REDDY HEATER THE HEATER WILL IGNITE AND STAY LIT FOR TEN SECONDS THEN SHUTS OFF SEEMS LIKE IT IS NOT GETTING ANY FUEL
  • 1 more comment
  • Anonymous Mar 24, 2008
    my ready heater lights up fan starts you see the kearosine sprewing out and it shuts down within seconds???
  • Anonymous Aug 26, 2008
    heater turns on for a few seconds then turns off
  • Anonymous Oct 30, 2008
    I had the same problem. Had to replace ignitor.
    Problem Solver:
  • 19 Answers
Check the photocell with an ohm meter in bright light should have continuity.
Posted on Mar 05, 2008
I have reddy pro 170 i plug it in , the fan & igniter comes on for 10 to 15 seconds then shuts off ,blew through fuel line and nozzle still same result, i do see fuel mist coming out nozzle ,i dont k
You must make sure the mist is not to close to the igniter . If it is it wont be misty enough to ignite. And make sure its in the path of the mist. If its new return it to the store.
Feb 07, 2015 | Reddy Heater Pro-Tough Kerosene/Diesel...
My heater is a reddy heater 165,000btu. when i plug it up it will ignite, it will get a flame for about ten seconds and it shutdown. i recently replaced the ignitor because it broke and replace the fuel...
I would definitely stop burning off road diesel as it is dirty.Remove the top section of the heater and clean the fire eye with windex and a terry cloth rag, and run K1 kerosene it burns so much cleaner. Also make sure that fuel is not an issuecheck fuel filter,fuel lines and don't forget the screen in behind the nozzle.
Dec 14, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
When filled with kerosene then plugged in, the heater will kick on for about 3 seconds and the fan will run but it will not ignite, then it shuts off. reddy heater 55, 55000btu. runs on K1 or fuel oil.
REDDY HEATER 40 KEROSENE FIRES UP FOR A FEW SECONDS AND QUITS WITH A WHITE CLOUD OF SMOKE COMING OUT THE END
MY REDDY HEATER 35 KEROSENE RAN OUT OF FUEL AND WILL NOT RUN AT ALL WHEN PLUGGED IN
Jan 11, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater will not stay on rm60 reddy heater
When you say the heater is coming on does it actually ignite or is the motor just running until the safety circuit kicks it off? The air pump on you heater should blow at 3.5 to 4 psi which runs up to the nozzle which is a venturi which sucks the fuel out of the tank. The motor will generally run for 20 to 30 seconds trying to ignite. If the flame sensor does not sufficient flame during the time it shuts the motor off. Check these items and let me know what you find.
Jan 07, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddy Heater Doesn't fully ignite
First thing I would do is clean all of your air and fuel filters and check your lines for breaks. A lot of times they will do that if your not getting enough air to fuel mix. If it continues after that it's the CAD/ flame sensor which you can get from MR. Heater for 3 bucks they are all basically the same and I know reddy heater wants 18 for the same thing.
Jan 27, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Reddyheat rlp 100 will not stay lit, strong gas smell.
I had the same problem with my Reddy Heater PRO 100. It is the 20Lb bottle causing your problem.
I Put a 100LB bottle on and ended my problems.
Dec 31, 2008 | Reddy Heater RLP100 Portable Forced Air...
Igniter lites up fan kicks on and within 5 sec shuts off
Dustin, The ignitor only glows for 5 seconds, just long enough to ignite the fuel. The heater is shutting down because the photocell does not see the correct flame color.
Since you say "comes on for 5 seconds", I can only assume that there is a flame. You do not specify a lack of flame. I am also assuming that you have had the heater running this heater season and the problem just started.
YOU must find out if the problem is fuel delivery related or electronics related. Start by checking the pump pressure.
Follow these troubleshooting tips
Dec 21, 2008 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
343 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
