Question about Ricoh Aficio SP-C210SF Printer
Printer only prints on the left side and wrinkles up the paper on the left side
It only prints half on the page on the left side & it is wrinkling up the paper on the left side as well.
  • 417 Answers
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Posted on Jan 19, 2008
Paper wrinkles when printing
You can try these following solutions:
If the paper does not completely eject, press the paper with folded side paper button, then open the printer cover and remove the paper. Also, check the Paper Size setting in your application or printer software.
If the paper is wrinkled when it comes out, it may be damp or too thin. Load a new stack then try to print again. You can also try to check the printer alignment and the printer setting.
Feb 11, 2010 | Office Equipment & Supplies
HP LaserJet P3005 printer prints wrinkled paper
2 reasons:
1. Was there a paper jam prior to this problem? It could be that the paper was pulled out and a small bit of it is stuck on the pins that guide the paper from the heat roller. If no torn jammed paper prior to this issue, then check out 2.
2. the heater/roller is damaged and needs to be replaced. I would suggest you take it to your nearest HP dealer to properly diagnose this for you.This would save you unnecessary cost in trying to pull it apart and causing more damage to it.
Good Luck,
Jan 27, 2010 | HP LaserJet P3005n Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
My Dell 1100 keeps wrinkling and tearing the paper
Depending on wear the tear is at determines the issue. The wrinkling paper and the look of your printer sounds like some sort of fuser issue. Recycled paper is more likely to wrinkle and the grain can cause paper to wrinkle as well. The Long grain paper is up and down the sheet and short gain is side to side on a sheet of paper. If your printer is on a long grain setting and you have the pages coming out sides ways or vice versa then your print outs can wrinkle.
Jun 22, 2009 | Dell 1100 Laser Printer
Wrinkled Left front corner
Sounds like you have a burr on the paper guide fins. Look for a small nick in the plastic guides fins which can simply be filed smooth with a small file.
May 26, 2009 | Brother HL 5250DN Laser Printer
Paper wrinkles on left side when printing
Fuser is worn out (specifically, the pressure roller).
May 19, 2009 | HP LaserJet 1300 Printer
FIRST printed page is quite wrinkled, the rest are fine
Hello sir;Try to print one page, when the paper process half way then stop the machine, remove the cartridge, check the paper is wrinkling, if yes ,that's meanspaper feed roller dirty or registration roller slipply, ortherwise, check the fusing unit, need to replace presure roller. The 2nd issue, you need to replace paper stop roller or rubber pad.
May 12, 2009 | Brother HL 5250DN Laser Printer
CLJ8550n poor print quality and wrinkled paper
this is usually not caused by the paper tray. this problem is usually caused by the fuser assembly. check your paper path. dead cycle the printer, shut the printer down before the paper enters the fusing area, check for wrinkles. remove all paper, print again, check the output, wrinkles, replace the fuser.
Feb 03, 2009 | HP Color LaserJet 8550n Printer
Paper jamed or wrinkled
Dear
this is the problem of hot roller replace it paper jam problem will be resolved.
Nov 25, 2008 | Samsung ML2251N Laser Printer
Ricoh Aficio SP-C210SF Printer Logo
575 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
