Question about Xerox WorkCentre XD100 All-In-One Laser Printer
THE XEROX XD100
WHEN I MAKE A COPY THE IMAGE IS NOT COMPLETE. IT IS CUT OFF AT ONE END.
  • CHROME1945 Jan 24, 2008
    thanks alot we will try it. it sounds just like the solution we needed.
    Problem Solver:
  • 5 Answers
You can check the clutch in the main cassette to make sure it is turning the feed rollers by barely starting a feed and stopping the machine. The rollers will be in a different position. A second way is to take the paper tray out and trip the paper tray switch all the way in back, then start a feed and put (just a LITTLE pressure) with your finger on the roller to see if is aggresively turns. This will prove that the clutch is good.
DO NOT USE alcohol to clean the rollers since this will clean the rubber rollers but make them fail much sooner. Use eucalyputs oil (4 oz bottle in health food stores for $5 will last for years) with a cloth and clean the rubber pickup rollers. If the leading edge of the rollers looks a little shinny you need to barely roughen the entire surface of the roller up with (60 to 80 grit) sandpaper (especially the leading edge) and then clean it again with the euclyptus oil. This will take about 20 minutes to dry and your rollers will pickup paper as good if not better than when they were new.
If your image if still not complete and is cut off at the end, see if you get the same result by using the manual bypass with a sheet of paper. Also try copying from the ADF if you have one. You can do a copy at 50% and see if the whole image is on the output or if the end is still cut off. If it consistently is cut off at the end by just a little, you can go into diagnostic mode with - Turn on power and within 4 seconds pres clear, exposure mode, clear, exposure mode - adjust "trail edge deletion" enter 50 then print, then enter 1 then print, then press exposure mode until the auto, text, & photo lights are lit, then adjust number shown up to increase, down to decrease. Turn off and back on to test.
Posted on Jan 23, 2008
  • copier user Jan 27, 2008
    I see from your comment that you may not have believed what I told you. As an engineer, let me explain it. Alcohol disolves oil and rubber rollers have oil in them which makes them pliable and tacky. Alcohol will clean the dirt off the roller and then cause the roller to fail sooner than it should because it dries out and becomes less tacky. Eucalyptus oil will also clean the dirt off the roller, but in addition will replenish the oil in the rubber and keep the rubber soft and tacky (not slippery). Roughening up the smooth or shiny surface of the rollers with a course grit sandpaper provides thousands of edges to grip the paper (similar to siping a tire). The hardest part of paper pickup is the initial grip because it has to overcome the friction of paper to paper. Once the paper has started to move, it is much easier to keep it in motion and fighting friction sources are not as big of a problem. Even though a roller can feel tacky to the skin, it has to quickly come in contact with the paper when the clutch picks and start the paper moving instantly. If it starts to slip a little, it is very easy for it to continue to slip and hence the paper jam.
    I have actually taken brand new copiers and printers that were made by Sharp, Xerox, HP, etc. that would paper jam with slicker papers and fixed the problem that the manufacturer could not fix with the above proceedure. So trust me when I tell you that it is the best possible solution and many times works better than replacing parts with new parts that produce the same results. Many manufacturers and technical people do not understand this. In the case of manufacturers, it would be slightly counterproductive in light of reducing sales of new rollers.
    Genius:
  • 1,003 Answers
Clean all acessable feed rollers with rubbing alcohol applied to a microfiber cloth.
Posted on Jan 17, 2008
How do I cut an image I have gotten from google
Simply use "Paint" (Find on Windows Search Engine).
Copy the image on web then paste it on Paint clicking CTRL+V.
Cut pushing the Gray Squares, just crop it: 25339131-qiujozs4ltfcqs4dcs3ov4hz-3-0.jpg 25339131-qiujozs4ltfcqs4dcs3ov4hz-3-2.jpg
Dec 26, 2014 | Computers & Internet
How do i cut and paste photos togeather
open photoshop and open the photo you want to cut. Now use the rectangular selection tool to select the area you want to copy. After selecting the area, press ctrl+c to copy it. Now press ctrl+N to open a new page and paste ctrl+V to paste the selected area of the image.
May 15, 2014 | Computers & Internet
I have e-studio 160. my paper setting is A4 in the cassette try. When i make a copy in platten glass, all the image are complete, But when used the RADF the copy is not complete like, it just like they...
try to reset the copier :
1- turn it off
2- press keys together { 1 - 3 - * } & switch machine on - still pressing the keys until her peep sound
try again & tell me the results
Jun 30, 2011 | Toshiba e-Studio16S Copier
About shortcuts of keyboarding
Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Ctrl + A Select all text. Ctrl + X Cut selected item. Shift + Del Cut selected item. Ctrl + C Copy selected item. Ctrl + Ins Copy selected item Ctrl + V Paste Shift + Ins Paste Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
Jun 19, 2011 | Computers & Internet
When i cut on my hp compaq 6125 its ask for a password that i no longer know. Is there anyone who can instruct me how to reset the password ?
Download PCLoginNow, burn image to a disk on a different computer. Then run it on your laptop
http://sourceforge.net/projects/pcloginnow/reviews/
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Dec 12, 2010 | HP Compaq Business nx6125 Notebook
Cut the copy of image
SET THE ORIGINAL SIZE AND THE PAPER TRAY.Change the security values.
Aug 20, 2009 | Minolta Office Equipment & Supplies
Image on master is cut off
If you open the drum and inspect the master on the drum,do you get complete ink coverage on the image that is on the master.
Mar 16, 2009 | Office Equipment & Supplies
How can i copy the image?
Here is ACER's guide on how to create the eRecovery cd's
http://www.acerpanam.com/synapse/data/7117/documents/Acer%20eRecovery%20Management%20v2.5%20-%20final.pdf
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 06, 2008 | Computers & Internet
Question about copying direct from scan to a Word document
Check if your Canon software creates a PDF image. A scanned image is a RASTER image, a series of dots, that 'appear' like text or drawing. You cannot use Ctrl-C or Ctrl-v. If the software creates a PDF file, you can cut & paste. Usr any good OCR (Optical Character recognition) software ad convert the raster image to editable text. Then you can cut & paste.
S. Moha, Chennai
Dec 02, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
Image "cut"
you search and search and search, and in the end you solve the problem, you don't even know how ?!?
Feb 14, 2008 | Samsung DVD-909 DVD Player
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
101 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
