Question about Dynex DX-E401 Router
Connecting to Xbox Live through my Dynex-E401 Router
The router is working fine for my main computer, and is sending a good signal to my Xbox 360 through the direct ethernet connection that I set up, but whenever I try to sign on to Xbox Live I get the message that says, "Xbox live signup is currently unavailable." Does this have to do with the way the router needs to be configured? Could the router be incompatible with their service? ( I seem to doubt it.) Or, Is it microsoft's network problem?
  • eracer Jan 23, 2008
    I don't know how to log in to the router, so the suggestion has not solved my problem.
You would think that Xbox 360 would be perfectly compatible with UPnP. They should be communicating with each other just fine, (UPnP talks to NATPMP to automatically open and forward appropriate ports), and the game's datastream is probably entirely connectionless aside from the initial handshake (UDP).
To log into your router console, type "" into your browser, for the username enter "admin" and do not put in a password. To enabled Demilitarized Zone (DMZ), click ADVANCED and on the left side click DMZ.
You will need to know the internal IP address to the XBOX360, which can be found on the "CABLE TEST" or "LAN" page in the router console.
If you find that you cannot log into the router console with the supplied information, you need to press the little reset button with a pen for like 10 seconds.
If you cannot reach the router console at then you need to go to Network Connections in windows and find out the "Default Gateway IP" which is the router's internal IP.
The XBOX360's internal IP address will be in the same format as your computer's (if you only have one computer, the XBOX360's IP will probably be and your computer's should be All of these are default values. You can change them in the router console as you please.
Posted on May 03, 2008
Type into your browser
Posted on Jan 26, 2008
  • 77 Answers
You will need to log in to your router and look for a setting similar to "DMZ Host". Configure the IP address of your Xbox as the DMZ host.
Posted on Jan 19, 2008
Trying to acces dynex router for xbox live and need a " pass phrase " lost the manual how do i connect
The Manual:
The default address of the router is Type that address into a web browser on a computer connected to the network and it should bring up the login screen for the router. The default login for the router is Username: admin with a blank password. If you changed this, you will need to reset the router with the reset button and configure your entire network again to make changes.
May 20, 2011 | Dynex DX-E401 Router
I cannot connect to xbox live. I've called numerous times to microsoft with no results. I've called my router company to open gaming ports, which i did and still nothing. Ive gotten a new xbox, and it...
if you are using a router then you will have to set the connection up your main line to allow the connection to be made. if you are direct connecting with the modem to the xbox and its still not connecting then the xbox live server is down. I used to run into not connecting to xbox live alot more through using my router because my router was old and good gaming on live requires a good gaming router. check to see if your computer is acknowlledging your router, And if it is then, Make sure your router is up to date. sounds like a router issue. post back with any more help if its needed :-)
Oct 20, 2009 | Microsoft Xbox 360 Console
Dynex-e402 change nat settings to access x-box live
Dynex DX-E402 router, changing NAT settings(UPnP) to access x-box live. go to router settings web page for router,, enter user name and password to access settings page. user id is usually admin this also for password. under advanced settings click on forwarding. In listed sub-catagories click on UPnp. click enable. this should solve any NAT issues with X-box 360 signing onto x-box live. dynex dx-e402 was very easy to setup.
Mar 24, 2009 | Dynex DX-E401 Router
I have had a wireless dynex router for awhile and it has been working fine using wireless then when i plugged in my computer and xbox 360 to the router it has made the computers using the wireless internet...
it is getting limited or no connectivity because it is actually not connected even though it shows.the best resolution is that change your entire wireless settings and then connect all wireless devices like computer and xbox 360 again it will connect.I use to do the same when i use to work for netgear.
that will fix..
Jan 04, 2009 | Dynex DX-E401 Router
Dynex mtu
Browse to the router's setup page and in Basic setup you will see MTU, change it from auto or default to 1500.
setup page address is,
Look under basic setup page.
Please remember to rate all Techs who assist you for free :) Good luck, Joe
Sep 30, 2008 | Dynex DX-E401 Router
Wep key for dynex router?
put new router dynex good signal no internet on laptop
Sep 27, 2008 | Dynex DX-E401 Router
Dynex issue. is the router's default setup page.
If it is a MTU problem, cahnge the MTU to 1500.
Please remember to rate all Techs who assist you for free :) Joe
Jul 29, 2008 | Dynex DX-E401 Router
Dynex DX-E401
Try an Xbox Live certified router.
Also it could be down to your connection what size is it?
I run 3 Live accounts and 6 PC's with no slowdown at all.
Feb 25, 2008 | Dynex DX-E401 Router
Computers & Internet Logo
1,401 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
