Question about MSI KM4M-L Motherboard
I am not able to boot from cdrom of my system
I am unable to boot from cdrom of my system
    President:
  • 2,351 Answers
Enter pc bios. can you see your cdrom listed in the MAIN menue? Goto Boot. Set your cdrom to first boot device.
Make sure you have a bootable CD in the cdrom. Still can't boot to the cdrom? Think about swapping it out or getting a new one.
Posted on Jan 17, 2008
Can only get to BIOS, system will not boot to CD Rom. Unable to upload settings.
can u c the boot sequence in the BIOS....
if yes make to boot it from CDROM insted of Floppy/HDD
keep this boot seq. in BIOS
1 boot from CDROM
2 boot from Flopy
3 boot from HDD
Dec 17, 2009 | Acer Aspire 6930-6771 Laptop
I got the coooo2la and it shows 0xc0000139 error and I am unable to start up the computer in regular mode or safe mode what can i do.
This can be caused by a corrupted registry, malware, spyware, or a virus. My suggestion would be boot off of the CDROM and do a Automated System Repair (ASR) on Windows (not the recovery consol). If one of the Windows files has become corrupt, it will check file sizes and replace any files that it needs to in order for it to boot up.
If that does not work, or you are unable to use the ASR, please follow the steps on Microsoft's knowledge base as it should fix the issue:
Dec 14, 2009 | Microsoft Windows XP Professional SP2
I am unable to bot windows7. sudden failure
hi,
change the boot order so the CDROM is bootable first,
Insert your Win7 disk and boot off that , you will now seethe repair options.
Regards
GeWiz.
Dec 10, 2009 | HP Computers & Internet
Getting problem in formatting the IBM PC
check if the cable from the cd rom connected to your ibm pc if its ok , also check the master, slave configuration pins into the back of your cdrom. make sure that theres no conflict between the hard disk and the cdrom. Your cd rom may probably cannot be detected. make sure that it is working first. then install the hard disk. The hard disk must be in primary master and the cd rom must be in primary slave. then try booting it to your cd rom. also, try checking if your windows xp setup disk is bootable, it means that it can boot from cd rom. PM me if you have other experiences after doing what i adviced. Thank You.. heres my email. jmizpahadonai777@gmail.com
Aug 07, 2009 | IBM Thinkcentre 8185 PC Desktop
Unable to boot the computer.
have you check the jumper to see if there are master or slave settings. depending on your cdrom make sure if one is master the other is slave.
May 21, 2009 | Maxtor / 80GB / 7200 / 8MB / SATA-150 /...
Can't boot with Cd-Rom unable to install windows XP
Well, maybe I can try, thus in your bios setting you can boot using usb cdrom? Or maybe its time to change your cdrom drive already. If you can borrow a good spare cdrom. Take this in for the meantime in exchange for your installed cdrom. Maybe your cdrom drive is faulty. Then if this is ok, it is now easy for you to get on.
Second option, you can take out your harddrive prime it, then have a partition (say d:\) with a copy of full copy of xp installer, and other important installer just have it foldered. Then I assume you can boot using a floppy drive with win98 rescue disk. After booting goto harddrive partition with xp installer. then click setup and set it up in c:\ . Then your go other software, installed it manually.
I do this coz it much faster to installed using harddrive and also it is only in xp.
Hope this helps. comments if I miss something.
May 05, 2009 | Microsoft Windows XP Home Edition
Unable to boot win xp cd. not detected by compaq presario 5000 series interneal cd rom LTN 403 DQ24
Drive requires cd drivers to run Boot CD.
Some versions came with floppy disk to start cdrom drives, This will also require a floppy drive.
You may also try hitting f10 to enter bios setup make sure cdrom is bootable.
Mar 08, 2009 | Computers & Internet
Toshiba Satellite A50
When the system boots hit the BIOS key F2 and in the setup select boot from CDROM and press F10 and exit, Insert the bootable CD and boot the system
Jan 06, 2009 | Toshiba Sattelite A105-S2071 Notebook
Booting problem
Install MS Windows XP / 2003 / VISTA CD setup file (ISO file)
Then
  1. Start the computer with your chosen boot disk.
  2. Change to the cdrom drive.
  3. Go into the \i386 directory on the cdrom.
  4. Run WINNT.EXE to begin the install process.
Nov 21, 2008 | Microsoft Windows XP Professional With...
I am unable to boot my system through cdrom drive
Is the bios set to Boot to the cdrom? Enter the bios, go to Boot. Move cdrom to number 1. Save & exit.
Jan 17, 2008 | EliteGroup ECS 755-A2 Motherboard
MSI KM4M-L Motherboard Logo
285 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
