Question about Jenn-Air JED8430 Electric Cooktop
Electrical wiring there are 4 wires coming from the cooktop and only 3 coming from my breaker box. not sure where to connect the red wire from cooktop. have black, white and green from breaker.
  • sonnyb Jan 20, 2008
    still not sure which wire to connect to which wire. can't find anything in the manual about wiring. black goes to black white to white and red to what?
    still not sure what you are saying. The wires from the breaker are actually black white and copper. Does white go to white, black to black and that leaves red to go where? Also is the green the ground wire? thanks for trying to help.
    Genius:
  • 1,067 Answers
Ones connecting to anther set of plugs red on postive top countuins sending power to next box in a chain
Posted on Jan 19, 2008
  • 7 more comments
  • nick helpap
    nick helpap Jan 19, 2008
    green u can leave hanging red main power
  • nick helpap
    The old wiring had 2 hots and a ground. The cooktop requires, 2 hots, a ground and a neutral. The old wire has no neutral
    You still may be able to use the new top with old wire but you would need to check the owners manual and see if you can use the equipment ground(bare) as a neutral. Some models allow this, some don't. It should be in the manual somewhere if you can use the 3 wire feed and how to wire it up. If it isn't in the manual, a call to the Jenn-Air company would be a good idea. I'm sure they get this question a lot as all the old cooktops used 3 wires, and the new ones use 4
  • nick helpap
    u need # ?
  • nick helpap
    did that help dont forget to rate it
  • nick helpap
    nick helpap Jan 20, 2008
    red should be hot 2 hots it takes
  • nick helpap
    im not sure on that model i could try to call them monday am for u fnd oout n that model or u wantt ther #
  • nick helpap
    Your 1992 home...if it passed inspection - clearly has a bare grounding conductor in all circuits...( so for this circuit from your panel - you see a black, red, white and bare ground supply coming to the cooktop)..and this stovetop MUST be grounded. Based on your description - the new unit does NOT require a neutral wire and runs strictly on straight 240 volts ( red and black hots only). The branch circuit box white neutral will NOT be used and should be capped off with an appropriate sized wirenut. However...the branch circuit box bare ground wire MUST be connected to the bare ground of the cooktop.
    Yes...it makes a difference. What has changed over the years in this requirement is now ALL of these appliances must be supplied with a ground. (decades ago a simple 3 wire connection - having only a black, red, and white could have been used....but under today's Code - a bare grounding conductor must now be used...the white can no longer serve as a ground [because it ISN'T]...) The wire decription has changed from terms like requires 8/3 to requires 8/3 with ground.
    The same holds true for stoves and dryers....a 3 wire with ground (sometimes mistakenly called 4 wire) must be run to all these new 240 volt appliances. If they are cord and plug connected...the plug and receptacle MUST now be 4 prong....so that the bare ground is utilized. This is mandatory in new construction...but some older homes and local inspectors allow grandfathering and let this requirement slide....if the home didn't have 3 wire with ground ran to the location (and they allow the white to serve as ground under those circumstances). ALL new homes must now have this ground wire.
    In your installation...the red to red, black to black, white capped off....and bare ground of unit to bare ground of circuit supply.
    The Code now requires that manufacturers now clearly state this on all 240 volt appliances...but some manufacturers do not make it very clear in the way they word it....as you've found out.
  • nick helpap
    http://www.amana.com/assets//amana/pdfs/...
    cheak outthis link shows wireing for u also sum models u can switch over to 120 from 240 in manel
  • nick helpap
    di that help u shows a pic on a 3 wire set up sumtimes these stoves come with a switch to go 3 wires
Maytag cook top Model # CSE 9000 ADB. A red, black, blue, yellow, white, and bare copper wire come out of the unit. How do I hook it up???
each colored wire is for a seperate burner, the white wire connects to the white neutral wire the bare wire connects to the ground the red and yellow wires connect to the red wire (L1) and the black and blue wires connect to the black wire (L2). i have the same model and i connected mine this way and it's working fine. mine is also connected in a box that has a seperate fuze for each burner so you can follow the red (L1) wires to the 2 fuzes and connect your red and yellow wires to these fuzes and the follow the black (L2) wire to it's 2 fuzes and connect your black and blue wires to these fuzes. i don't know if this box is necessary or ir you can just connect directly to the wiresin a regular box and rely on the breaker but it was already there from the old cooktop i replaced so i used it. hope this helps you
Jan 07, 2011 | Maytag 30 in. CSE9000 Electric Cooktop
Hello: I am trying to replace a cooktop (installing a used cooktop - GE model# J P651 002 AD). My problem is making sure I understand the wiring connections. The cooktop has a black, a red, and a green...
The green goes to the bare ONLY.
Likely the black was used as a neutral and the reds were 240 volts.
You need to investigate at your panel. If you see the black going to the neutral bar, abandon it by capping with wire nut. If you see both the reds going to adjacent terminals on a double breaker, connect one red to the red and the other red to the black of the cooktop,
Oct 07, 2009 | GE 30 in. JP328 Electric Cooktop
Whirlpool Electric Cooktop Wiring
sound like you have a three wire setup on you house most commonly the black wire is the L1 wire or one of the hot wires and the red is the L2 wire and is also one of the hot wire in this instance your white wire would be your neutral/ground wire this would connect to the copper wire on your cook top depending on the model it would have a red wire a black wire and the copper wire but some may also have a white wire also if this is the case on a three wire setup you would attach the copper and white wires together also if needed you can goto the maufactures website and download an instalation guide.
Mar 25, 2009 | Whirlpool GJC3034 Electric Cooktop
I need tio hook up a 4 wire cooktop(Bl R, W, Gr/copper to a 3 wire boat(Bl-L1, W-L2 and Gr) Can anyone help?
hi my name is mark, you need to check local electrical code before wiring cooktop. if it is allowed the white and ground/copper can be tied together with green from house. but if not allowed you will have to run a seperate white wire or new 8ga 3 wire/ with ground from breaker box. check the code first. and shut off power before you wire cooktop. thanks for your question.
Mar 13, 2009 | KitchenAid 36 in. KECC568 Electric Cooktop
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
GE electric cooktop
Try looking at the junction box that it is connected to. Maybe one or more of the wires have burned off or come loose from the wire nuts. How many amps is the breaker? Most electric codes require separate circuits (Breakers) for each appliance. First turn off the breaker. There should be an outlet box of some kind on the wall or behind the cabinet. Follow the wire from the cooktop and see where it goes. Open it up and check if any wires are burnt or loose. If it was installed wrong I would change it. Most cooktops shouldn't be fused at more than 30 amps. Single ovens the same, double ovens up to 45 amps. The problem is if they used an old range outlet with 6 gauge wire and tried to connect both appliances to the same wire. This is hard to do without it coming loose.
Jun 10, 2008 | GE 30 in. JP326 Electric Cooktop
Stovetop 3 wires to wall 4 wires
I'm assuming this is a 220/240v unit. The wall has two blacks, each with reference to white is 120v. Since you need 240 volts, you need to use both blacks. The third wire you'll need is ground. ALWAYS make sure you use a ground wire!!
Realistically, the white is connected to the Ground terminal in your circuit breaker box. Best practice says cap off the white, and use the GROUND.
Mar 08, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric wiring confusion
On Cooktop From Box
Black to Black
Red to Black w/red stripe
White to Ground
Green to Cooktop frame
Nov 16, 2007 | Jenn-Air JED8430 Electric Cooktop
Wiring installation
You do need a 208/240 volt supply from your service panel. The green is ground, white is nuetral, and the red and black should measure 120 volts each to ground or 240/208 between each other. It is normal for most breaker panels to supply 208/240 between adjacent insulators. If you are only getting 1/2 of that then the circuit breaker may not be straddling the insulator bar but be 1/2 notch out and both breaker pins contacting the same 110 supply.
Apr 14, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JED8430 Electric Cooktop Logo
185 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
