Back to:
Tags:
Ovens
Generic problem for all Ovens
Whirlpool super capacity 465 / gas oven won't light (by 4 users)
posted by w-f-h on Jan 17, 2008
digit displays ok, counts down preheat time, but never fires, after preheat time just goes back to the clock. no smell of gas (good thing). Thank you
Comment by w-f-h, posted on Jan 17, 2008
tech 17, no the broiler does not light. thanks for your concern, Wayne
nope worked one day.. and not the next. The top burners don't always fire up the best, yet eventually they work. what made me investigate, was last nite the oven wouldn't do a thing. noticed after pre heat time that it wasn't warm at all. It's a whirlpool MOD# SF377PEGQ 1 Thanks for your concern. Wayne
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by mrsjulian, posted on Oct 12, 2008
My whirlpool super capacity 465 will not ignite. There is no power what so ever going to it. There is nothing on the display. I've noticed that last week the display read "PF" -power failure..but everything lighted fine. I've unplugged the unit thinking that might help, but it didn't. I can light it with a match but that's it.
Comment by icey330, posted on Jul 15, 2008
Same issue here. Google lead me to this site. Broiler works fine. Stove works fine. Oven just won't light.
Comment by tmmoore52, posted on Feb 04, 2008
My Whirlpool Super Capacity 465: The stove works, the oven doesn't. I am getting gas past the regulator, but it is no getting to the gas tube in the oven. What is the most likely problem(s) & what is the average cost to fix it?
Clarification Request
by tech17, posted on Jan 17, 2008
ok the reason i ask the broiler and oven have their own ignition systems now if you will send me the complete model number off the serial plate on the front of the oven usually behind the bottom door ill got to whirlpool and lock up the problem also any trouble codes if it displays and did this just happen all of a sudden or any strange thing like self clean or such more info better to solve
try the broiler and let me know if it lights there is a safety valve on modern ovens that wont let gas in if oven doesn't light
Best Solution
posted on Jan 18, 2008
Helpful (85)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Hi.I'm back, no the broiler doesn't glow either. ran some tests and i have 116.4 volts @ the igniter. and when I checked igniter I recieved an open circuit. Tested a new igniter and it showed a reading thus making me believe that the old igniter has open circuit. Also did ohms resistance test ?? on valve regulator and recieved reading, thus eliminating that the valve is probably not defective. So where I'm at is I am going to install the new igniter and see if it fires up . Then do the same tests on the broiler and see where I stand. Maybe our broiler has been out awhile and went unoticed. Till the bake went out. Make any sense? I may sound confused but confident that I will prevail... LOL thanks for everything,
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on whirlpool super capacity 465 / gas oven won't light:
I don't want to Accept this solution
Solution #2
Thanks for Trying (70)
tech17
Rank:Guru Guru
Rating: 88%, 1134 votes
now you say your top burners aren't lighting well either have you noticed any difference in the flame height if you turn all the burners on all the way
Comment by tech17, posted on Jan 17, 2008
look in the oven up at the broiler tube and tell me if you can see the tube and ignightor ir you can turn on the broiler and let mi know if it glow-es red
we aren't done just trying to diagnose the problem its one of three things as i see it 1the electronic oven control is bad but that usually displays a f code 2the oven ignightor is bad but most of the time if that's the case the broiler will ignite unless both are bad which can happen but rare 3 either the oven safety valve is bad or rust is restricting the screen in the pressure regulator from the in coming gas line which would effect the whole oven . were just trying to narrow it down so we fix the right part sorry but its not the kind of promblem where i can just type a fix
Rating Locked! (?) w-f-h has rated this solution as Thanks for Trying
Thank You!
Solution #3
Not Rated (0)
Guest
Rating: 0%, 0 votes
no it doesn't.... Hey didn't mean to cut you off i was following prompts. it said to rate solution. guess I didn't figure that was a solution. Got to be away for awile I'll check back later. thanks.
Thank You!
Can you Help with these Ovens problems?
Ovens
The oven door on my Kenmore electric range (model...
Thermador SC302T Electric Double Oven
We can't get the oven light to go off and on. It is stuck...
Ovens
the oven I have is old and the oven portion won't work but...
Tappan 30IN ELEC IGNa Oven
Once the heat comes on, which isn't consistent with the...
Kenmore 40494 / 40495 / 40499 Electric...
how do i get my stove on self clean
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
