My maytag atlantis won't spin just makes noise
i have a maytag washer that won't spin, it just makes noise. the last time this happened, i found the belt on the floor under the washer. i replaced it and it'd been working fine until about last week. now it's doing the same thing, but the belt is still on the pulley's. i can spin the tub, and i can turn the belt and move the pulley's.
can you please help me with this problem, my kids cloths need to be washed.
The transmission has a very poorly made gear with 2 tabs on it in center- botton of the transmission inside these tabs break off then it won't spin, i got 2 0f them here now and no part to fix them with , Maytag should made supply the part to fix it with, they want to sell you a whole transmission at better that 200.00 , Jimmy T.
Posted on Jan 17, 2008
Maytag Atlantis washer. Washer makes noise that approaches grinding, and the agitator doesn't spin. Rather, isn't connected to the motor. Spins semi-freely by hand, with a rough motion and noise
Your unit is gear driven and is contained in a mechanism enclosure.The roughness your feeling when turning it are the worn-out gears.One cause is it might have ran out or dried out of gear lubricant.The motor drives a belt to run the gears so the motors are running fine.Your gear box is the problem.
Dec 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My MayTag Atlantis washer will not spin or drain the water out, when it gets to the rinse cycle or spin cycle , it just makes a buzzing or clicking noise.
The brake mechanism is not releasing properly. The noise your hearing is the motor trying to move but can't. Do not continue to operate the washer or you will burn out the motor...an expensive replacement. See instructions for my other solutions.
Sep 23, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Oct 11, 2009 | Maytag Atlantis MAV6000 Top Load Washer
In spin cycle machine makes squeaky noise.
Your bearings could be going out, causing excess stress on the belt. Take the back off of the washer and check the belt tension. If there IS something stuck back there, you'll be able to see it.
May 21, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Atlantis won't agitate. Will spin.
hi thanks for the question if it was making a high pitch noise that's the transmission buy new washer but not a maytag a roper is good same ae kenmore thanks the appliance doc
Jul 23, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag MAV6257AWW Washer
Could you describe the noise you are hearing. This will help to determine what to look for.
Jan 13, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
