Question about Sony VAIO VGN-S150 Notebook
No screen light on switching
On switching switch LED ,WAN led glow but the HDD led just glow for a second then sut off and the screen does not glow at all.This prolem occurred firt occasional,then frequently and now permanently.Some body told to replace Hard Disc Drive. Even on replacing the swame problem persists.Pl. suggest the solution for this problem.Will be thankful.My EMail chauhantej@gmail com.Thanks
TEJ CHAUHAN SanAntonio
  • tejchauhan Jan 20, 2008
    I tried again to fix hardware but still no light,probaboly the problem is with invertor and back light.could it be tested by simple multimeter? or any other way .thanks.tej chauhan
  • 51 Answers
There are two possibilities
1. you might not properly insert your hardware
2. its broken
resiting it will help
if not replacing it will do
Posted on Jan 17, 2008
Do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
The led on the front won't light, and I have power connected, but nothing. Is there a reset somewere?
I am assuming you are trying to power up an installed motherboard, based on the category selection. You say that you have power connected. That means that you have connected the 20 (24) pin main connector and the 4 or 8 pin CPU power connector to the motherboard. Have you connected the front panels controls to the motherboard header? There are connections for the power switch, power LED, HDD LED, reset switch (optional). They must be connected in order for the motherboard to start. THe HDD and Power LED connections are polarity-based, so if you hook them upo backwards, their respective LED will not light. The HDD LED plug is usually red and white with the red being on the positive (+) terminal. The Power LED plug is usually green and white with the green wire going to the positive terminal. The power switch and reset switch wires can be connected either way as they are not polarized.
Jul 14, 2015 | Computers & Internet
How do I fix a Canon pixma ip6600D printer?
ALARM LIGHT which always glows - RAM error (logic board is dead)
Apr 02, 2015 | Canon Pixma iP6600D InkJet Photo Printer
The switch on our almost new Life Gear Glow 300 hour LED spot light is not working. We replaced the batteries as we assumed that was the problem. When the switch is depressed the light flashes briefly
sounds like the switch is intermittently contacting an needs cleaned , tightened ,or replaced
try some wd 40 in it .it wont hurt the electronics
or take the switch apart an clean
Oct 12, 2014 | LifeGear Life Gear Flashlights LED 300 Hr...
I have a Sennheiser MM100 Bluetooth headphones that has stopped responding. It will not turn on/off and the LED light is blinking a continuous blue. How do I get it to function again?
Found this online. Hope it helps you out.
Switching the headset on
To switch the headset on:
Press and hold the Play/Pause button for 2 seconds.
An ascending confirmation beep is heard in the headset and the LED indicates the current operating mode. Flashing in blue indicates that the battery charge status is OK; flashing in red indicates a low
battery (see page 6).
The LED flashes several times every second:
The headset is paired to one or several Bluetooth devices and tries to connect to one of these devices.
The LED flashes slowly (once every second):
The headset is paired to one or several Bluetooth devices. However, there is no current connection because the
Bluetooth device is switched off or out of range.
The LED flashes once every 3 seconds:
The headset is paired to one or several Bluetooth devices. However, there is neither an audio transmission nor an active call.
The LED is glowing slowly every 4 seconds:
The headset is paired to one or several Bluetooth devices, a sound file is received via A2DP and played back or
paused.
The LED flashes once every second:
The headset is paired to one or several Bluetooth devices and there is currently an active call.
If you switch on the headset and keep the Play/Pause button pressed for 5 seconds, the headset will go into pairing mode (see ?Pairing the headset? on page 9).
The LED flashes alternatingly in red and blue for up to 60 seconds:
The headset is not yet paired to any Bluetooth device. Pair it as described under ?Pairing the headset? on page 9.
Oct 31, 2012 | Audio Players & Recorders
Most of the time while I'm switching on it, power led does glow, HDD Led glows once and also can here the spinning sound of Processor fan but there is no display and after few seconds it will restart. if...
two solutions:
1- use a cooling hardware. maybe your laptop hangs because of high Temprature.
2- VGA of your laptop almost destroyed !!(sorry damaged).
so you can only take your laptop to a guarantee center.
Jan 10, 2011 | Compaq Presario F572US Notebook PC
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Problem with GA 8LD533
There are a few easy fixes for this, first,
Clear the CMOS (Unplug the power cord, remove the battery, and (if it's an option) move the jumper J1 (it has three pins, the jumper covers two, move it to cover the other one), unplug everything external from the motherboard apart from the PSU and power switch and speaker, replace battery, powercord, and jp1, power up - what happens?
Nov 19, 2007 | Gigabyte GA-8LD533(-P) microATX...
Sony VAIO VGN-S150 Notebook Logo
110 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
