Back to:
Tags:
Onkyo TX-SR601 6.1 Channels Receiver
Volumne
posted by Santka on Jan 17, 2008
I am unable to control the volumne on the receiver
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 20, 2008
Not Rated (0)
CABLE CUY
Rank:Wiz Wiz
Rating: 82%, 33 votes
SOME AMPS HAVE A BUTTON ON THE REMOTE SAYING AMP OR RECIVER,PRESS IT THEN TRY YOUR VOLUME AS THE REMOTE IS NOW WORKING YOUR AMP.
CABLE GUY.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on volumne:
I don't want to Accept this solution
Solution #2
posted on Mar 08, 2008
Not Rated (0)
robotek
Rank:Guru Guru
Rating: 90%, 667 votes
Hi santka
It sounds like it has locked up from a power surge. Try a full reset of the unit by powering it down completely unplugging it from the wall socket overnight. If it still misbehaves, get back to me here and we can look into it more.
regards
Graeme
Thank You!
Can you Help with these Receivers problems?
Receivers
my audio on my logitech web cam does not work when using...
Receivers
My Roalnd W-30 is describing a "Disk Load...
Volume and menu work as I see it on the receiver but it...
System working fine last night. Turned on this morning...
Having issue with my right speaker output on the Onkyo...
Loading problems.
Repair Service
Find Receiver Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
