Question about Edirol UA-25 External Sound System
Playback recordings I was using the Edirol UA-25 to recording my voice with no problems. The playback recordings were sharp and crisp. Now, when I record my voice the playback quality is terrible. What has happened?
Problem with cable? Change in sample rate? Have you changed software/drivers? Could do with more info.
Posted on Feb 10, 2008
Error: asio system overload 10011 and invalid input settings 10021
I am not sure what platform you are using or what software, but I would recomend unistalling the edirrol completely. Then re-dowload all the drivers and re-install them completely. Remove all traces from your recording software also before reinstalling.
Please give a bit more iformation on your setup if this is still a problem.
Best of luck
Oct 31, 2011 | Edirol UA-25 External Sound System
Can't Record and Only hearing playback via laptop.
Check you XP machine for SP3, go into the sound manager and make sure that the input your using is not muted and set as default.
http://www.ejoysoft.com/images/mixer.gif
Aug 04, 2009 | Edirol UA-4FX External Sound System
Problems recording on acid pro 7 with edirol ua4-fx
point nr 1:
when you record midi, you are not recording sound but a key code and time info it was pressed.
point nr 2:
the midi keyboard may be seen as a remote controller.
check the midi configuration on your software host
Jan 22, 2009 | Edirol UA-4FX External Sound System
Play back and record
You can leave it on, and select via software what you want to do.
if you arm a track then it is able to record, if nothing is armed then it will simply playback.
Aug 26, 2008 | Edirol UA-25 External Sound System
Only Hearing Sounds on One Side of Headphones
your headphones are bad sounds like cheak out the new seinhezer hd280 pros ok 99 bucks best they make
Jan 23, 2008 | Edirol UA-25 External Sound System
Recording sound
What operating system/ computer are you using>?
Oct 17, 2007 | Edirol UA-25 External Sound System
Recording Device Not Listed
You need to install the driver accordingly, When you buy the product it comes with installation Disk. If you dont have it now still you have solution simply download the driver from the manufacturer's website
Here is the link
http://www.rolandus.com/products/productdetails.aspx?ObjectId=758&ParentId=114#
Good Luck
Aug 30, 2007 | Edirol UA-4FX External Sound System
Problem with playback
Hi, I have the same audio interface. Alright, make sure that all of your effects are turned off. you probably (and most likely) have the "fx voice", "amp drive", "chorus" and "delay" effects turned on (bottom row). There is no way you should have distortion with tremolo & reverb on playback all the same time without the effects being turned on. the pop ticking could be produced by the buffer size. If youre using Sonar LE, you should tweek the buffer size until playback sounds smooth. I hope I helped! Good luck!
Aug 14, 2007 | Edirol UA-4FX External Sound System
Cannot record
some driver has been installed by your device...to go back, do you have "system Restore" turned on? if so, try restoring XP to a time before your device
May 27, 2007 | Edirol UA-25 External Sound System
Mic problems: playback works great through interface, microphone isn't being detected
Check in contraol Panel under sounds and audio devices that you are using the Edirol and not an on board sound. It sounds like although the cards installed its not selected as the audio device to record from. You will also have to tel Adobce audition to select the Edirol as you audio card of choice as it to can be changed to select input from other sound devices.
Mar 31, 2007 | Edirol UA-25 External Sound System
Edirol UA-25 External Sound System Logo
158 people viewed this question
Top Edirol Computers & Internet Experts
Folusho Adeyanju
Folusho Adeyanju
David
David
Ben Armstrong
Are you an Edirol Computer and Internet Expert? Answer questions, earn points and help others
