Question about Hoover Washing Machines
Hoover washer Artisan model Cycle stops pump keeps running
Hoover washer Artisan model Cycle stops and water pump keeps running but no water in machine as none comes out with the discharge hose is put at ground level.
Cleaned pressure chamber and sensing line to water level controler ....Still the same fault........New level switch?????
Thanks
Jerry
  • 1462 Answers
SOURCE: hoover washing machine top load, model 550m.5.5kg
water leak from cold hose nothing to do with other problem. tighten hose connection and fit a new hose washer overfilling probably because air chamber blocked. remove lid. you will see a pressurestat somewhere at the top - usually round with anything from 3 to 7 wires and a small tube underneath. follow hose down and it connects to the air chamber. make sure this is free of gung and check hose for splits and has no blockage. to check the pressure stat itself, attach your own hose to the stat and while machine in fill mode, blow down this hose and you should hear a click and water intake will stop
Posted on May 04, 2007
  • 249 Answers
SOURCE: Water fill level is incorrect, probably faulty pressure switch.
don't touch the screws 0872465395 Ire
Posted on Dec 30, 2007
Krazytech
  • 725 Answers
SOURCE: I have a whirlpool front load washing machine model WFW8300SW00
Hay Crab.
what I have found is that the washer thinks it is not pumping out .. if your drain pump is clearly removing the all the water in a good time... then the problem is your pressure switch...it is telling the computer that it still has water in the machine...
replace the pressure switch and it will solve your f21 error.
It is a round unit on the right hand side on top...with a tube and wires going to it...let me know if it helps
Posted on Apr 05, 2008
part No: 47841-405 hoover washing machine
Posted on Aug 31, 2008
SOURCE: Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Posted on Feb 14, 2009
Cold water won't stop before rinse cycle
if it fails to stop running only at the rinse part of the cycle it is probably in the timer as the solenoid valve has to cut the water off when the washer fills for the wash cycle too. fills for wash cycle and cuts off water, washes and drains, refills for rinse cycle and water just keeps running? does this every time you run it? that's in the timer. bad solenoid (water inlet valve) would keep running even on wash fill up. hope this helps.
Feb 25, 2014 | LG WM2688H Front Load Washer
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
The water does not get pumped out of the machine
The filter is to be found at the bottom front left of washer behind a removeable plastic trim, if you can see a screw in the filter cover, undo this, and turn filter anticlockwise to remove.
If no filter at front, then remove rear panel of washer, and remove large black hose fastened to drum, check for blockage here, and check the pump at the same time.
Thanks
.Please rate my solution;
Nov 08, 2009 | Hoover AAA160 Front Load Washer
Machine not draining
Can you hear the pump running just before the spin cycle, if so then I suspect a blockage in the filter or pump hose, If not and machine is quiet then it could be a faulty water pump or PCB board and you would have to call a technician.
Apr 13, 2009 | Hoover Nextra HNF 2137 Front Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
HOOVER LOGIC 1300
you need to access your drain pump and check it for an obstruction but when you pull the hose off keep in mind it might have a lot of water in it i usually use a shop vac and pull all the water out through the drain hose before removing the hose or opening the pump sorry i cant be more specific but ive never cleaned the pump on a hoover
Mar 23, 2008 | Hoover AAA140 Front Load Washer
My Hoover Model Not listed/stops during the cycle
the cycle timer is beginning to sieze because it needs oil. disassemble washer to the point where you can apply small drops of 30W machine oil to the timer's bearings
May 20, 2007 | Hoover HTC243 Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
