When you hooked it up you didn't hook up the right wires because there is 12volt constant wire that keeps the unit to save things so when you turn it off it's not getting any power at all so it just resets
Press the [MENU] button for at least one second. Push the control knob toward [AM] or [FM] to select "DEMO." Press the control knob for two seconds to alternate between "DEMO ON" and "DEMO OFF."
If you need a manual you may download a copy here.
Cancelling the DEMO MODE is explained on page 29... as follows....
Select the Demonstration mode
Push the Control knob to [FM] or [AM].
Select the "DEMO" display.
Set the Demonstration mode
Press the Control knob for at least 2 seconds.
Each time the knob is pressed at least 2 seconds,
the Demonstration mode switches "on" or "off"
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
To turn OFF DEMO mode - go to page 50 of the manual.... and find the following-
1 Select the Demonstration mode
Select the "DEMO Mode" display.
2 Set the Demonstration mode
the Demonstration mode switches as shown
below.
Demo Mode "ON"
Demo Mode "OFF"
To turn off demo mode. Hold down the src button and hit the reset button and release it. Continue holding down the src button until the system is fully rebooted. You will then be able to eject your cd and it will be out of demo mode. Came from Kenwood tech support.
Turn the unit onto standby then press and hold the menu button then scroll down to demo using the toggle switch on the right then press and hold the toggle switch for a few seconds and it will change to demo off. It's not too difficult but you are correct, it doesn't tell you correctly in the installation instructions.
There is often confusion in the way the manual states how to achieve removing demo mode. Because this is listed in the "Menu System" section of the manual and assumes you read from page 1 of the manual that you will know to enter the menu in this section of the manual. Here is step by step instructions on removing demo mode on your unit.
1. Go to standby mode
2. Press and hold the menu button till the menu comes up
3. Press control knob towards AM or FM to scroll through menu till you locate "Demo On"
4. Press control knob straight in for approximately 3 seconds till it switches to "Demo Off"
5. Hit menu button again to exit menu
