power cables from the 360 and reconnect them again. if there is an inter-cooler connected at the back of the console, remove the inter-cooler and turn on the console without the inter-cooler. try also a different wall socket and if the light on the power supply is still orange, red, or no light when you turn on the console you need to replace the power supply unit.
[b]four red lights (no error message)[/b] - it just means that the console does not detect the AV cable or the AV cable is not connected to the console. try to wipe the metal area around the AV connector and reconnect it again.
Posted on Jan 18, 2008
    Problem Solver:
This happened to me 2 or 3 times.I checked the power supply and found that it was loose(the one in the back of the actual 360 console)when I pushed it in properly,is worked fine,i have not got this problem at all since then.So just make sure the power supply is properly connected.
Posted on Jan 17, 2008
6ya staff
SOURCE:
When i turn my PS3 on the light goes from red to green but nothing else happens, the discs load and eject thats it. You cannot turn the system off without turning the power off at the wall.
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
Hi my playstation 3 has red power light when you plugin when you push power button it goes green for about 3 seconds then goes red again and will not power up do you have any solutions Thanks Anthony
Yes this is internal overheating you can fix this by using a good guide or you can send it in and they will fix it for you.
If you send it in it will cost about $150 to fix.
Or you can fix it from home.
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: Whe i touch the red startup button it beeps and tu...
you got a YLOD yellow light of death when you get a yellow light briefly and then the red lights start blinking, you need to reflux the solder on the processors and apply heat to them, here is a link on how to do the repair, if you are not good at doing these kind of work, I would suggest taking it to a pro.
http://www.youtube.com/watch?v=XIm0Qk0CVTE&feature=related
May 17, 2010 | Sony Playstation 3 (PS3) Console
My ps3 it goes green beeps twice then goes red and flashes on/off
you might be holding the power on button to long. you hold the power on button until it beeps to reset the video output. try turning it on by using your controller. just press the ps3 button and if the red light is on then it should come on.
Oct 14, 2009 | Sony Playstation 3 (PS3) Console
Wii Console will not turn off. After pressing the Power off button the console light goes from green to yellow (not red.) After about 5-10 minutes the blue light will start to cycle on and off and the game...
try turning it off on the console and not with the controller. turning it off with controller turns it yellow. press and hold the power button on console for 5 seconds it should turn red.
Jun 30, 2009 | Nintendo Wii Console
Power Problem
your ps3 is dead this si similar to the xbox360 red ring of dead some ps3's can be fixed some not there is a guy on ebay who does this type of job go to ebay and enter the world ps3 reflow and you will see like 2 diferent guys there
May 12, 2009 | Video Game Consoles & Games
Microsoft Xbox 360 Console Logo
201 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Ekse
Nathan Hamilton
Nathan Hamilton
Paul Castley
Paul Castley
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
