Question about Logitech Harmony 520 LCD Remote Control
Harmony 520 Remote switching HDMI input on TV (Vizio GL42L)
I have this remote programmed to Switch my input to HDMI2 (where my DVD player is plugged into). When I press the activity to do this, my TV switches to HDMI2 but then switches back to HDMI1 (where my Cable box is plugged into). Pressing the "Help" button fixes it for that viewing session, but once I choose this function again, the same thing happens. I've tried messing with the delay timers for TV warm-up but I can't seem to fix it, and makes it worse. I set the timers back to "default" until I can resolve this.
  • 1 more comment
  • jon catuccio Feb 06, 2008
    I have the same problem. Looking for a fix. Please post back here if you find one.
    JC
  • Anonymous Jun 20, 2008
    Mine switches to the wrong setting eg. on tv it switches to component 1 on TV even though it is set to HDMI2. Pressing help does not help since the remote seems to think it is supposed be at component 1. The settings are correct onthe computer. Just won' send the right signal.
  • Anonymous Mar 29, 2014
    When I set my Onn 15" lcd tv to play from ext2 it performs okay. However if I switch off the tv and then later return and switch it back on again I have to reset the input to ext2 again.
Hey there -
I'm using a Vizio GV42LF and I seem to have fixed the problem.
I just worked with the settings, and actually used the Help feature on the remote which helps you sort out the input select issues; I was surprised, but the step by step, "Is the TV on...yes or no", "Is the TV on HDMI1...yes or no", actually fixed the issue.
Now I have volume control on the TV, and can select channels on the set top box, or switch to my HTPC and stereo etc.
The remote itself I find a little cheap; compared to the Vizio remote, it's amazing how hard you have to push the buttons. The Vizio has "soft" buttons whereas the Log. is HARD to press, BUT maybe this is good if you have a little one running around like a madman.
DC
Posted on Feb 07, 2008
What model TV do you have?
Where do to plug in the cord to connect the tv to the DVD player?
Hello
You have several options for connecting your DVD player to your GV42L FHDTV10A - HDMI,
Component, S-Video and Composite (AV) inputs. Based on your home theater configuration, you can
decide which option is the right one for you.
connected to the HDMI input of the VIZIO GV42L FHDTV10A for optimal results.
To maintain the display quality, use a VIZIO certified HDMI cable available up to 10 meters or less.
1. Turn off the power to the LCD HDTV and DVD player.
2. Connect a HDMI cable to the HDMI output of your DVD player and the other end to the HDMI
Input (white color area) at the rear of the LCD HDTV.
3. Turn on the power to the LCD HDTV and your DVD player.
4. Select HDMI using the INPUT button on the remote or side of the LCD HDTV, or directly by
pressing the HDMI button on the Remote Control.
a) If you are already using the HDMI 1 input for another component, or you do not want to use
the HDMI 1 input for the DVD player, you can connect the DVD player to the HDMI 2
connection.
b) Refer to your DVD player user manual for more information about the video output
requirements of the product.
OK
Apr 24, 2011 | Vizio 42 in. LCD TV
Just installed my new 32le5300. Cant switch to dvd player. manual won't play on my imac. Can you help?
The manual is available as a PDF here: http://www.lg.com/us/tv-audio-video/televisions/LG-lcd-tv-32LE5300.jsp . Click on Support and then the Televisions Manual on the right. Just above is a link to Adobe Reader if you need the program.
LG doesn't always support Mac systems but that shouldn't change the manual access if you have a working optical drive. If you have Adobe Reader, then the problem might be that the disc won't autoplay. Try manually accessing the contents of the optical drive. (Open the File explorer and then the optical drive.)
Next: is your DVD player a stand-alone device or is it part of the computer? How have you connected the TV and the DVD player? The model number would help. Generally, you need to change the source for the TV to match where the DVD player's cables are going into the TV. There is a button for this on the TV's remote (and on the TV, just left of the power button) - labeled Input. The DVD player should be off when the TV is turned on and then set to this source. (The TV can get confused otherwise.)
The HDMI and HDMI2 ports should work with a PC connection (1920x1080 with the input label set to PC for the TV if you change the label for the HDMI ports). The entire list of inputs should be TV, HDMI1, HDMI2, HDMI3, PC (VGA), AV in 1, Component in 1, AV in 2, Component in 2, HDMI4.
I hope this helps.
Dec 30, 2010 | LG Televison & Video
Samsung PN58b530 tv and harmony 550. When setup have all devices set except when the tv turns on it stays on one hdmi setup then jumps to another that was not programmed.
Samsung TV's have Anynet automatic input switching. This severely conflicts with the Harmony Remote as they both do the same jobs; Switch inputs automatically. We would like for you to disable this feature on your Samsung TV using your original remote, so the Harmony Remote will work properly.
Disable Samsung Anynet+
1. Press your Tools Button.
2. Scroll down to Anynet and press your Select Button.
3. Once on the Anynet screen, please press your Left/Right Button(s) to select the Off Setting on the Anynet+ (HDMI-CEC)
4. Scroll down to the Auto Turn Off and select No.
Once this is completed, please turn off your TV and all device and power them back on using the Harmony Remote.
Feb 01, 2010 | Logitech Harmony 550 Remote Control
I can not get my Harmay 520 to program to my tv or vcr,dvd and wii game
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Oct 01, 2009 | Logitech Harmony 520 LCD Remote Control
Harmony 520 no sound control for tv
I can help you program your Logitech Harmony 520 remote for your TV.
I hope that helps.
Sep 28, 2009 | Logitech Harmony 520 LCD Remote Control
Can't change from HDMI2 back to HDMI1
You need to change via tv selections option for tv, this should be possible by selecting the source for tv feed. This should give various options to select hdmi11, hdmi12, scart1 ect. If remote not working to change look on the tv itself for the control buttons, normally on the back to 1 side (rh from front) then pressing the correct button. If this does not work try turning power off to tv for a couple of minutes and then turning back on. Hope this helps.
Apr 29, 2017 | Vizio Televison & Video
Harmony 880 does not change input with Onkyo HT-R520 amplifier
You will either have to use your Onkyo remote to teach the Harmony those functions or try one of the similar model receivers in the Harmony software. I had to chose a similar DVD player in the list in order to get my Harmony to play nice with my DVD player.
Feb 14, 2009 | Logitech Harmony 880 LCD Remote Control
Changing from 480i to 720p on VIzio VX37 with factory issued remote
If you use the hdmi input from your cable box and select either the HDMI1 or HDMI2 input setting it should automatically change based on the channel transmission resolution.
All this is currently controlled by the cable providers set top boxes, and depends on whether you have purchse the Hi-Def programming packages.
Hope this helps you.
Nov 03, 2008 | Vizio VX37L Television
Video performance question
The 2801 (I used to have a 2803) is just an AV receiver, so it doesn't do any video processing.
If you get a DVD player with HDMI or DVI output, you'll be better off doing what you said - bypass the receiver for video and connecting the video directly to your TV, and the audio to your receiver.
It makes things less convenient since you can't switch inputs only with the receiver's remote, but you'll get a much better picture.
If you really need to control the whole system with a single remote, consider getting a Logitech Harmony remote or something similar. They're very convenient.
Apr 05, 2008 | Denon AVR-2801 Receiver
No picture on hdmi2
First of all connect the Direct TV box to HDMI 2 and see if it works there. If it does then the next step is to connect the DVD player to HDMI and see if it wors there. If not then connect the DVD player to the TV using the component inputs and if the DVD player works on those. If it does then maybe the HDMI interface in the DVD player no longer works as it needs to communicate with the TV.
Dec 06, 2007 | Panasonic TH-42PX60U Television
Logitech Harmony 520 LCD Remote Control Logo
1,358 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
ray gallant
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
