Question about Kenwood KVT-M707 7 in. Car Monitor
Bluetooth i have got kvtm707 and knag520 can i get a bluetooth device for this
  • 397 Answers
Yes, what are you trying to do?
Posted on Jan 20, 2008
I seem to have lost instructions on how to turn on the headset and pair
Bluetooth® is a wireless connectivity feature that has a short range and low power consumption. This makes it the perfect medium for sending information among devices in the same room. Using Bluetooth, you'll be able to connect to wireless headset and entertainment devices like wireless speakers. You can connect to many car infotainment systems and share your device's contacts and music. You can share content, such as photos and contact cards, between two mobile devices.
Connect to a Bluetooth Device
  1. To connect to a Bluetooth device, turn on the Bluetooth device you want to connect to and make sure it is in discoverable mode.
  2. To turn on Bluetooth on your mobile device, open the Notification Panel by swiping your finger from the top of the screen to the bottom, and touch the Bluetooth shortcut. When the Bluetooth transmitter is turned on, the icon will be green. If you do not see the shortcut, you may need to touch and hold the shortcut bar and swipe it left or right to reveal the additional shortcuts.
  3. To scan for new devices, touch the Settings icon_notifications_settings_shortcut.png > Bluetooth.
  4. Your mobile device will begin scanning for any available Bluetooth-enabled devices. If your device is on and in discoverable mode, it will show up in the list under Bluetooth devices.
  5. Touch your device. Verify the passkey matches on both devices and touch Accept. If you are connecting to an older Bluetooth device, you may be asked for a PIN. The default PIN for many devices is four zeros - 0000. Some devices have PINs specific to the device. The PIN will be in the device's documentation.
The Bluetooth menu allows you to make your device Not visible to other Bluetooth devices or Visible to all nearby Bluetooth devices by unmarking or marking the option above the Available devices list. When the box is marked, a timeout is shown next to Visible to all nearby Bluetooth devices. If the time reaches 0:00, touch the box to unmark it, and then mark it again to reset the timer.
Nov 02, 2014 | Radio Communications
Bluetooth cant searching another device? what i should did for that?
Depending on your computer and any bluetooth devices make sure both have bluetooth are either turned on or made bluetooth discoverable
Bluetooth Pairing
Bluetooth pairing is necessary whenever two Bluetooth devices connect to each other to share resources.
A trusted relationship is established between the devices using a numerical password, commonly referred to as a passkey.
Depending on how often one Bluetooth device connects to another, the user might opt to have the passkey saved for future connection attempts or prompt to enter the passkey each time the devices request communication with each other.
Bluetooth Pairing Service
In most cases, Bluetooth devices are paired only once, and the details of the relationship are saved for later connections.
The pairing service, an integral component of all Bluetooth devices, is responsible for maintaining a list of devices that have made successful connections in the past.
It is essentially a passkey manager remembers the specific details for other trusted Bluetooth devices.
If a user has a reason not to allow automatic connections for specific devices, the Bluetooth pairing service will not store passkey details.
Preparing to Pair Because Bluetooth is a standardized-communication method, making trusted connections between Bluetooth devices is a straight-forward and simple process.
Before attempting to pair two Bluetooth devices for the first time, it is recommended to have both devices fully charged, turned on and Bluetooth enabled.
At least one of the devices must be set to discoverable mode, which means for a short period, the device will be announcing its presence to other devices within its range.
Pairing Bluetooth Devices
Have the second device search for other Bluetooth devices.
There are many types of devices on the market and just as many ways to put your device into discoverable or searching modes.
It is recommended you view the documentation for your specific devices to determine how to enter these modes.
Within 30 seconds, you should see the devices have found each other and a prompt to enter a passkey will be presented.
Bluetooth Pairing Passkey
The passkey is a four-digit number you supply at the time you are establishing your trusted relationship between devices.
If a specific passkey is set by the manufacturer, you can try "0000," or you might have to find the passkey in your device's documentation and enter that instead.
After you enter a passkey, the other device might prompt you to enter the passkey you entered. When the passkey is verified on the other device, the two have been paired.
The Bluetooth device and passkey information are stored using the pairing service so future pairing attempts do not have to be made unless desired as a security precaution.
Bluetooth software
You may wish to check out Bluetooth Command Line Tools a set of console utilities designed to work with Microsoft bluetooth stack.
Other Bluetooth resources
Visit our free premoderated Directory of Bluetooth Resources.
Aug 04, 2013 | Computers & Internet
Bluetooth is not responding
which bluetooth device ? are you referring to ?
keyboard , mouse , ahh a webcam ?
Bluetooth is a wireless technology that connects devices over a limited-range network (WPAN, or wireless personal area network). Bluetooth transfers data three to eight times faster than a parallel or serial port.
Some Lenovo PCs includes an internal Bluetooth card to allow users to connect Bluetooth devices to the computer. Inactive Bluetooth support or computer settings can prevent the Lenovo PC from detecting a Bluetooth device.
Hold down "Fn" and "F5" after booting the computer or returning from standby to enable Bluetooth features. Click "Start." Click "Control Panel." Double-click "Bluetooth Configuration." Select the "Accessibility" tab. Check "Let other Bluetooth devices discover this computer." Select "All devices" from the drop-down menu. Click "OK." Double-click "Bluetooth Devices." Select the "Options" tab. Check "Turn discovery on," "Allow Bluetooth devices to connect to this computer" and "Alert me when a new Bluetooth device wants to connect." Click "OK." Exit from "Control Panel." Align the device with the Lenovo PC. Check the documentation included with the device to confirm it is the correct distance from the computer. Right-click "Start." Click "Explore" or "Open." Navigate to "My Bluetooth Places." Click "Bluetooth Tasks." Click "View Devices in Range" to locate the device. Select the device from the list. Click "Discover services" to use the device's applications on your Lenovo PC. Right-click the device and select "Connect" or "Pair" to configure the device. Hope it helps.
Jan 25, 2013 | Lenovo G570 43349EU 15.6" Windows 7 Home...
Trying to connect jabra BT2080 to phone. says enter passkey?
  1. Bluetooth device A looks for other Bluetooth devices in the area
  2. In order to find other Bluetooth devices, Bluetooth device A must be set to discoverable mode. When set to discoverable, Bluetooth device A will allow other Bluetooth devices to detect its presence and attempt to establish a connection.
    You may set your discover setting off if you like (It is recommended that you turn it off when not using the Bluetooth). When the discover setting is off, no other Bluetooth device will be able to find it. Undiscoverable devices can still communicate with each other but they have to initiate communication themselves.
  3. Bluetooth device A finds Bluetooth device B
    Usually the discoverable device will indicate what type of device it is (Such as a printer, cell phone, headset, etc.) and its Bluetooth device name. The Bluetooth device name is the name that you give the Bluetooth device or the factory name that originally was programmed.
  4. Bluetooth Device A prompts you to enter a password (PassKey)
    With advanced devices (i.e. computers, smartphones), both users must agree on the Passkey and enter it into their device. The code can be anything you like as long as it is the same for both Bluetooth wireless devices.
    On other devices, such as Bluetooth headsets, the Passkey stays the same. Refer to the product's manual for the default passkey. Most often, the default passkey is "0000".
  5. Bluetooth device A sends the Passkey to Bluetooth device B
Jan 26, 2011 | Jabra BT2080 Bluetooth Headset
Can my motorola hH695 be paired to my iPad?
Hi, this instructions works on some iPads, you can try it on yours.
How to Pair A Bluetooth Device With The iPad
Among the many convenient features of the Apple iPad, the ability to pair the iPad to any Bluetooth device is very convenient.
Bluetooth devices allow your iPad to interact with devices ranging from headsets to computers without the use of wires.
Like most things related to the iPad, connecting an iPad to a Bluetooth device is easy. Follow these simple steps to do so.
Instructions
Things You'll Need:
* iPad
* Bluetooth Device (headset or other)
First, in order to pair the iPad to a Bluetooth device you need to make sure the Bluetooth device is discoverable. Refer to the instruction manual for the device (which you can find online usually if you lost it) on how to do this.
Typically, it just involves holding down a button for a few seconds.
Next, you need to turn the iPad's Bluetooth capability on. Go to Settings by touching the Settings App icon that looks like gears.
Within Settings, select General and then Bluetooth. Once you are in the Bluetooth screen, press the on/off switch to turn Bluetooth on. Make sure it reads "on".
Once you turn on Bluetooth, you should see the discoverable Bluetooth device show up on the screen as part of a list. Select the device you wish to pair with the iPad.
Depending on the device, it may prompt you for a password. Refer to the Bluetooth device's product manual for this password.
Tips & Warnings
A white Bluetooth icon on the top of the screen indicates a device is connected to the iPad
A gray Bluetooth icon on the top of the screen indicates Bluetooth is on but no device is connected.
Jan 09, 2011 | Motorola Mobility H695 Bluetooth Headset
Pairing with a motorola bluetooth device
Hello, Barb.
Here are some instructions from the manual:
To set up a Bluetooth connection, do the following:
1. Select Menu > Settings >
Connectivity > Bluetooth.
2. To activate or deactivate the Bluetooth function, select
Bluetooth > On or Off.
Indicates an active Bluetooth connection.
3. To search for compatible Bluetooth audio devices, select
Search for audio enhancements and the device that you want to connect to the phone.
To search for any Bluetooth device in range, select Paired
devices. Select New to list any Bluetooth device in range.
Scroll to a device, and select Pair.
4. Enter the Bluetooth passcode of the device to associate (pair)
the device to your phone. You must only give this passcode when you connect to the device for the first time. Your phone connects to the device, and you can start data transfer.
Hope this helps.
Apr 19, 2010 | Nokia 6085 Cellular Phone
I have blackberry 8110 and it ask me for a passkey
Blackberry 8110
Bluetooth technology troubleshooting:
Common Problems
I cannot type a passkey on a Bluetooth enabled device
If you cannot type a passkey on a Bluetooth® enabled device, the passkey might already be defined.
On your BlackBerry® device, in the Enter passkey for <device name> field, try typing 0000.
My list of paired Bluetooth enabled devices does not appear
Try performing the following actions:
• Verify that Bluetooth® technology is turned on.
• Verify that you have added Bluetooth enabled devices to the paired Bluetooth enabled devices list.
I cannot pair with a Bluetooth enabled device
• Verify that your BlackBerry® device is compatible with the Bluetooth® enabled device. For more information, see the documentation that came with the Bluetooth enabled device.
• Allow the Bluetooth enabled device to discover your BlackBerry device. In the Bluetooth setup application, click Allow another device to find me.
• Turn off encryption for Bluetooth connections between your BlackBerry device and the Bluetooth enabled device. In the device options, click Bluetooth. Click a Bluetooth enabled device. Click Device Properties. Change the Encryption field to Disabled. Press the Menu key. Click Save.
I cannot share contacts with a paired Bluetooth enabled device
• Verify that your BlackBerry® device is paired with the Bluetooth enabled device.
• Verify that, in the Bluetooth options, the Address Book Transfer field is not set to Disabled.
• Verify that your BlackBerry device is connected to a Bluetooth enabled device that supports the Handsfree profile or the Object Push profile. For more information about supported profiles, see the documentation that came with the Bluetooth enabled device.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Feb 01, 2010 | RIM BlackBerry ® 8830 Cellular Phone
How can i set the em227pk bluetooth up for pairing? plz help.
In order to pair a BlackBerry smartphone with a Bluetooth enabled device (e.g. a Bluetooth enabled headset), the Bluetooth enabled device must be in pairing mode. Most Bluetooth enabled devices are not set to pairing mode by default. Refer to your Bluetooth enabled device manual for instructions on how to set the Bluetooth enabled device to pairing mode.
To pair the BlackBerry smartphone with a Bluetooth enabled device, complete the following steps:
1) On the BlackBerry smartphone, click Options > Bluetooth. If you cannot find the Bluetooth option,
2) Open the menu and select Add Device. The Select Device list appears and lists Bluetooth enabled devices that are in range and available to be paired.
Note: Only BlackBerry smartphones enabled with Bluetooth technology that are in range and in pairing mode will appear in the available Select Device list.
3) Select the Bluetooth enabled device with which you are pairing. The Enter passkey dialog appears.
4) Type the passkey to authenticate the Bluetooth enabled device. Most Bluetooth enabled devices contain a hard coded passkey. See your Bluetooth enabled device manual for the passkey.
Note: 0000 is the universal passkey for pairing any Bluetooth enabled device with a BlackBerry smartphone.
Note: Once a Bluetooth enabled device is paired, it appears in the Paired Devices list. The Bluetooth enabled device will no longer appear in the Select Device list.
Bluetooth devices are manufacturer specific. Please refer user manual for instructions on how to pair with other devices.
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
Bluetooth
my bluetooth device not working. if i try to start it laptop say NO BLUETOOTH DIVICE.so what can i do?
Dec 12, 2007 | Acer Aspire 5100 Notebook
Kenwood KVT-M707 7 in. Car Monitor Logo
112 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
