Question about Frigidaire FWTBB30DS Front Load Washer
Had same problem, found a 4 inch hose on left rear leaking, not properely installed. This corrected the problem after making correction.
Posted on Jan 27, 2008
Frigidaire gallery top load washer is leaking and will not wash big load
Hello msmm50 - Contact a professional so they can properly and accurately diagnose the unit for repairs. Sounds like you have a leak in the drain lines or the water valve.
Dec 01, 2012 | Frigidaire Gallery GLWS1339EC Top Load...
Filter on Frigidaire Gallery Washer
There is a coin trap at the bottom of the unit.
1. Unplug the washer
2. Pull the washer out to tilt it back so you can
reach the screws below the front panel and
remove it. (You will need something to catch
the water once the hose is removed from
the bottom of washer)
3. Loosen the bolt with the sliver clamp on the
bottom of the washer. The water will begin to
come out while your loosening the clamp. (Do
not remove any GREEN clamps)
4. Once the water is out, you can stick your hand
inside the hose to clean it out.
Aug 13, 2012 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire gallery front load washer dripping sound
With any front load machine manufacturers suggest to leave the door open after cycles to help evaporate the water - this is even done in top loading machines nowadays. Also clean the unit with bleach water and rinse in high temp water cycles.
Aug 12, 2012 | Frigidaire GLTF1670A Front Load Washer
Water Leak
1) make sure the drain on the floor in the back inside is clear of food and not fill with frozen water. If it is, pour hot water through it to clear.
2) that drain hose drains water down to a pan under the unit that should be evaporating from the heat of the compressor, but lately with all the humidity we've had, it may be playing catch up with itself.
3 Keep doors closed as much as possible
4) check and make sure door seals are tight.
Jul 16, 2010 | Hotpoint FFM70 Bottom Freezer Refrigerator
I have a frigidaire gallery front load washing machine that I purchased about 4-6 years ago. The softner will not dispense. I have taken the entire dispense unit out and have run hot water over it to try...
Add white vinegar to the dispenser and run a load. If that does not solve the problem take the dispenser out and soak it in a 50:50 white vinegar and water mixture for an hour
Sep 24, 2017 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
Frigidaire gallery series front load washer leaking water on side where soap dispenser is. Have had two different repair places take a look at it- replaced soap dispenser- still leaks - repair people can't...
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
May 19, 2017 | Frigidaire Gallery Supreme Series...
I have a combined Bosch fridge/freezer unit. It is the frost free type of freezer. Lately, the bottom unit (the freezer), the door sometimes seems to have no pressure behind it and will not stay shut.
use a level to make sure unit is not tipping forward. adjust 2 front feet to tip slighly backward door will then close itself from about 6 inches......poss feet have sunk into floor covering.....
Feb 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidare Gallery 2 speed top loader fills with
It could be multiple problems, if so it's more than one of the below, it would be cheaper to buy a new unit.
Start by removing the front panel and check the belt and idler pulley/tensioner. Look for wear in both and make sure there isn't too much play (it should only move about a 1/2 inch when pushed on it's longest stretch. While you have the front open, inspect the pulley for damage or excessive play.
Another cause could be the transmission (it's just above the pulley). Look for fluid/oil leaks and/or rust. A bad oil leak can cause the transmission to seize up. If you notice rust accumulated on the transmission assembly, you probably have a bad seal. Water could have gotten in there causing it to fail. A damaged transmission needs to be replaced, repair parts are not available.
The cycling problem sounds like a faulty timer. Test it by advancing the dial and make sure the correct cycles are starting/stopping. This part can be replaced with a few simple tools.
As always, make sure you disconnect the power before doing any service.
Aug 02, 2009 | Frigidaire Gallery GLWS1339EC Top Load...
Wont final spin , had loud knock but quit
You have a broken shock absorber and you need to relpace it. Remove the lower inspection panel by unscrewing the 2 screw at the bottom of the panel below the door. Remove the panel and look inside on either side of the wash tub. You will see the 2 shock absorbers and one or both will be broken. There are 2 plastic pins holding them in place. On the pointed end of the plastic pin, there is a tab that needs to be depressed (use a flat screwdriver) so that when you pull on the other side with a plier, the pin will come out. Go buy the replacement shock absorbers at your local appliance shop. To install, put the absorber in place and push in the plastic pins. Make sure the correct end is up. Replace the front panel and the job is done.
May 23, 2009 | Frigidaire Gallery Supreme GSTR1670DS 3.1...
I have a front loading frigidaire washer gallery 1670 series
I would say yes, its worth keeping. Mine leaked a while ago and I bought a new pump assembly. I think it was about $70. You can remove the two screws on the bottom of the bottom face plate and remove the cover. The pump is on the right side. Look for goo leaking out of the shaft seal. Verify before you buy parts, It could be the rubber boot torn or something similar.
Don't reach inside untill its unplugged.
You can replace the shocks easily too. Lots of parts places online with illustrated parts catalogs.
Jan 19, 2009 | Frigidaire GLTF1670A Front Load Washer
Frigidaire FWTBB30DS Front Load Washer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
