KENWOOD KA-691 AMP. HOOKUP
I have a amp & would like to hook up tv, casette deck, equalizer, dvd , vcr & cd player to it w/o a manual it's not coming togeather?
    Genius:
  • 1,067 Answers
Ok well rca cables does your amp have all the inputs u need video 1 2 tv cd dvd ect run casete deck play out to tape in on amp cd to cd dvd to dvd rca cables unless u use coxail digital ok now the eq only has 1 in put unless u wann run itthrow a pre amp out and in if amp has that sum dont if not pick 1 or 2 to run into eq on ther own chs then back out form eg into tape 2 monitor in ok or whatever u want so u rember what ch thats on vcr run red white to video in sterio only and s video to tv or yellow comsite vcabel ok does that help
Posted on Jan 17, 2008
Kenwood ka 996 integrated amp. The standby light will dont turn off. I also need to see if someone will tell how everything should be hooked up.
the standby light should be on if the unit is not 'ON' if you want the 894 to turn on when you power up the 996, then you will have to plug the ac for the 894 into the 'switched' ac outlet on the back of the 996
what specific problems do you have with this system
Mar 07, 2013 | Audio Players & Recorders
When I hooked up my CD player it came on but did say nothing out the speakers
If this is a kenwood deck, Go into the menu, Your internal amp is turned off. Any other deck you did not wire it up poperly then, If you bruaght it used the output could be fried, Because it was not hookup right end wires were cross up.
Oct 26, 2012 | Car Audio & Video
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
I want tohook up a Kenwood KA-88 Amp. to a KT-58 Tuner to a DP-M5540 disc player and KA-68W Cassette deck. how do I do it?
Find the manuals or go by the basic INs to OUTs rule. REC = OUT, Play = IN. "Tuner" and "Aux/CD" are not literal. They're for anything BUT a turntable. But remember ONLY a turntable would ever use "PHONO".
This picture shows the rear of the KA-88
http://www.canuckaudiomart.com/view_images.php?cat=Amplifiers&catnick=amplifiers&cfid=168328&image_id=1469879
Register and download the CD manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-DP-M5540-CD-Players-manual/id/479ag101/t/2/
Jun 28, 2011 | Audio Players & Recorders
I have an old kenwood stereo system I forgot how to hook up it is a ka-87 amplifier a kt-57 tuner and a double deck cassette player kx-57w .Can anyone help?
Connect the RCA Outputs of the Tuner to the RCA inputs for Tuner on the amp.
Connect the output of the Tape Deck to the Tape Input on the amp.
Connect the input of the Tape Deck to the Tape Output on the amp.
Select Tuner on the amp to listen to the tuner.
Select tape Monitor to hear the Tape Deck(s).
Dec 30, 2010 | Audio Players & Recorders
How to connect a dvd recorder ( & player ) a VCR & Foxtel to a plasma THP46G10A do you have diagramatic sketch of connections
samsung 42" plasma hooked up to LG vcr/dvd combo and foxtel IQ box. all working but only by plugging vcr cable into video camera sockets on side of plasma tv?? reason only place with a yellow plug socket? on rear of tv colours are only red,green.blue? and white. nothing for the yellow can you give any advice on correct hookup proccedure please.
Dec 18, 2009 | Panasonic Televison & Video
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Having a hard time connecting various audio components
Yes, it is a little tricky...
1) CD Changer (output) -> CD input on Amp
this is tricky... this will allow you to record to your tape deck, and control the sound via the EQ:
2) Tape Deck (tape out / recout) -> TAPE PLAYBACK on EQ
3) Tape RecOut on EQ -> Tape 1 Playback on Amp
4) Amp Tape 1 RecOut -> Tape Deck Playback / Input / RecIn
in essence, your creating a loop starting from the tape deck, going to the eq, then to the amp, then back to the tape deck to record.
Your EQ has another set of LINE IN and LINE OUT - use the second Tape 2 on the amp to create another loop. This will
allow you to control the EQ for any of the other sources.
5) LINE IN on EQ -> Tape 2 RecOut
6) Tape 2 Playback on Amp -> LINE OUT on EQ
5) Radio Tuner (output) -> Tuner input on Amp
6) DVD/VCR Combo Output -> AV/AUX on Amp
7) PC Computer... you don't have room for this. You can either use the PHONO input, and you'll have to purchase a Line Level Phono Converter
or, get a Y cable and split the signal and share with some other source.
Hope this helps.
- OPTiC
www.djproaudio.com
www.repairny.com
Dec 13, 2008 | Technics SH-GE90 Home Equalizer
VR-206 - how to wire in equalizer
your vr-206 have several inputs dvd, vcr, tape decks, turn tables etc, also have an opcion called eq in and out usually if you dont have an equalizer al you do is jump straight rca to rca cables red in to red out and white in to white out.
but if you have an eq all you do is output from amp vr-206 to input and the input to output back to the amp
Dec 22, 2007 | Kenwood VR-209 Receiver
My deck doesnt not transmit signal to my amp. Is this an rca cable problem
Hi Your problem is almost defenetly that one speaker is hooked up with reversed polarities, making one speaker cancel out some vibrations of the other speaker. So get the wiring phase checked again, its ethier this or a fauly cable. Good luck.
Mar 21, 2006 | Kenwood KDC-MP728 CD Player
688 people viewed this question
 Grubhead
Grubhead
