Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer
I am just trying to change the direction of the vent from the back to the side. I popped out the side panel.....but how the heck do you get an elbo in there? Do I have to pull the front panel off, and pull the drum out too?
  • Mitchgitch Jan 17, 2008
    I was afraid of that. In the old days the back just popped right off! Thanks.
    Sergeant:
    Champion:
  • 262 Answers
Sorry to say this but yes you have to pull it apart and put elbow on you may be able to put it on by just pulling the front panel and working it in between the drum but not likely but the drum is just pulling the belt off and pulling up and out at the same time let me know if you need any more help
Posted on Jan 17, 2008
  • Bill Dozier Jan 17, 2008
    sorry but the rules have changed over the years it drives me crazy too (leave well enough alone is what I say)good luck and if you need my help
Maytag dryer is taking forever to dry clothes, can even smell bad while running? how do i clean it besides the lint catcher?
Make sure the vent is not clogged. Its in the bottom of back side. Typically vented outside. Also, verify your heater elements are working by running dryer with door open to check for heat
Jul 27, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Hello, my maytag neptune dryer is making a loud noise while drying. when i turn it off, and turn the drum, i hear a chaffing noise on the left side. i tried to pry the top off, however it doesnt seem to...
Steven your neptune dryer has bearing problems - thats the chaffing noise you hear on the left side - your drum is running off centre , probably pulled that side by the action of the drive belt . Remove back of machine and check out from there . disconnect all power before and during inspection . you may be able to replace bearings on that dryer if you have the tools to do so .
Jul 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Can i change which side the driver vent is located?
Hello Laurie. Your dryer allows rear vent, left or right vent. Here is a diagram which shows you all three http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MDE5500AYW/3048/0151200/M0606011/00002?blt=06&prst=&shdMod=
Just pull the dryer out from the wall to access the rear and sides. Joe
Thanks for choosing Fixya!
Jan 11, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AYW panel lights work but not dryer
inside the control panel is a tech sheet that has some diagnostics on it . there is a membrane button test or something to that effect. I suspect that the start/pause button is the problem and you would need to replace the console w/touchpad.about $130-140 new. there are some used ones on ebay.
May 20, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My dryer quit working and I think it is the thermal fuse.
maytag neptune?..remove door and screws on other side too.. pop off front. :)
Jun 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Contol panel has gone blank and contol panel is hot on right side
try unpuging for awhile then plug back in if doesnt work need to replace board and panel
Apr 06, 2009 | Maytag Neptune Washer
Maytag neptune dryer not heating up to dry clothes.
On my dryer the igniter is rt behind the front panel. Take off the dooe and a few screws and pull it off. If the igniter lights at all it is good. Try also checking the entire discharge vent hose as sometimes it gets clogged way dn line and you might not notice it. Try squeezing it all the way dn.
Mar 02, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Control panel not lighting up
there is a fuse inside the machine but try to unplug it for 15 mins to reset and see what happens
Sep 15, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to remove a back panel of maytag neptune dryer?
You have a choice for which side front door should be on this model. There are 4 screws on front door. Take all 4 screws and pull down the front panel. You will see two metal parts each side which holds top panel. Remove two screws and metal parts. Now you can push up the top panel.
Mar 17, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
196 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
