Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Tv wont work
I have a rca hdtv and it wont come on green light comes on 3 times then nothing happens
    Genius:
  • 1,030 Answers
This set's processor sees a problem and shutting the unit down for safety. There can be one of about 30 different problems that would cause this to happen. A technician has special computer interface that allows him to read errors in the processor. So this unit will have to be trouble shot further to narrow the problem down.
Posted on Jan 17, 2008
Model d52w20b the green light comes on flashes 3 times but the tv wont come on the green power light is supoose to stay on
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
Jan 14, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Green light comes on for 5 seconds the drops off repeats 3 times then nothing happens,tv won't turn on.
Replace any swollen capacitors on the deflection board. If none found replace the board. It may no longer be available. Pull the board and send to PTS Electronics in Bloomington IN to be rebuilt.
Nov 20, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv's green light comes on then off three times
Check capacitors cp150 ,114, 120 ,if cp150 is puffed up on top it is bad.2200uf 16v and the other 2 are 220uf 35v.
Feb 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20 RCA Projection wont turn on
On the Deflection board CK 3 fuses they will be in a roll on right side of Flyback Transfomer FL231 they look like small rectangler brown caps they are fuses Then Check 3 capacitors cp150 2200uf 16v if puffed up on top it is bad replace cp114 and cp120 220uf 35v.
NO WORK
you have 3 bad capacitors they are green and gold 2200uf and two 220uf 35v.If this is not what is wrong replace deflection board.
Sep 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Wont turn on
Check the solder connections on the flyback and also right next to the flyback there is a small white coil with copper wrapped around it that will sometimes arch causing the solder to need re-soldering
May 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
24 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
