Question about Canon PIXMA MP600 all-In-One InkJet Printer
MP600 Paper Jam
My Canon MP600 says it has a paper jam but there is no visible paper jam. Can you tell me what to do. Thanks.
  • 12 more comments
  • kathioleary Jan 17, 2008
    I don't see paper anywhere and there was no jam. BUT before the error message, I did pull a piece of printer paper backwards out of the input slot so that it would not go through and that jerking motion set the error message on- but really no paper is there that I can see.
  • Anonymous Jan 24, 2008
    A piece of paper got stuck while feeding from the rear; I pulled it out backwards and now have the "paper jam" error message. I turn it off and on again, it feeds another piece through with no problem, but then the error message comes up again. There is no paper jam and even if I don't want to print, I can't even use it as a scanner. Help!
  • Toni f Jan 30, 2008
    I have the same problem. Very frustrating! There is no paper in the machine but I keep getting the message. Have tried everything I know. I really need to use my scanner.
  • De Fries Jan 30, 2008
    I have the same problem as well. There is absolutely no paper in the
    machine but I keep getting the message. I
    run a small company and really need to use my scanner and copier. A Canon client serviceman told me that my mp600 needs repairment and I should bring it back to the shop where I bought the machine. Don't know yet what to do, because repairment might be more expensive than the purchase of a new one.
  • Anonymous Feb 11, 2008
    I also have the same problem. There was a paper jam but all of the paper has been removed. However, the printer keeps giving the same error message - Error: paper output slot- the paper is jammed. Clear the paper and press OK. Have done this - checked all openings and turned printer off and on, and off at the wall and on. Nothing works.
  • telegramsam Feb 15, 2008
    I have the exact same problem and have no idea how to fix. I even paid $9 for a can of compressed air and tried to clean, but still continue to receive the error.
  • PeterLawrey Feb 29, 2008
    I had the same problem with a previous printer and foolishly bought another to replace it. Then the new one had the same problem!
  • Anonymous Mar 01, 2008
    I have switched the printer on and off, removed the printer cable and replugged and there is no visible paper in the printer that is jammed.
  • 4gradella Mar 06, 2008
    I also have the same problem with no luck solving them. I also have unplugged and toggled the feed switch with no results. I have also searched the unit to the best of my abilities and found no paper. Thanks!
  • whit22 Apr 07, 2008
    it's saying there is something jammed in the printer but have had made of friends look as well but nothing there. what do we do?
  • Anonymous Aug 26, 2008
    My printer has a non existent paper jam.. :Paper output slot" Jammed ect. Clear jamm blah blah blah... Anyone know how to fix this maybe with firware or something?
  • Anonymous Aug 27, 2008
    Same problem it says I have a paper jam but there is no paper to be found. Contacted Canon they tell me I can either buy a new printer from them at a discount or pay to have it repaired at a service center. The printer is 6 months out of warrenty. I bought it about 1-1/2 years ago. My old Lexmark lasted 5 years. I will not spend money to get it repaired nor will I buy any Canon products agian. Time to post a rant on Craigs list. This product is of poor quality and I would not suggest it to anyone. P.S. I have followed all the steps that tech support has suggested.
  • robin1212 Sep 03, 2008
    I have the same probelm - printer jam error with no paper jammed (was able to get the paper out in one piece). Just got off the phone with cannon and since I purchased the printer 13 months ago it is out of warranty and I have to take it to a service center. She said the initial paper jam might have tripped a sensor.
  • moon river
    moon river May 15, 2018
    massege the paper is jammed clear paper and press any salution
I just had the same problem, tried everything and resigned myself to buying a new one. I was about to throw the thing when I saw the Card backing of an A4 Pad. I thought I have nothing to lose so forced this through the machine and Bingo. It cured it.
Posted on Jan 07, 2009
I also had a phantom paper jam in my MP 600. I took an A4 piece of firm cardboard, pushed it through the feed switch at the back so it was half way through and left it sit there while I turned the printer off then on. It spat the cardboard out and all was fine again!
Posted on Feb 20, 2010
    Scholar:
  • 29 Answers
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Posted on Mar 05, 2008
I had the same problem with the printer paper jam error message. I did what dolphinfin suggested and it cleared my problem after two hours of trying everything else. Thank you!
Posted on Aug 15, 2009
Dolphinfin, you are right! My MP600 had the same problem. I noticed two white nylon rollers in the paper feed path were not flush with the rest; I jammed a business card in there, and an obstacle was dislodged. One or two printing attempts later, with a pair of needlenose pliers, I'd pulled out a missing pen cartridge that had fallen in there.
I see nothing wrong with the MP600; It's always been reliable, except when my messy office results in junk falling into the paper feed path.
Posted on Nov 20, 2009
Dolphinfin, it worked! Of course you need to check all the other possibilities. I image if a pin or paper clip fell in, this "last ditch effort" would have croaked the printer forever! As it is, I am a happy camper. Thanks-- when all else fails, you the man!
Posted on Apr 19, 2010
I had the same problem, but I opened a Word document, clicked print, and clicked "ok" on the scroll wheel quickly. It went through like a reset or something and then it printed the word doc.
Posted on Jun 16, 2008
Canon replaced my printer but this is a reocurring problem, I am now on my 3rd printer which also has a paper jam problem. I am still uinable to clear a non existant paper jam.
Posted on May 22, 2008
I've tried the A4 card stock solution. It worked to have the card stock in place and then turn the printer on and off. The card stock fed through (I've fed it through multiple times), but the error message is still there. It appears that there is no solution to a phantom jam- is this correct?
Posted on Jun 25, 2010
Paper jammed
Put off the machine and gradually remove the paper. If any piece of the paper is cut in the process, it must be removed else the printer would continue reading paper jam. Thanks.
Jun 28, 2012 | Canon PIXMA MP600 all-In-One InkJet...
Error message 6000
6000 is a paper jam or jammed sensor.
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp600#ServiceAndSupport
Click service and support, then enter error 6000, then click Error LCD ... 6000..., then click Removing paper jams mp600. Sorry, but they use javascript so I can't give you a more direct link.
Sep 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Paper jam in canon MP600 Printer
If you cannot see the paper jam, perhaps it is inside the machine:
1) Open the rear cover and inspect the area for any bits of paper that might impede the paper path
2) On the front of the machine, pull out the cassette (paper tray) and inspect the cassette area for any paper jammed inside.
Dec 21, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Non visible paper jam
Fixed the problem by running two sheets of heavy card stock through at the same time.
With the machine off, positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on. When turned on the printer, it drew the two sheets through and this reset the paper sensor. Previously found that only one sheet at a time did't work.
Aug 10, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon MP600 paper jam
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
May 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have PIXMA MP 600 PRINTER that has a paper jam as I fed used paper back into it /ink was still wet and apparently paper has stuck together and jammed. How do I clear
clear the jam paper
1) pull slowlly the jam paper back as possible as you can, usually the jam paper could be broken as pulling
2) open the cartridge area find the paper pull slowlly forword paper direction as possible as you can and try to take out any pieces paper behide the cartridge (between paper input roller and ink cartridge
Jan 24, 2009 | Canon PIXMA MP600 all-In-One InkJet...
that is correct..this puppy still under warranty?
Aug 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
It says the paper is jammed, but there's no paper in it!!
This is an awesome printer. Did you know it can duplex (print on both sides of the paper) automatically? The jam "could" be in the duplexer on the back or, the duplexer unit isn't locked into place.
Unplug the printer and open the rear door, check for visible paper jam, remove, close door.
There's also access to the feed mechanism from the bottom of the printer.
Unplug printer.
(1) Remove the Cassette. (paper tray on bottom of printer)
If the paper is loaded in the Auto Sheet Feeder (on back of printer), remove the paper from the Auto Sheet Feeder and close the Paper Support.
(2) Stand the machine with the left side down.
(3) Slowly pull the jammed paper out while pulling the green cover toward you.
Caution
Set the machine back to its original position immediately after removing the jammed paper.
(4) If any paper is sticking out of the Cassette, reload the paper in the Cassette.
Reload paper in the Auto Sheet Feeder, if necessary.
(5) Insert the Cassette into the machine.
(6) Press the OK button on the machine.
Some of these instructions were copied from the online/downloadable printer manual from Canon's web site: http://www.usa.canon.com/consumer/
Feb 16, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA MP600 all-In-One InkJet Printer Logo
4,219 people viewed this question
old marine
old marine
