I have a casio wk210 keyboard. I have sampled sounds in .wav format, and they are stored in the Data Manager Data folder created when I downloaded the Casio Data Manager. I'm trying to move them from my computer to the keyboard using a USB cable and the Casio Data Manager software. The Data Manager software recognizes the keyboard files, but does not recognize the .wav files on my computer. Should I use a different format than .wav? Also, under preferences in the software, I've tried listing sampled sound (melody), sampled sound (drum), and all data, but I still can't get my .wav files to show up in (be recognized by) the Data Manager software.
I suggest you uninstall the Casio USB driver from Control Panel'system'device manager then Reboot the PC without the USB cable.
Download latest USB driver from :- http://support.casio.com/en/support/download.php?cid=008&pid=20
64 or 32 bits versions are both available.
Load driver first. Plug in the usb cable only when software tells you to do so.
Uninstall Data manager if wrong version.
Install IDES 4.0
Get a supported SD card. 1GB is supported by most Casio Keyboard. You need to format the SD card in the Casio Keyboard.
Midi files must be located within folder called "MUSICDAT". Some models only support "type 0" midi files.
If your computer has a SD card reader, you can use a 2GB or smaller SD card. Format the SD card using the CTK4000. Drop tje music into "MUSICDAT" folder.
If you connect to PC using a USB cable, you need to download DATA MANAGER from Casio website. DATA MANAGER allows you to copy files from computer to keyboard.
Does it say ERR NO FILE? If so, then read on. The reason you have this error is because you don't have a folder on your sd card named MUSICDAT. Solution:
Insert your sd card into computer
Make folder called MUSICDAT.
Then, transfer all files inside the folder (make sure your songs are in MIDI format).
Safely remove your sd card.
You're ready to put it in you Casio Keyboard!
If you still get the error, take time to read you manual. Read the "using the sd card" part. The folder name might be different for your Casio Keyboard (because mine's a CTK-5000).
...and IF you still get the error, perhaps the songs you meant in your question are MP3 songs (like the ones you play on the iPod)? Then, that's a different topic... :)
Well then, good luck!
Make sure the driver is compatible with your operating system... often stuff will not work with Vista for example. Often SOME software REQUIRES it to be installed before USB cable is connected, and yet other requires it not be connected till software is installed... read the manual...
Hi I just got a RC 50 and I face the same problem but looking the content of the data in the Roland folder (after you connect the USB) , I notice the format of the label of each sound's and I understood the problem.
So , here it is .
Before you connect to USB , you have to choose a patch , let say n.16 OK, now the audio file that you want to import into the data folder must be named in this way "016_1.WAV" ,the 16 refer to the patch number and 1 is the phrase number (if you want to put the audio file into the phrase 1 ,or 2 if 2 ecc.)
now disconnect the USB .At this point you just have to increase or decrease the patch number just one time and go back to 16 (it has to refresh the patch info) and you'll find your audio file ready to use in whatever phrase you put it.
have fun
Paolo
I have a Wk-8000 & a CDP-200R, the later is the same as wk-500 but with 88 weighted hammer keys.
Since wk-500 can play SMF (Midi 0 & 1) format directly from a SD card and there is enough polyphony to play anything, I don't find any real reason to convert SMF to any "Casio Format". Just get a 2GB SD card and put your SMF files in the MUSDAT folder for the SD CARD using your PC/MAC.
If you have the smart card slot you can save your songs to the memory card by using Anvil Studio which is a free program. Save your midi song in Format 0 and be sure to use channel 4 for right hand playing and channel 3 for left hand. Be sure to keep the file size under 80k if you have other channels active for other instruments!
