Question about Acer AL1717 17" LCD Monitor
Acer al1717 power light never comes on
Bad swicth? How do I open up the monitor? Where are the screws?
Richard Brown
The front of the case snaps into and out of the back half of the case. Shove screwdriver along any edge so that a snap is heard indicating the the tabs/case halves are seperating. The through the whole thing into the dump as the electronics are probably
Posted on Apr 16, 2008
Test
Posted on Apr 02, 2008
Why in my Acer monitor AL1717 comes vertical lines in middle of the screen ?
Try updating your display driver and also try with another monitor cable, in case its broken.
Apr 28, 2014 | Acer AL1717 17" LCD Monitor
I turn it on and it comes on screen goes black and it comes on again and goes black again
You should try it on another PC first to make sure it is not the PC video card problem.
Common problem with LCD monitors is due to bad DC filter caps in the power supply section as you can see here:
http://s807.photobucket.com/albums/yy352/budm/ACER/
There are more than one version of the AL1717 as you can see in my ACER album.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 24, 2011 | Acer AL1717 17" LCD Monitor
Acer AL1717 HAS POWER COMES ON DISPLAYS FAINTLY GOES ON STANDBY AFTER 5SECONDS
Check th caps in the power supplyinverter board for bulging top or bottom seal.
There are more than one version of the 1717 as you can see here:
Post back what you find.
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Oct 13, 2011 | Acer AL1717 17" LCD Monitor
Acer al1717 comes on after 5secs goes off and there is afaint display on the screen
Take your monitor apart stand first then your front basil then remove your back .
on your power board check to see if any of the capacitors have tops that are bulged . if so replace them . I have alot of flat screens that i get and out of the last 20 ive received some are ACERs some are HP one was even an old Zeos and I have got 16 out of the 20 up just by replaceing voltage regulats and Capacitors .
I didsnt plan on starting another computer shop but I live in a Moble home park and It seems word of mouth is the best advertiseing because every time a puter or monitor takes a dump I end up fixing it .Richard
Screen turns on, but after a minute or so goes black. The power light stays green. If you shut off the power and turn it back on, the screen comes on for a minute, then goes black.
Check the power supply caps.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
Oct 14, 2010 | Acer AL1717 17" LCD Monitor
MY Acer AL1717 was shuting down but the CPU is already open How to do this my acer
The prblem will more likely to be caused by bad capacitors in the power supply, look inside for caps with bulging tops or seals, post bakc what you see so we can guide you further, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 12, 2010 | Acer AL1717 (Silver) 17 inch LCD Monitor
Acer AL1717 no power indication, AC is present on the plug.
You need to open it up and check the fuse first, then look to see if any cpas have bulging tops or leaking liquid. Post back what you see inside so we can help you more, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 03, 2010 | Acer AL1916W 19" LCD Monitor
Power problem
low power consubtion first on ur moniter then cpu
Jun 19, 2009 | Acer AL1717 17" LCD Monitor
LCD Monitor
1st remove the base cover by by squeezing to release the clips and remove the 6 base mounting screws. 2nd remove the 5 screws in the back cover. 3rd push and pry at the parting line to release the clips. 4th remove the base mount by removing the two attaching screws and sliding it down about a quarter inch. 5th remove the steel cover by removing the 4 wires, two screws from power outlet, two bolts from vga plug, and the other screw in the cover. and there you have it.
Oct 26, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 Back Panel Open Screws
Taking monitors apart can be a pain and tough.
I do quite a few and some are really rough to unsnap !!
Remove the stand and cords.
Remove all rear screws.
Then the hard part is unsnapping the trim from the case without using a crow bar or breaking it.
Start at the bottom first that way if you leave a couple marks they are not so visible. You'll need something thin with a beveled edge to slip between the two plastic parts to release the catches as you rock the trim back and forth from the screen.
(the edge of a pocket knife works- a credit card can have an edge sharpened with a file- sometimes real good fingernails work)
ebaysbammbammfran
Oct 12, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1717 17" LCD Monitor Logo
238 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
